Page 232 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
H433x0n
1,224
1,606
With the release of Hawk Point, Notebookcheck ran some tests on the new AMD chip against their latest MTL numbers. I'm posting a chart here where they re-did their Cinebench r23 scores over power consumption like they did at MTL's release. I'm only including the Intel MTL vs RPL numbers to compare the latest versus release numbers. Overall it's basically the same as the release situation. The release tests did 28 W - 45 W whereas this is a higher range, but overall the results are basically the same. The 155H is roughly 5 - 10% more efficient than RPL depending on what power level you are running at. So whatever updates have come with the latest laptops/firmwares, it hasn't really affected MTL's positioning in compute performance / efficiency according to this test.
Really wish they did a test below 35W. Nonetheless at 35W it’s 12387 vs 11211, or roughly 10.4% perf/watt.
Abwx
12,032
4,995
It s about 20% better perf/watt, you should look at how much power RPL match MTL@35W, that s the perf watt improvement and this has nothing to do with the perf improvement at same power.
Comparisons should be done for a same task performed within a same time, just imagine that car efficency is measured at a same distance over a same speed,
In Europe the standard is the comsumption for 100km at either 90km/h or 120km/hour, so a same amount of work within a same time, that s the same for CPUs.
Now if a car or CPU consume 50% less to provide the same work you can trade this better efficency for higher perfs and increase the speed (at same power) by about 1.4x since power increase at least as a square of speed not only for CPUs but also for cars since Power = (1/2)mv^2 and in the case of CPUs Power = f^2 in the favourable part of the curve.
Hitman928
6,754
12,500
Yes, many people have a hard time understanding when someone says there is not high confidence of something that it might not be true--Even those on Reddit. I've seen lists like that plenty of times here. He isn't perfect. But it is ignorant to ignore everything he posts because some things haven't come true. There are saved images of his leaks, no need to store videos. Feel free to give those saved images a proper review if you want (which if you want to exclude someone you should do a proper tally). A lot of his leaks do come true. A lot do not. Below are some of his Meteor Lake images.
Is he correct in everything? Heck no. But 2 and 3 years before the Meteor Lake launch, he actually got some important details right, even in his speculation white font.
Nov 2020:
June 2021:
June 2022:
Nov 2022:
Dec 2022:
May 2023: View attachment 93763
June 2023:
I'm not sure why you posted all these screenshots, none of them really help his case. He was either wrong on the vast majority of this (including his high confidence items) or was just catching up to what other leakers were already reporting. Two easy examples of this are first, that he claimed to have known MTL was RWC for a while, but only after others had already leaked it (which is why he is saying he knew about it for a while but just hadn't reported it). The second example is him claiming his "sources" telling him about two "hidden" E cores and them creating a power island when this had been leaked over a year earlier.
Others call him out on his wrong info all the time as well, so it's not like he can fall back on the excuse that plans changed. One clear example of this is here:
SiliconFly
1,924
1,284
Catch up? I don't think that phrase cuts the mustard. Let us look at the bread and butter.
https://chipsandcheese.com/2023/09/23/intels-ponte-vecchio-chiplets-gone-crazy/
It's has potential, but it's not going to leap frog refined technology on it's first release. In some ways it seems like they bit off more than they can chew.
Thats talking about the outdated PVC. ARL is very different. A generational leap in packaging technologies compared to PVC. And far ahead when compared to even the upcoming Zen5. Zen5's outdated substrate based chiplets connected using the dated infinity fabric architecture is not even a competition when compared to ARL's foveros and NOC interconnect fabric which is light years ahead. Fab 9 is purely dedicated just for foveros to give Intel the required lead in packaging tech.
SiliconFly
1,924
1,284
I wish it was primarily Intel silicon but the bulk of ARL is on TSMC N3B. The top ARL SKU on N3B looks like it should be able to reach ~5.4ghz boost clocks.
On its own terms (relative to Golden Cove era) it looks like it’ll do okay.
Many of the tiles are outsourced. But the key components, like the CPU tile & the packaging tech, are all Intel.
SiliconFly
1,924
1,284
If Zen 5 loses to ARL in performance or perf/W, it won't be because of advanced packaging or the lack thereof imo. Ultimately, AMD's choice in using a substrate based SerDes interconnect was based on engineering judgement, not a lack of imagination. I'm sure if AMD determined advanced packaging was needed, nothing would prevent them from doing so, especially since TSMC is the leader in it. If anything, the fact that Zen 2 to Zen 5 all successfully use the same interconnection tells you how little it holds back their design in the grand scheme of things.
