Page 765 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
919
834
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
jpiniero
17,006
7,406
I recall someone on this thread proclaiming that Intel's introduction of parts incompatible with AVX-512 would be a trump card for Intel, because Intel's bigger market share would instantly make the incompatible part some sort of industry standard.
That was the height of "cope" logic.
Thankfully, Intel dropped that insanity today...
I wouldn't end up being surprised that ends up not being the case and client doesn't have AVX10 either.
511
5,118
4,605
Client has AVX10 Confirmed by Intel Principal Engineer also this info is public next client will support APX+AVX 10
511
5,118
4,605
I had kind of assumed that was the AVX10 256-bit though. Which is now gone.
Which means there is only 512 BIT Vector in AVX 10 and I think they are doing Zen 4 like AVX-512 in Arctic wolf and full AVX-512 in P cores
DavidC1
2,021
3,157
Now is this a problem on AMD Side or LPCAMM side we don't know
Neither.
When you are dealing with 1mm2 being a big difference, you are inevitably sacrificing signal integrity when making a module that is user replaceable. User replaceable memory CANNOT have the same signal integrity as a soldered down one, it's physically not possible.
poke01
4,606
5,916
Neither.
How does SOCAMM address this problem? It looks like it it provides more bandwidth than LPCAMM can.
jpiniero
17,006
7,406
What I was implying was the idea that the E cores do not support AVX10's 512-bit mode, only 256-bit. Which is now gone.
Reactions: 511
19,203
Shouldn't be too much problem for Intel to implement what AMD is doing with Zen 5c. Their E-core team is clearly superior in intellect.
TESKATLIPOKA
2,696
3,260
No but it is not rocket science given the die sizes and additional requirements on the Motherboard
But that's only the production cost. It doesn't say anything about how much Intel or AMD is asking for those chips and how will the OEMs price those laptops in the end. So we still don't know how much more expensive Strix Halo laptop is compared to a Panther Lake laptop.
According to notebookcheck(Link)
RX 8060S is 177% faster than ARC 140T in Cyberpunk at Full HD.
Even If Panther Lake provided 50% boost, Strix Halo would still be 85% faster.
So Panther Lake shouldn't cost more than 1350euro, or It would have worse gaming perf/€ than Asus Rog Flow(2509€ in my country), which already has bad perf/€ vs CPU+dGPUs.
Reactions: Joe NYC
GTracing
478
1,114
I'm pretty sure AVX10 256bit is still valid. Are you thinking of how they ditched the 128bit version?
Edit: Ah, nevermind. Apparently this with the past week. Intel's AVX10.2 white paper no longer mentions a 256bit version.
MS_AT
913
1,830
128b, 256b, 512b are all valid. The difference is before the latest change you could have a CPU that stopped at 256b and was not supporting 512b. With the new change every CPU claiming to support AVX10.2 has to be able to execute 512b ops so you don't need to have 2 binaries. But you can still write code that targets lower register widths.
511
5,118
4,605
It will still be proportional to the amount it cost to make them will it not ?
Yeah sure Strix Halo is indeed gonna be faster but how much cause Cyberpunk is CPU heavy in the same link a 285H with 140T is better than a Lunar Lake Arc 140V while 140V is clearly better in terms of architecture and it's HW capabilities.
I would say Halo would be 50-70% faster than the Xe3 iGPU
