Page 287 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Doug S
3,813
6,749
That’s for Intel 4, not 18A.
The important thing is that it showed that BSPDN allows relaxing M0 metal pitch without affecting density. The same will apply to 18A. M0 will be larger for 18A than it would have been without PowerVIA.
We'll see the same thing with TSMC's initial N2, and the version of N2 coming six months later (i.e. the one that Apple will use) that offers BSPDN as an option. It isn't clear if BSPDN will be mandatory in N2P but from the sound of things it will remain optional as they claim to have some customers that don't want it to save money (whether it actually costs TSMC more or they are just charging more for it intially isn't known I guess)
Ghostsonplanets
774
1,228
Too bad Ghostsonplanets is wrong with his tile prediction. Just because LNL integrate Soc into the compute tile doesn't mean Intel will do the same with their regular mobile lineup after Arrow Lake. Why should they do this if they are 18A volume limited. Panther Lake is not a MX chip, it's UPH. There is no On-package memory either based on the Intel slide.
Prediction? I believe this was the rumored upon Tile configuration of PTL until Tigerick said that there's actually 3 tiles (+base). Intel wanted to reduce the heavy handed tile approach of MTL/ARL, hence why the reduction in tiles.
Even then, the claimed CPU tile is still absorbing the SoC tile, NPU, MEDIA Engine, etc into a single tile. With PCD replacing IO and the tGPU being separate like MTL.
I also never claimed it was a LNL MX follow-up sucessor. I even questioned why l, so far, PTL has no indicative of following up LNL or having a LNL like SKU.
mikk
4,333
2,413
The only credible rumor was a 3 tile design xino mentioned. Tigerick was wrong in the beginning, however the newer/corrected info he posted sounds legit because it's more detailed.
To me it's a summary of leaks combined from other people what Prakhmar posted, most of the stuff he told wasn't new to me. It's not like he faked it. It doesn't mean everything is correct though. I was sceptical about the 4+8+4 core config but now I think it makes sense, they can reuse the Lunar Lake layout with the 4 LPE cluster and add 8 E cores into the ringbus. They can shut down the ringbus cores and L3 in lower load scenarios as with Lunar Lake. LPE cores should be much more useful on the same node and tile and twice the cores count, on MTL it was underwhelming.
Henry swagger
513
313
Gracemont in Alder Lake already is ~95% of the per-clock integer performance of Cypress Cove. In Raptor Lake, it should surpass the PPC of Cypress Cove. Skymont should at minimum be Golden Cove level of PPC.
All this is based on the SPECint_rate 2017 1T numbers from past Anandtech reviews.
Even leaks said its targeting golden cove ipc.. skymont will be 8 wide
Hulk
4,056
I have come to the conclusion that MTL will always be somewhat of a mystery performance-wise. It's hard to lock these mobile parts down to a frequency to isolate them for "throughput" and efficiency tests I guess. In my head right now when I think of MTL I think, performance at least as good as RPL mobile but with better efficiency and much better iGPU. But I have no objective metrics that readily come to mind that I have faith in.
I think Intel may have an opportunity with Lunar Lake. As we know memory subsystem performance has always been the achilles heel for mobile systems. Putting main memory on the tile hopefully will alleviate some of discrepancy between desktop and mobile performance.
Ghostsonplanets
774
1,228
I think it's best to think of MTL as a TGL, even if a bit disjointed due to the first step into a disaggregated architecture.
It's a genuinely good product, even if it can't best the competition. CPU performance is a bit lackluster, but it has an amazing GPU IP, best in class Media and Display Engine, good ISV support for NPU and AI workloads. It's also an amazing leap in perf/W, efficiency and battery life for Intel, specially coming from "No battery" Alder/Raptor "No life" Lake Mobile.
If you can buy a laptop with MTL, specially 6+8 and with decent pricing, it's a no brainer. Or you can wait for ARL-U to bring a 10% bump in efficiency for the Compute Tile alongside a price reduction and higher availability.
I think Lunar Lake will be one of the most significant launches for Intel. As you say, they have a very interesting opportunity to turn around the x86 performance and battery life discourse while also offering a flexible chip that can go into either fanless or fanned and enabling novel PC designs. Genuinely (IMO), the most interesting launch from Intel this year.
Gzxy
9
9
41
I just answered that here: https://forums.anandtech.com/thread...akes-discussion-threads.2606448/post-41190543
Intel doesn't have capacity. Intel doesn't have capacity. Intel doesn't have capacity. What part of that are you struggling with? If you need me to say it another way: Intel bought too little equipment and is maxed out on their top nodes.
So rather than build only your own chips in your fabs, you build other people chips in your fabs and you outsource yours in TSMC since you cant risk having huge capacity if IFS fails and maybe your future nodes aren't very competitive. Also use some of your own capacity for server chips (Xeon) where margins are better.
