Page 674 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
919
834
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
5,118
4,605
You don't need a die shot. You only need a shot of the package. You find the size of the LGA7529 package. The actual shot shows having 3x narrow dies. The narrowness is because the dies are right next to each other like on Meteorlake. Each narrow die is actually 4 of them. You find the size of the narrow geometry, and divide by 4.
It's possible 4 of the dies are connected by Foveros, and connection to another of the quad die groups are done using EMIB. Then again, SPR is using EMIB only and it's pretty close between the dies.
The thing is the 18A dies are under the Intel 3 dies and they are distant apart from the initial diagram each die has distance between them which will slice the area same issue as Zen5X3D
Same with how I got Turin Dense Zen 5c's size. You get the package size, and measure the die. There's a clear separation between core and L2 for AMD, so it's even easier to find core size only.
Amd it is easy due to dies are Visible
Saylick
4,099
9,578
Don't you mean the 18A compute tiles are ABOVE the Intel 3 base dies?
Reactions: DavidC1
Kocicak
1,177
1,232
If you had multiple defective cpu either you are getting wrong CPUs constantly or there somewhere something in MB causing issues my advice would be cap IA voltage to around 1.45V or maybe 1.5V depending on the desired frequency it will prevent degradation altogether on new cpu
He used the CPU for a few months without any limits - IMO 90% of the damage happened in that period.
Also 5500 MHz is not a "chip friendly" frequency at all. I think I wrote this ten times already - the process Intel uses to make these chips is not up to such high frequencies.
5,118
4,605
Also 5500 MHz is not a "chip friendly" frequency at all. I think I wrote that ten times already - the process Intel uses to make these chips is not up to such high frequencies.
Frequency doesn't matter voltage does cause it is a function of voltage itself
Reactions: lightmanek
Gideon
2,041
5,084
When Zen 5 desktop parts were launched it was a disaster requiring some agesa bios updates and windows 24H2 patches. Same like ARL now requires similar bios updates & possible windows patches.
Looks like some have either forgotten about it already or just want to ignore it.
Apparently, it was okay to wait for amd’s patches, but not now for Intel’s.
Your clear bias is showing here, despite calling you out already.
Every major launch has benefited from BIOS updates, windows scheduler changes and new chipset drivers. None has had issues with worse average performance than the predecessor without them.
Zen 5 was consistently better than Zen 4. Even in gaming, whether it was 3-5% faster on average (not slower as intel). Windows 24H2 patches also screwed Zen 4 (since time memorial it turned out, an issue AMD also should have caught)
511
5,118
4,605
Is there a thread for something like laptop CPUs thermal paste application ?
Hulk
3,862
Hey, maybe the CPU tries to compensate for the lack of power by overperforming in ST with higher than normal boosts since it isn't allowed to flex its muscles MT-wise? Definitely seems like some sort of boosting algo designed to win benchmarks in the short term.
Frequency capped at 5.5/4.4 on the 2nd one to avoid requests for ridiculous voltage.
Hulk
3,862
They significantly improved the FP performance full fat AVX-512 with more units to feed
Capped voltage at 1.3 on the 2nd sample. Lasted longer but still failed eventually.
Reactions: 511
511
5,118
4,605
Why are there two sets of the apparent same tests with different results? Is one MT? Are all clocks set the same? I'm confused as what to make of this.
One is fixed clock and th other is at stock clock
511
5,118
4,605
If it’s the same as the 9800x3d, then the compute tiles are on top, which is what the Intel slide also shows. . .
This one is on me i took the wrong reference but from the die shot it is clear the Intel 3 is the top die while the Cores are below those big dies
