Page 238 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
19,218
I hope we see some OEM release a mini-ITX or micro-ATX mobo with soldered MTL that can be overclocked with liquid cooling.
Would be interesting to see the actual limits of Intel 4.
ondma
3,321
1,712
Intel slides during launch said it's NOC. Even anandtech says NOC. Many other say it's NOC. If you believe otherwise, it's perfectly okay. It's a free world and we all have our right to believe what we want. Just for you though...
Link1
Link2
Link3
Link4
Link5
Sometimes we just have to accept the fact that ARL is gonna be superior to Zen5 in some aspects.
I'll repeat it once again esp. for you though: As of now, only LNC appears to be the weak link in ARL. As far as packaging is concerned, ARL is far superior than Zen5.
Give it a rest with the packaging hype. Dont get me wrong, I would love to see ARL be very competitive or even beat Zen5. It is the final performance and power consumption that counts though. That is the sum total of all parts of the chip. So what if Foveros is superior to AMD's solution? If the core is not as good, that is like putting higher speed rated tires on a car with a less powerful engine. Yes, it may be better, but it is not the determining factor in final performance.
Khato
1,381
491
adroc_thurston
8,610
11,325
Why exactly is there an assumption that Intel's limited to a single protocol?
every single fabric is a whole zoo of different protocols, we're talking physical implementation which is yes, IOSF.
Like in 2012 Intel-based phones.
Or Avoton.
Zen5 is already better than ARL in all aspects
Yea.
ARL doesn't even stand a chance at all.
yea.
If LNC performs admirably,
It's more stuff.
More stuff isn't what Intel needs in their big cores.
Khato
1,381
491
Or Avoton.
IOSF is the protocol used for the connection to the IOE, and internally in the SOC tile for a number of the IP blocks.
The CPU tile and GPU tile are using IDI and iCXL protocols, respectively. Pretty clearly spelled out in the hot chips meteor lake presentation.
adroc_thurston
8,610
11,325
It's all IOSF, that's their point to point distributed NOC.
The I/O part is just non-coherent slaves.
Protocols are whatever, iCXL replaced GTI and that wasn't the big change.
19,218
No matter how much time anyone wants to waste debating how excellent the packaging or any other tech Intel has at their disposal, they are determined to not compete as long as they can because they simply do not want to spend more and keep costs down thanks to the mess created by Pat's predecessors.
They could:
increase cache sizes
decrease cache latencies, even by a single cycle at every level
improve their memory controller for lowest latency timings and highest memory speeds
widen their internal I/O datapaths/buses to transfer more data at higher speed
use huge eDRAM or HBM L4 cache
have a future kickass architecture backported to their most refined process node as a plan B
All of the above are very expensive things to do for them in their current financial condition.
If Arrow Lake still manages to impress, it will be a miracle that Intel badly needs.
Reactions: krawcmac
Hitman928
6,754
12,500
First MSI Claw (their MTL based handheld) previews are out, https://www.tomshardware.com/video-...nst-amds-phoenix-apu-in-early-msi-claw-review
They call them reviews, but since it is still not a retail release, I prefer to call them previews. Performance is not good against the Rog Ally handheld built around AMD's Z1 Extreme processor. It is quite a bit slower in every game they tested. Not sure if its down to being strictly power limited compared to the laptops we've seen so far or beta firmware/drivers that need improving (probably both). Hopefully firmware/driver updates can help improve its performance and at least close the gap a bit.
DrMrLordX
23,226
13,305
Meteor Lake seems to struggle in gaming benchmarks.
@SiliconFly
That's an "if". A big "if", since the only preview we have for Arrow Lake is that leaked Intel slide showing it beating Raptor Lake by a lousy 20%, at a 251W PL2. Based on that, I'd say Arrow Lake is going to be neck-and-neck with Raptor Lake, just at a lower overall power consumption (unless Intel is dumb enough to ship more CPUs with high PL values).
CouncilorIrissa
788
2,855
While I believe that MTL will end up a bit slower, I'd like to point out that ROG Ally is a mature device at this point. It's performance at low power envelopes has gotten a lot better since release, so I think there's quite a bit of headroom for the Claw to grow.
CouncilorIrissa
788
2,855
LNL's here (presumably):
