Page 762 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
919
834
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
Hulk
3,857
Remember the good old days when Intel didn't constantly update us on process status? They just put the product on the shelves and let it speak for itself.
18A status update #23 "launches" Q2 '25...
Does anybody remember Intel 20A, now THAT was a good launch.
Sorry, I AM an Intel fan. I just want them to DO something meaningful. Although the Battlemage release was meaningful I must admit. Just no volume.
5,118
4,605
Does anybody Intel 20A, now THAT was a good launch.
That was a different Intel I think after BK there were constant delays and stuff for almost everything
19,203
Am I reading Q1 2026 wrong? Does that mean no H2025 Launch
At least there should be a nice Core Ultra 300 launch by Q42025.
Intel can save some face by launching 4P+32E halo part for the rendering/video encoding/workstation crowd. That would catch AMD off-guard for sure, unless AMD has a similar design ready with Zen5c and they can ramp up volume in a matter of months.
511
5,118
4,605
Not happening I wonder how powerful Nova Lake will be though it's got 16+32+4 Config
19,203
Not happening
I wouldn't bet on that.
They got him to invest his own money in Intel shares so he will try his best to put something competitive out ASAP otherwise he stands to lose a lot.
Even something as simple as bringing back HT in Arrow Lake (assuming it's just fused off) and AVX-512 (maybe re-using the server compute tile in consumer) could be huge things that would improve the value proposition of Intel's CPU line-up and competitiveness.
jdubs03
1,343
942
Agreed. And yeah that’s definitely a good motivator when you’re helming a company that is in the doldrums.
511
5,118
4,605
EPYC is ahead in performance because Xeon is power constrained.
Given enough power P core should easily surpass zen core, albeit lacking in efficiency.
The P cores are not efficient Yes that is true but this is per core performance I doubt it's power constrained
Ghostsonplanets
774
1,228
and how are they achieving that with limited bandwidth. more cache?
Aside from what everyone else said, PTL-H iGPU is also 50% wider than ARL-H Xe LPG and LNL Xe² LPG.
IMO:
PTL - H 12Xe³ - New iGP performance class
PTL - U 4/6Xe³ - =<~ MTL-H performance class
WCL - 2Xe³ - ~= MTL-U performance
511
5,118
4,605
For 12Xe3 we have many Improvements also there is clear PPA Improvement as well vs Xe2 here are all the changes that have been leaked.
> 2X iGPU cache
> 20% Clock Speed Improvement
> 1.5X the Xe Cores
> Major Improvements to the Arch with Xe3
> Size Increase of iGPU die from 39mm2 N3B to 54mm2 N3E(N3B is denser in SRAM and Logic vs N3E)
> Variable register allocation
> New Xe Slice organization with 6 Xe3 Cores
Did I miss something?
Ghostsonplanets
774
1,228
> 2X iGPU cache
> 1.5X the Xe Cores
Outside of sub-triangle opacity culling for better RTRT, no.
Where was the tile size of 12Xe³ shared? That's quite the increase in area dedicated for graphics.
511
5,118
4,605
If they add major changes with Xe3 than this area increase is justified example a 12 Xe2 would be slightly larger than 60mm2 N3B(considering the fact that the graphic tile consists of exclusively the cores and the caches)
Ghostsonplanets
774
1,228
Thank you!
I'm certainly interested in how Intel will improve PPA with PTH/WCL Celestial.
Battlemage already was a massive improvement with a 20 Xe² die being faster than a ACM 32 Xe die. And Lunar Lake was already very toe to toe with Ryzen AI HX 390 at lower TDP.
Perhaps we'll see the first performance leap from Intel over AMD on IGP space?
Reactions: Tlh97 and DKR
511
5,118
4,605
Thank you!
The area efficiency sucks for battlemage sucks as a dGPU though they improve that as well with celestial and for second part strix halo exits but it is damm expensive vs Panther Lake also this new feature I found on the web 🤣