Hulk
4,056
I'm seriously considering that Zenbook 14 that Anandtech used to review MTL. I checked one out at MC and it was very impressive. I'm using a 6 year old Surface Laptop 2 that quite honestly has been a fantastic device. But times have caught up with it. The iGPU is useless for video editing. Topaz video/photo AI, and PureRaw, which I use quite often. Also the 4 Skylake cores are overmatched for many of my apps.
I've been waiting and waiting for the Surface Laptop 6 and am super eager to upgrade so I don't have to go to my desktop every time I need to do something compute intensive.
Reactions: Ghostsonplanets
19,210
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E08 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E3CPU + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (20A)Arrow Lake (N3B)Arrow Lake Refresh (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop OnlyDesktop & Mobile H&HXDesktop OnlyMobile U OnlyMobile H
Process NodeIntel 4Intel 20ATSMC N3BTSMC N3BTSMC N3BIntel 18A
DateQ4 2023Q1 2025 ?Desktop-Q4-2024
H&HX-Q1-2025
Q4 2025 ?Q4 2024Q1 2026 ?
Full Die6P + 8P6P + 8E ?8P + 16E8P + 32E4P + 4E4P + 8E
LLC24 MB24 MB ?36 MB ??8 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
Can you update your post to include this link? https://forums.anandtech.com/thread...akes-discussion-threads.2606448/post-41187952
Would be helpful for new readers.
19,210
Would that be the best performance for your dollar, considering the impending launch of a tiny little chip from a tiny little company called AMD?
Reactions: spursindonesia
tamz_msc
3,865
3,730
Nah, get the IdeaPad 5 Pro - it comes with LPDDR5x-7467.
Reactions: Hulk
dullard
26,192
4,859
Intel is now internally two different companies. There is no longer any "own chips" for their fabs. Intel's fab sells its wafers to the highest bidder. Intel's processors are made at the fab on the node that they determine to be right for the job (based on capacity, timing, cost, performance, efficiency, etc. as I outlined above) whether this is Intel Foundry or TSMC or Samsung (for the upcoming Lunar Lake LPDDR5X) or who knows maybe or Global Foundries will be included at some point.
Intel foundry will even produce chips for CPU competitors: ARM, Qualcomm, or AMD if they so choose.
Intel’s manufacturing groups will face the same market dynamics as their external foundry counterparts and need to compete for volume through performance and price. This includes Intel’s internal customers, who will have the flexibility over time to engage with third-party foundries. It’s not an entirely new notion for Intel, however; today, roughly 20% of Intel’s silicon is manufactured externally.
Aapje
1,530
2,106
Intel is now internally two different companies. There is no longer any "own chips" for their fabs. [etc etc]
You are confusing their goal with where they are right now. Even according to themselves they are still working towards being able to supply chips for more use cases, having tooling that is on par with TSMC and being competitive on price, performance, etc.
And they definitely will try to make their own chips, because if they don't, their foundry business will die. Not just because they need all that volume, but also because other big companies won't trust Intel Foundry if even Intel Design doesn't use them.
dullard
26,192
4,859
Since this is a discussion of the fab for a future product, Nova Lake, I think it is quite appropriate to talk about Intel's future fab goals. Applying where Intel is now for future products seems wrong to me. Especially a product that is 2-ish years away. That is a lifetime in technology.
tamz_msc
3,865
3,730
Gracemont's IPC is around (6th gen) Skylake IPC only. And I don't think Skymont is going to double the performance over Gracemont. Even a good IPC uplift should put it in the ballpark of Sunny Cove.
I don't think Skymont is going to come anywhere near Golden Cove's IPC.
Those graphs show overall performance, not IPC. For the latter, divide the SPECint 2017 score by the fMax of the Gracemont cores in Alder Lake.
Raptor Lake E-cores should be a decent uplift over those in Alder Lake in terms of overall performance because of the fixed ring frequency behaviour, doubled L2 per cluster and increase in fMax.
coercitiv
7,473
17,858
I think MTL performance is just a tad below RPL actually. Probably due to the tile overhead.
We have data to prove MTL can provide higher throughput at equal power levels. The loss in ST performance is negligible to end users. The product is better than RPL, it's just not good enough of an upgrade considering the time frame.
However, take this opportunity to reflect on the supposed advantage in packaging technology Intel is supposed to have over AMD. The advantage alone is not enough to justify the use of tile segmentation in mobile, IIRC folks like @Exist50 and @IntelUser2000 talked about this long before the product hit the market. Intel is learning though, and in the future this experience will pay dividends.
Aapje
1,530
2,106
Yes, if you use future tense.
When discussing the future, you regularly want to refer to the present and the past, which is a lot easier if you use the correct tense for each.
dullard
26,192
4,859
In my view, the packaging technology has the main benefit of giving Intel the ability to swap one chip for another in a new iteration of a CPU. That was basically their selling point for the concept when it was first announced years ago with their Client 2.0 presentation.
But of course, if the main benefit is that the NEXT CPU is easier to make means the first CPU gets few of the benefits and all of the drawbacks.
Reactions: Hulk
