Page 664 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
919
834
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
cannedlake240
247
138
Ehh for one architecture sure but they are Jumping two architecture and one optimization.LNC has 14% ipc over RWC and cougar is 5% more and Panther is another 10-15% it is inline with modern architecture 🙂
Thats still not going to be anywhere near 40-50%, and 5% for cougar is probably too optimistic
Kocicak
1,177
1,232
They are offering a replacement CPU. I'm jumping ship. 14900K is too hard to cool and too prone to degradation for my tastes. I could just run at 4.5GHz and call it a day... but I'm an enthusiast! I can't go out like that.
I was telling you that 5.5 is too much. You will get a lot of perfomance from the new CPU, when you cap it from the beginning at 5 GHz.
If you want, jump ship the next year, when the truly updated AM5 platform is available.
naukkis
1,030
854
10-15% at best should be the expectation for modern architectures. Memory and cache latency on GNR isn't great in HEX mode so if they can sort that out IPC uplift will be greater than Client. If latency can't be lowered at least get the capacity up through 3d stacking...
Intel Panther Cove will bring APX, which basically should give x86 similar performance possibilities than todays ARM. x86 is currently lacking about 50% IPC. If Intel doesn't target that with Panther Cove they are just losing their mind. And when they target that kind of high IPC they pretty much have no other option than drop SMT.
If they change their mind and re-introduce SMT they basically confirm that they have failed all their design targets and have gone to damage limitation mode.
cannedlake240
247
138
Nah anything more than 20% is extremely unlikely. ARM is 4.5Ghz max, way below the 5.7ghz of current x86 chips. They achieve basically the same perf, but the low clock speed approach is more efficient. Intel's experimental Royal core program that was recently canned allegedly targeted much higher IPC
naukkis
1,030
854
So Intel bringing new instruction set architecture targeting performance and you except that they could not extract any performance out of it? Intel should gain that 20% for legacy x64 and have much more from native APX compared to legacy x64.
cannedlake240
247
138
David Huang and Chester from CnC believe that perf improvement from APX will be negligible. Plus it apparently increases instruction length which will make the x86 decoding an even bigger headache
naukkis
1,030
854
It does not cure everything on x86 - but doubling registers will outright reduce loads 10% and stores 20%. X86 with it stupid TSO ordering will greatly benefit from fewer stores. APX also makes possible to reduce branches from code. With those APX code should be equal to ARM at least with cpu designs that have mop cache to remove instruction decoding problems.
dttprofessor
163
45
Quite a few cloud use cases do not require high single-core performance. SRF is sufficient for these applications. No matter how strong the performance of CLW is, it will not cost the cloud more. SRF is sufficient.
Meteor Late
347
382
Eh 5.7GHz is on Desktop, on Laptop there is no 5.7GHz chip because it would consume a massive amount of power for single core. ARM limit is not 4.5GHz, I'm sure M4 can clock a bit higher, 200-300MHz more for sure, at what power cost though I don't know, probably very costly.
Hulk
3,857
You were correct.
What will the updated AM5 add?
Kocicak
1,177
1,232
I have no idea, but I believe it is impossible that AMD ran exactly the same platform for three consecutive years without updating it.
Now is a bad time for jumping ships, the next year you will be able to choose between a fixed CPU for LGA 1851 or even better CPUs for AM5 than are available today.
dttprofessor
163
45
maybe core 285hx(not ultra)5.7g
AcrosTinus
221
226
Well I'll be getting a warranty replacement on my 3rd Raptor CPU shortly. Running on auto "Intel safe" BIOS options with updated Intel microcode BIOS and max clock capped at 5.5GHz. Getting lock ups in Topaz Photo AI. Contacted them and they said check CPU stability Photo AI hits the CPU hard. I said, "Impossible, I'm 100% stable."
Just for kicks I backed max clock down to 4.5GHz and the issues with Photo AI are resolved.
Checked with Intel and based on S/N and batch number they said my CPU is "defective" and will send a new one.
Now the question do I use it or just bail and move to AMD? I want to bail as I'm tired of this. I just hate starting over with Windows from the ground up. But it's gotta happen sooner or later right? I think the writing is on the wall and I have to move on from Intel.
The only AMD mainstream that might be worth it is the 9950X with 3D-VCache to compensate the IO Die and RAM latency. Anything else is too weak, 9800x3D is nice but I am not buying 8 cores in 2024, not going to happen.
And Intel maybe in one of my dreams might implement a 3D cache equivalent, now that the tiles introduce latency and the L3 is quite weak, it might help or just introduce more latency.
I think Intel's strategy might be increasing L3 frequency like they did from Alder to Raptor, reintegrate the IMC into the compute die and introduce a LV4 cache to hide the D2D latency. I don't know how effective that approach might be but it is fair to say that Intel won't be taking any gaming crowns for nearly a decade maybe and frankly I don't care. I am on 4K with a 4070 Ti Super, these bottlenecks don't see me. I buy Intel for the stability *ahemmm* and their chipset, here AMD has to catch up as their chipset is only connected via a 4x lane. Z890 currently has more bandwidth but no real CPUs....
Markfw
May 16, 2002
27,360
16,193
Intel ? Stability ? you are in the wrong universe, see the Raptor lake instability threads
Markfw
May 16, 2002
27,360
16,193
It was a joke, "stability *ahemm*", thought it was on the nose
SORRY !!!! I was commenting based on the rest. The 9800x3d if you are a gamer or 9950x for the test productive would have been my recommendation.
But sorry, this is an Intel thread. No more posts on this from me.
Reactions: AcrosTinus
511
5,118
4,605
Test productivity 😅
No matter how bad 14900K was it was not a regression like ARL was ARL would have been salvageable without the -ve gains it had
