Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 766 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
762
718
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
Doug S
3,216
5,523
How does SOCAMM address this problem? It looks like it it provides more bandwidth than LPCAMM can.
What do you base that on? I haven't seen any bandwidth comparisons, and since they have a similar number of pins I can't imagine the bandwidth would be all that different.
The main thing this is doing is completely screwing the chances of LPCAMM going anywhere. With two incompatible standards it will be easier for companies to skip both and continue soldering down LPDDR. Thanks for nothing, Jensen!
adroc_thurston
5,869
8,212
One is DC, one is client tho.
SOCAMM is just an attempt to make 6400 Grace SKUs actually field servicable.
Reactions: 511
Sep 5, 2022
34
73
61
From what I read SOCAMM has more I/O ports compared to LPCAMM. It has 694 I/O ports, more than LPCAMM's 644 I/O ports. There’s also supposed to be denser electrical wiring on the substrate module to connect the memory chips on substrate to the motherboard of the GB300. Nvidia is working with all 3 memory manufacturers(Micron, SK Hynix, Samsung) to make it a standard. It’s only a matter of time before JEDEC adopts it as a standard for everyone.
AMDK11
453
367
The LionCove core itself is a reset if we are to strictly adhere to Intel's tradition in this matter.
It is a bit strange that the C&C analyses show that the predictor is also lame in some respects compared to RaptorCove, even though Intel claims that this part is 8x larger in some respects (whatever that means).
17,546
I think Lion Cove was designed from the start for hyperthreading but they ran out of time to validate it and it was probably causing up to 8% lower ST performance in games so they decided to ditch it. Remember, Raptor Lake Refresh wasn't even supposed to exist. It should've been MTL-S, followed by ARL-S but their MTL-S experiment turned out really bad which impacted everything later on. It's super ironic that they call AMD a copycat but they ruined their consumer chips trying to copy AMD chiplet strategy. Should've kept mobile chips on chiplets and desktop chips monolithic.
511
2,498
2,309
HT doesn't affect ST Performance also they Messed up the chiplet fabric hence the issue with MTL-S/ARL-S.
Chiplets are inevitable as for issues look at how AMD had issues with Ryzen Chiplets initially they were using Inferior chiplet Architecture to intel.
17,546
That's true but even Nvidia isn't getting into chiplets at the moment. Intel was arrogant enough to think that they could mimic AMD without any major issues. This is something Pat should've looked into and prevented them from doing.
Go slow and steady when embracing new manufacturing technologies. I thought that was established wisdom at Intel. Getting into chiplets with a brand new architecture, well, it's a miracle that ARL-S isn't much worse off than it already is. Gotta give Intel engineers that, though.
511
2,498
2,309
This is before pat Sapphire Rapids/Ponte Vehicco are Chiplets.
This time the Chiplet is not the issue as I have said before it is L3/NOC.
It was never also if it was established practice at Intel we wouldn't have any of the major innovations with nodes.
Reactions: DavidC1
DavidC1
1,546
2,546
It's brain drain that impacted them from doing anything right. They didn't/don't have the right people/team to do their jobs. Also, Meteorlake issues were way before Pat. It was impacted by 6+ month delay on 7nm.
Lack of brainpower and chaos within the company is what caused Arrowlake issues.
Nothing would work well in that case, monolithic or not.
Intel was the leader in implementing the newest memory technologies and at fastest speeds. They led the world in density, frequency, and latency with SRAM. The Itanium 2 chip had massive 3MB L3 cache with a surprisingly high density and low latency.
Their designs were deficient even back then, but the implementation was solid. Mediocre design was made up by stellar process technology and excellent implementation.
Those guys are at Apple, AMD, and various other chip teams now.
Raptorlake itself wasn't supposed to exist. It was supposed to be Alder and then Meteor.
DavidC1
1,546
2,546
SOCAMM seems to be higher cost than LPCAMM, and that comes with better specs, but it's really slotting between HBM and regular DDR memory.
You are still sacrificing performance with SOCAMM, since HBM is much higher bandwidth but you can't beat having multitudes of higher capacity either.
poke01
3,535
4,861
99.99% of these issues will be fixed with Nova Lake.
17,546
Unless huge changes to a positive way is happening now, it won't be "fixed" for another 5 years on top of that.
The only thing they need to fix is the RAM latency and probably add a faster L3 with lower latency or reduce the L3 size to make it smaller/faster and add a larger L4 cache. 245K and 265K are pretty good for the price. 285K is kind of broken as it doesn't offer that much for the price bump.
511
2,498
2,309
265K was just $10 more expensive than than 245K few days ago 🤣
DavidC1
1,546
2,546
They need *significant* reductions to get a noticeable improvement, which won't happen without better engineering.
I can believe being better by the time Nova Lake is out, but I wouldn't bet on being back to pre-2014 levels of leadership.
Krteq
1,005
713
Yep, Panther Lake is officially "rescheduled" for 2026