TSMC is not the leader in packaging tech anymore.
dullard
26,196
4,868
First, you claimed that it was not possible to verify his claims. Here are your words, "you can't go back to show how wrong he's been". The screenshots prove you to be wrong, you can readily verify his claims. Heck even if there weren't screenshots, you even contradict yourself "Others call him out on his wrong info all the time as well..." Is it possible to show he is wrong or not? Please make up your mind.
Second, nice change of goalposts. The discussion is about the reliability of his posts, not originality.
So, do you want to analyze his posts from the screenshots or not? If not, why keep making claims about him?
Hitman928
6,754
12,500
You're taking my words out of context. I was talking about how he deletes many of his videos where he got things very wrong, so you can't go back and show how wrong he's been because he deletes his most inaccurate predictions, not that he deletes everything.
Umm, what? The point was that he doesn't deserve legitimacy. Saying you got info from "sources" or claiming you are leaking info when others first reported it detracts from his legitimacy. If he says he can independently confirm what others have leaked, then that's fine, but that's not what he was claiming in the examples you showed that I called out. Additionally, if he's only reliable in "confirming" what others have already leaked, what's the point?
Do you really want me to go through and list everything he got wrong or was behind other leakers on? I mean, I guess if you really want to we can do that. I can also point to multiple posts where others have already called out his innacuracies despite his high confidence predictions if you'd like.
dullard
26,196
4,868
Talking about deleting a video is meaningless drivel when the heart of the video is saved and can be discussed. It isn't a discussion about whether he is a coward weasel when pointed out to be wrong. It is a discussion about whether or not leaks are usually accurate or not.
Umm, what? The point was that he doesn't deserve legitimacy... Additionally, if he's only reliable in "confirming" what others have already leaked, what's the point?
If he is legitimately correct on an issue but wasn't first, why discount his posts unilaterally? I'm only calling for people to actually base discussions on data.
What is the point? The whole thread is about talking about what is happening in the future--not bragging rights about what leaker was first. Someone who gathers leaks together is useful towards that end.
Certainly, as long as it is a good faith effort to highlight what was both wrong and right. No twisting of data, no hand wringing. No nitpicking that if a 0.999999 isn't close enough to be 1 so that someone calls a prediction of 1 years ago wrong since it actually is 0.999999. Lets work together on this. Ideally others would join in and track many leakers.
Hitman928
6,754
12,500
Are you saying that you have screenshots from the referred deleted videos? If so, please post them because none of what you posted appear to be about the subjects of the deleted videos in question.
Never called him a coward, just that he shouldn't be legitimized and if we are talking about whether his leaks are accurate or not, him deleting past inaccurate leak videos absolutely is relevant and should be part of the discussion.
Because he is claiming that he is leaking these things from inside sources when they were already publicly leaked or sometimes officially reported. You don't see how that hurts his credibility, that he takes credit for things others already leaked?
If he wants to be a rumor gatherer then that would be fine and I don't think anyone would have an issue with that, but that is not how he portrays himself nor how you are painting him.
Alright but I don't expect to change your mind as I'm pretty sure you'll just hand wave away all the things I point out anyway but at least for others who aren't so invested in defending him, they'll see how bad his "leaks" really are.
moinmoin
5,248
8,463
@dullard Can you please start a thread dedicated to that topic? This got nothing to do with Intel lakes anymore at this point, and aside you nobody is really interested in that topic.
Intel has positioned itself as leader in packaging tech all the time. Unfortunately Intel also seems to be incapable of turning that into a competitive advantage so far, starting with Lakefried (and before that they didn't productize all the tech at all).
SiliconFly
1,924
1,284
I never said he's accurate. His ARL claims sound as much bogus as most other ARL claims that we've come across. The point being, I said he's claimed so and so! Thats all.
SiliconFly
1,924
1,284
TSMC is the only foundry doing mass volume 3D stacking, and their volume of 2.5D packaging is orders of magnitude higher than Intel's.
Not accurate. Intel is the current market leader in 3D packaging tech with foveros. TSMC has 3D packaging tech, but not many customers. For example, AMD CPUs are 2.5D. Not 3D (except for the X3D variants which are based on a very primitive form of 3D tech thats no where near Intel foveros).
Tigerick
942
857
ARL-S 6P+8E is on 20A. Not TSMC.
Only low volume products on TSMC.
Let's see:-
  • ARL-H 6P+8E on N3B
  • ARL-HX 8P+16e on N3B
  • ARL-S K series 8P+32E, 8P+16E, 8P+12E on N3B
  • Lunar Lake 4P+4E on N3B
  • ARL-S 6P+8E on 20A
And you claimed: the key components are all Intel. Above CPUs which are key CPU???
  • Many of the tiles are outsourced. But the key components, like the CPU tile & the packaging tech, are all Intel.
Reactions: Thibsie
SiliconFly
1,924
1,284
Let's see:-
6P+8E is volume. Sad, mobile 6P+8E is on N3B.
