Page 237 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
H433x0n
1,224
1,606
No, even if they made a reticle limit DG2-1024 at 450W they'd still be behind the 7900 XTX in raytracing performance. So-called architectural advantage does not exist if you can't build bigger. It doesn't exist so they're not number 2. Same thing with AMD saying one of the advantages of their multi-chip architecture is that they could build a supermassive 400mm + 8 MCD RDNA3 chip to match the 4090. OK cool, but they didn't so it's whiteboard cope & dreams and they stay #2.
To summarize: if your raster performance is 0.5x RDNA3 per area on iso process it doesn't matter that you have -23% RT performance and they have -45% you're still 0.7x RT performance per area on iso process. Their raster is just really, really bad.
Let's setup a hypothetical:
RDNA4 improves RT performance drastically and enabling RT incurs a 30% performance hit. However, the 7900 XTX still outperforms it because it has a higher raster perf baseline. Would you consider RDNA4 RT perf to be a regression in that case? If you do, I can understand it, but I would disagree.
To me in that example scenario, I would still say RDNA4 has improved RT performance.
Khato
1,381
491
With respect to Intel's graphics, the better comparison at current is between Meteor Lake and Phoenix/Hawk Point. GPU die size is comparable despite the process node advantage for AMD. Intel may well be a bit slower and less efficient, but it's close. It'll be interesting to see what kind of improvements Intel brings with Arrow Lake and Lunar Lake compared to AMD's Strix Point. The additional CUs will almost certainly best the minor gains on Arrow Lake, but how it fares against the larger Xe2 based Lunar Lake will be most interesting.
gdansk
4,780
8,071
It has improved RT performance but would have done nothing to become #1 in raytracing. Which was my problem with Igor's claim of Intel being #2.
Reactions: Tlh97
gdansk
4,780
8,071
While it would be most relevant to this thread we can't normalize for the rest of the test configuration.
Khato
1,381
491
I take it you're referring to memory bandwidth? Or power consumption?
Regardless, the interesting point to keep in mind with Intel's graphics is that DG2 was effectively Intel's first serious attempt at a large, high performance part. Which was pretty obvious with the resulting poor PPA. Meteor Lake fixed some of the issues with the design, Xe2 will fix even more. I'm still surprised that Meteor Lake is pretty much on par with RDNA3.
gdansk
4,780
8,071
Yes to both. Even CPU performance differences and sustained cooling.
MTL seems much closer but since they're both in the realm of "RT performance is useless" it doesn't support Igor's claim either. But it bodes well for BM.
Reactions: Tlh97 and moinmoin
DrMrLordX
23,223
13,303
Yes. It would be a total regression in performance by every metric.
DavidC1
2,187
3,339
Compared to MTL-H's iGPU, below is the major changes in ARL's iGPU:
  • Doubled L2 cache.
  • Doubled RT throughput.
  • XMX cores added.
Are you going to address my questions I asked earlier Tigerick?
Yes, but that would be a very unbalanced architecture. If the die sizes are same, it means this hypothetical RDNA4 has dedicated too much to improving RT performance when it has to be balanced for all workloads, including raster.
It's equal to if Zen 5/Lion Cove reduces CPU performance by 20% but improves AI performance by 20x. Yay?
DavidC1
2,187
3,339
Latest advanced 3D packaging technologies like foveros are very interesting when compared to old and outdated substrate based 2.5D tech like in Zen5.
Ok, but Meteorlake sometimes underperforms the predecessor at the same clock, while Zen series was faster in every way, and competitive with monolithic Raptorlake.
You say fancy things, you dress it up fancy, but it ends up being plane jane. How many people outside of Intel fans will see it otherwise?
They used to lead in DDR implementation, memory controller performance, and caches. Ah, but it's just the fault of the "process" right? RIGHT?
Reactions: Thibsie and Tlh97
19,218
They have better RT cores, do they not? Regardless of whether they are using more die area for that. I like the fact that if I suddenly developed an RT fetish, I could get an A770 or the Battlemage A870 and satisfy that urge without making Jensen richer.
coercitiv
7,486
17,891
Foveros is top tier packaging, it just happens to hang around with some very shady core types. I fear some day we'll find it face down in some organic substrate, a victim of circumstance. Such awesome potential, such a sad story.
19,218
AMD would love that for bragging rights. Some previously infeasible AI applications would become a reality. So yeah, that would be a YAY!
FlameTail
4,384
2,762
Foveros, Lion Cove and Alchemist walk into a bar...
Reactions: lightmanek
Hulk
4,110
You have some good points here. I'll try to answer.
If Foveros is so great then why is there such a performance hit when moving from monolithic Raptor Cove to supposedly superior Redwood Cove and Foveros?
There will always be a performance loss/increase in latency when moving from monolithic to tiles. Intel slightly improved Redwood Cove to try and offset that in moving to Meteor Lake.
AMD made the move to tiles many generations ago so when moving through current generations they were on equal footing (all tiled).
But your original point is a good one. Tiled Zen 4 still had at least as good, probably better IPC than tiled Redwood Cove despite all this hype regarding Foveros. Why?
Couple of reasons. Zen 4 core is really good, better than we even thought as it "makes up for being tiled." Foveros isn't really doing anything special compared to AMD tiled solution.
AMD has had a couple of generation to get their tiled "act" together. This of course doesn't help Intel because you are right, they did a lot of talking and Meteor Lake is just "okay" in my opinion.
jpiniero
17,200
7,575
Meteor Lake is better than Raptor Lake. Just not all that much. That more likely has to do with Intel 4 than Foveros.
FlameTail
4,384
2,762
Why are you calling AMD chiplets as 'tiles'?
Hulk
4,110
Better in what ways?
Efficiency, then yes of course.
IPC? I don't think so but I could be wrong? I was under the impression that Raptor Lake does better than Meteor at iso frequency?
Hitman928
6,754
12,500
IPC I think is basically equal across a large testing suite. Loads that are really latency sensitive probably perform worse on MTL clock for clock.
adroc_thurston
8,578
11,314
It's not 3D, the base is passive.
That's 2D flipchip.
2.5D is passive slabs a-la MTL.
MTL has a brand new NOC.
It's IOSF. From 2012.
You can even like look for MTL hotchips slideware.
Because they moved the relevant bits (IMC and pretty much the rest of the uncore) from the ring to IOSF.
