Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 764 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
762
718
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
Ghostsonplanets
774
1,228
Indeed it does!
WCL is the designated poverty part, after all (and a good one at that).
Huh. Surprising to see you any bit interested into an upcoming Intel product. Last time was Lunar Lake (And you were correct it would be the only meaningful part of the whole Arrow Lake Core 200 line-up).
But I can understand. Finally replacing RPL-U (cost structure) and ADL-N while being a very small or "poverty", as you say, SKU. Should be Intel volume driver for Mobile.
adroc_thurston
5,855
8,180
A good product is a good product, Intel just kinda sucks at making them.
Indeed, fresh new IP and a good cost target.
What the market needs above all.
Reactions: Ghostsonplanets
511
2,447
2,229
So you don't know what will be the price of Panther Lake.
No but it is not rocket science given the die sizes and additional requirements on the Motherboard
With 3050-3060 performance it is not touching the Strix Halo, let alone Medusa Halo.
Doesn't matter how much more powerful it will be. PTL-H is going to be 128 bit bus, and only 1536 ALU GPU. Yes, it will beat, most likely, Strix Point and Medusa point, but it doesn't change that fact that it is competing in the same, mainstream market.
It is not and never going to be the Halo competition.
It will not beat the top strix halo let alone Medusa halo but Nova Lake Halo will
Magio
118
124
Has there been such a thing as a NVL Halo chip rumored? I know there's that massive CPU (16P 32E), but I haven't heard anything about a huge iGPU in NVL, have I missed something?
511
2,447
2,229
Yes NVL Mobile Halo exists it will use Xe3/Xe3P I am not sure which one to be precise but it's a halo platform from Intel for mobile.
Gideon
2,012
4,989
512 Bit Vectors on E-Cores this means AVX-512 on arctic Wolf in Nova Lake
Thats honestly awesome news!
.... but in that case how does it differ from AVX-512 (besides marketing speak)?
I guess it has Version based enumeration and apparently some new data movement and transform instructions (but AVX-512 has had lots of instructions added over its life cycle). So seems kinda a useless marketing renaminig
511
2,447
2,229
I mean yeah the marketing name probably the same guy that named SSE Version it says in the image new instructions and version base checking instead of flag based vs AVX-512 I guess on e core it will be double pumped AVX-512 like on zen4 which is fine imo
LightningZ71
2,246
2,764
Reading the article just makes it sounds like AVX 10.x is just the next revision to AVX-512 and not some whole new approach. I don't this absolutely requires everything in the 'mont cores to be fully 512bits as they can still use the doubled 256 approach that's been used in other solutions in the past. This is what I most expect from them, just absolutely minimal circuitry effort to bring up the capability to keep the instruction universe homogeneous across the core types.
AcrosTinus
191
193
First they dropped 128 bit support, now 256 bits - which is fine, but what's the point of AVX 10.x now when it's more or less AVX512 then?
It might be part of their de-risking approach. While a team was working on the spec the other was working on the arch and depending on how feasible the full implementation is, the spec will adapt to allow this. My inference is that they had lower confidence in the cpu-arch team and left them wiggle room, now things are looking good, hopefully.
511
2,447
2,229
AMD did the same thing Intel took the bullet for AVX-512 initially and after like 6-7 years did AMD introduced it in their CPUs
Glo.
5,930
4,991
I don't know that lol the only thing I know is that it exists MLID will leak if it exists or not he is only correct about names and stuff so I will give him that
How can you know that Nova Lake will beat Medusa Halo, if you have no clue how many Xe cores it has, in the first place?
Doug S
3,205
5,498
The biggest difference is that they won't have to rename it if they ever add support for 1024 bit vectors ;)
moinmoin
5,218
8,407
Since Intel tended to ignore AMD's input Intel usually has to "take the bullet" for new development and AMD has to follow eventually to not end up with incompatible chips.
But this evolution of AVX10 to go back to 512bit only may be a result of Intel and AMD wanting to work on aligning both companies more regarding future x86 development.
Reactions: Joe NYC
Joe NYC
3,120
4,539
I recall someone on this thread proclaiming that Intel's introduction of parts incompatible with AVX-512 would be a trump card for Intel, because Intel's bigger market share would instantly make the incompatible part some sort of industry standard.
That was the height of "cope" logic.
Thankfully, Intel dropped that insanity today...
