Page 800 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
919
834
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
LightningZ71
2,644
3,324
xtor density metric doesn't really matter. You can't even compare them ISO anyway. Plus it varies tremendously with cache sizes.
Only thing that matters is the performance delivered per mm2. In that case Intel still sucks for Lion Cove and Battlemage. But Skymont for example is pretty damn good.
Which would really be weird since X3D is about gaming. What "ST" gaming is there nowadays?
While most big studio modern games are multi-threaded these days, the vast majority of games still have a single thread that carries a considerable amount of weight with respect to game load and performance dependence. ST performance is still VERY important in high framerate gaming. In games that aren't as demanding in that category, it doesn't really matter after a certain point.
MS_AT
913
1,829
IF Microsoft is working on it than Yes 🤣
Well, after Alder Lake release Linux was in worse condition, and scheduling for Threadrippers is still messed up in there unless somebody patched the scheduler after David Huang wrote about it.
Not to mention even if you you are an app developer and want to guide OS about thread allocation you have another corner case to account for.
Reactions: Tlh97 and 511
511
5,118
4,605
WE got so many patches after Alder Lake now Linux scheduler is pretty good imo but can't say that about the windows one.
Yup
Reactions: Io Magnesso
ondma
3,316
1,708
Core counts will only go up on specific products, and only because it is dead simple for them to add a second chiplet.
x86 isn’t going anywhere.
When you count hyperthreading, they will be pretty close in terms of performance. Power limits and IPC will be the deciding factor.
They won’t. It isn’t even confirmed to be a Core X part. It could end up being an Xeon workstation part.
If it ends up being a Core 9 or whatever Intel calls their stuff these days, it will probably be $750-$800
Here is my estimate of MT performance. 24 zen cores is 24 real cores plus 24 hyperthreading cores (estimate HT adds 25%), so that makes 30 "effective" real cores. If in fact NL has 16 plus 32, (assume E core 60% of P core-- that is 19 "P core equivalents"). So that leads to 35 "effective" real cores. So if they can get the power and thermals under control, I think Intel should have an edge in MT. Of course, that depends on NL P core matching or very close to Zen 6, and on how well the E cores perform. It also would depend on workload, i.e. how effectively it uses HT and the instruction set of the Intel E cores. Personally, it doesn't really matter to me, as my use case is gaming. In the interest of competition, though, it would be nice for Intel to lead in something, as I dont see them taking back the gaming crown from AMD v-cache chips.
Reactions: Tlh97
Thunder 57
4,206
6,994
So in that case much cheaper than 32C TR. Especially if you also take total system cost into account.
If you believe that Intel (or anyone) would sell a CPU where each core costs $15 or less than sure. Especially when they are pushing for margins now and just announced more layoffs.
511
5,118
4,605
you need to modify your calculation an E core is 70% of a P core in Peak ST but in PL Workload it's lot closer this gap is going to be like to be lot less with NVL.
The margin is Gross Margin and for new products also gross margin only includes Cost of Good Sold not R&D and other stuff
ondma
3,316
1,708
Hopefully you are right that the E core is closer to the P core in total throughput, but I was using a conservative estimate. Don't forget, the E cores have both an IPC and a clock speed deficit compared to the P cores. For instance in the 285K, the clock speed deficit alone is 20%.
Reactions: Tlh97
coercitiv
7,447
17,752
You also need to take into account the pressure on the L2 cache, when running heavy MT loads the E core has to work with less effective L2. That's one of the perks of the P core, their own L2 cache with a beautiful private alley to ringbus valley.
DavidC1
2,021
3,157
For people who don't follow him
This is damm good.
Looks like they are actually making good progress for Panther Cove
@DavidC1
Arrowlake's LNC is 3MB and 17 cycles. Why is 18 cycles at 4MB impressive?
That's not true anymore since Arrowlake generation. Golden Cove was 40% faster per clock and clocked 33% faster in Alderlake and 35% faster in Raptorlake.
In Arrowlake Lion Cove is just 10% faster per clock and 24% higher clocks. It's already at 73% of the performance.
I assume Novalake will close the gap even further. Hence why they went to 2:1 ratio vs 4:1 ratio. Expecting 30% gains again on Arctic Wolf with two P core iterations maybe doing 10% each, so the P core will be just 5% faster. That's over 75% performance.
@LightningZ71 Why would an X3D part be slower in ST gaming?
poke01
4,606
5,916
Because it’s not. Nothing is impressive from Intel till Unified Core. Everything you see on Intel Twitter is hyped beyond comprehension as they are still living in Intels heyday.
Reactions: lightmanek
LightningZ71
2,644
3,324
My comment was directed specifically at the Gen on Gen performance difference between vanilla non-x3d Zen5 vs. vanilla non-x3d Zen6. There are only three cases where I would expect an X3D parts to be slower in ST performance than it's predecessor or the non-x3d sibling:
1- notable peak clock speed deficit, largely gone with Zen5.
2-Thermal throttling due to heavy MT loads running concurrently or poor cooling leading to heat soak. The vanilla part should generate slightly less thermal load and should maintain slightly higher clocks.
3- a weird corner case that exposes the minor latency hit that the 3d cache causes.
My argument for Zen6 is that, if the rumors are true, the 12 core CCX will have 48MB L3 cache at a comparable latency to the 8 core 32MB L3 CCX in Zen5. The 50% larger L3 would theoretically be available for a pure ST scenario, helping any apps that are dependent on it. It should also be less affected by cache pollution as the cache is larger and has more room to tolerate it with. Add in the expected 10% pic improvement from the rumor slide and it should be able to best Arrow Lake too.
Reactions: Tlh97 and DavidC1
511
5,118
4,605
Yeah but not anymore going forward the private alley is going away 2P people have to share 😂.
Atoms are good wrt perf@mm^2.
But that's CPU, at least Intel has a roadmap there.
GPU anything, especially GPGPU is lol.
If only they weren't a bunch of idiot in Intel DC GPU space not cancelling everything.
Why is it not that's1MB increase for 1 Cycle Skymont is 19 Cycles 4MB L2.
Their Heydey died with 10nm delays lol.
