Page 230 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Hitman928
6,754
12,500
Even so, with a much more efficient process, 1T performance should not be power limited.
MTL uses 20+ W to hit its 1t max boost. Even with the better process, I think it'll have a hard time to hit those same frequencies at roughly half the power.
Abwx
12,034
4,995
Computerbase says it runs sustained at 28W and they also say the cooling can't really handle more than 28W sustained. You are wrong.
Want another source? Here you go
The cooler not handling 28W while the fan is spinning at full tilt..?.
Granted it is possible, then after how much time is the device throttled, and are you sure that it s the perfs at 28W?
Because your Ultrabook review has also displayed some HVinfo screens :
From the first CB run to the last ones the perf gap is such that the first run use about 80% more power than the last ones if i do an evaluation in function of Intel s power/voltage characteristic, and effectively that amount to 50W throttled to 28W.
But you cant be sure that it s 28W for games FI because any recovery of the cooling apparatus will increase the power accordingly up to 50W if necessary, be it with a bursty maneer.
mikk
4,333
2,414
And you are sure it wasn't 28W even when CB clearly says it runs at 28W when using CPU+GPU right? The Zenbook is the most tested MTL laptop and in all of them there is a sustained power of 28W on the performance profile. Here another one in a game:
I don't see how a real game test could make use of a 28 seconds long PL2 given that the menu and loading into the game test already uses quite a bit of power. It's not something like Cinebench or most other CPU tests from idle to load. Once the device enters PL1 there is no sudden spike to 30+ in all the tests. Here another example:
FlameTail
4,384
2,762
Dayum.
Meanwhile Apple P-cores just use 1/3 of that power.
Abwx
12,034
4,995
For the Ultrabookreview tests that s possible because the CB scores are not as big as what they were with previous tests here and there, although they published the score for the first run which is certainly not at 28W if we look at the score after a few runs.
The score CB R15 score at sustained power after throttling is effective amount to about 11000 pts in CB R23, anyway we ll get a better picture once Computerbase release the CPU tests.
SiliconFly
1,924
1,284
A recent HY post talks about packaging tech like (cowos, emib, foveros) in recent CPUs. In essence, ARL's foveros is gonna be far superior compared to Zen5's dated infinity fabric. ARL's fate now solely rests on LNC perf.
maddie
5,204
5,614
Foveros & Infinity fabric. I hope you realize the difference. Comparing those two is worse than using apples and oranges, at least they're still fruit.
Markfw
May 16, 2002
27,406
16,255
What you neglected to mention is that most of that link is talking about what Zen 6 will use, nothing to do with Intel, except comparing these to Intel.
edit: In fact the title of the video is "
AMD ZEN 6 — Next-gen Chiplets & Packaging​
Reactions: Mopetar
SiliconFly
1,924
1,284
It's clear. That means Zen5 is still stuck with the dated infinity fabric. Also, he says Zen6 might adopt something similar to emib and not foveros. Thats still behind.
SiliconFly
1,924
1,284
Superiority matters little if the performance isn't there.
It may perform better than we anticipate. One leaked slide without much context says only 5% increase over previous gen, whereas MLID claims about 30% ST increase. It's all smoke and mirrors until we get real data. From what I gather, Intel has ditched all old tech in favor of LNC for future client & server which indicates its enormous potential. There is always a chance it may surpass Zen5 in ST. Only time can tell.
19,218
AMD's decisions are well thought out. Intel could always donate Foveros to AMD. If it's a good technology, Intel sure as hell doesn't know how to use it to get ahead. Case in point: Crater, uh, Meteor Lake.
Yes, I know you will say Lunar Lake will use Foveros to great effect. Good for Intel. But AMD will still find a way to give them grief.
SiliconFly
1,924
1,284
Lets ignore other fruits. It's direct apples to apples comparison. Chiplets.
SiliconFly
1,924
1,284
Lets hope they find a way. Cos with fab 9 operational, Intel naturally becomes the de facto leader in packaging tech in the industry for the foreseeable future.
SiliconFly
1,924
1,284
It's smoke alright. From whatever MLID is smoking :p
IDK. But there is one particular thing that he has that no other tech tubers have. Sources! His understanding of tech may be limited, but some of his info leaks have hit the mark.
In short, I've seen many people saying that he makes up stuff. Maybe. But sometimes he does leak some terrific info well in advance compared to others. For example, he was the first one to say ARL lacks HT. And he was the first to mention RU. Same with bergamo and many more when others didn't even have a clue.
His 30% ST gain claim is a bit bold. Maybe true. Maybe isn't. But compared to all other ARL leaks, his makes more sense.
mikk
4,333
2,414
H433x0n
1,224
1,606
That 5% was for Specint, which isn't really indicative of what most users will experience. The numbers for benchmarks that are more representative of client workloads ranged between 10-13% (WebXprt, Speedometer & GeekBench6). These are also the benchmarks that will be used by most reviewers too.
Since that old IgorsLab leak, the fmax has been increased and thus the 1T perf estimates provided by Intel have also improved.
maddie
5,204
5,614
Foveros is a physical interconnect. Infinity Fabric is a logical one, that can use a multitude of physical interconnects. Your assumption that you can use them in the same sentence and compare is woefully ignorant.
Tell me which physical interconnect will AMD use? Hint, Infinity Fabric is not the answer.
coercitiv
7,489
17,901
Not maybe, he does make stuff up. That's the problem with having a YT show built around leaks, his audience expects him to deliver on time & every time, so he ALWAYS has something for any upcoming product from Intel, AMD, Nvidia. If some bird chirps in his ear it's all good, if not then he'll make do with the wind.
SiliconFly
1,924
1,284
Let me rephrase. Intel uses foveros which has chiplets on top of an interposer connected using the advanced NOC interconnect fabric. This is far ahead of AMD's dated chiplet design, where the chiplets reside on the substrate and are connected using the very dated infinity fabric.
Like I said, Zen5 is not gonna catch up with ARL in packaging tech. ARL's foveros & NOC interconnect are far too advanced. ARL's only weak point may turn out to be LNC and may lose to Zen5 in ST or MT. Or maybe not. Hard to guess at this time.
