Page 663 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
858
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Hitman928
6,755
12,502
Server the home published SpecInt Performance for SRF/GNR
The difference between the 9965 (Zen5c, 3.7 GHz boost) and the 9755 (Zen5, 4.1 GHz boost) doesn't make any sense to me. This would put GNR roughly even with Zen 5 in "IPC" but both are significantly behind Zen 5c.
Edit: Ahh, I see. STH didn't test it, these are top OEM submitted scores. In other words, not very useful. Also, not 1T results like I thought it was in my head.
511
5,517
4,908
Sadly yes but it is showing both in their best light considering OEMs would have used their best to optimize for the platform also does AMD rates TDP at all core boost or it guarantees only base clock at TDP just like Intel does cause in actual workload clocks maybe been different than official figures under all core workload
GTracing
478
1,114
If that's the case we would need other explanations for why performance in games is low and random.
It's memory and cache latency. A few outlets have tested overclocking the ring bus and tile interconnect and got huge gains.
One example: JayzTwoCents got an 11% increase in Cyberpunk 2077
Reactions: Executor_
Hitman928
6,755
12,502
I was just reading the CNC article on the 9800x3d so in my head the STH results were 1t, but they're not, so my IPC comment with the boost clocks can be dismissed entirely. The problem with using the top OEM results is that they will be using the vendor's compilers (ICX for Intel and AOCC or AMD). These are not used much in the real world (especially AOCC) and even worse, can have specific SPEC cheats built in (Intel just got caught for this by SPEC recently and had a bunch of results invalidated). So, using the top scores isn't very interesting.
For AMD and TDP, the base clock is guaranteed at the rated TDP, though in almost all cases, the actual clock speed will be higher than the base clock, even when all cores are fully engaged.
511
5,517
4,908
Yes i know about that SPEC Dismissed many of their results for SPR but that is the best thing we will ever get unless Wendell or STH does a SpecInt benchmark
DavidC1
2,187
3,340
Reactions: 511
Hulk
4,128
Well I'll be getting a warranty replacement on my 3rd Raptor CPU shortly. Running on auto "Intel safe" BIOS options with updated Intel microcode BIOS and max clock capped at 5.5GHz. Getting lock ups in Topaz Photo AI. Contacted them and they said check CPU stability Photo AI hits the CPU hard. I said, "Impossible, I'm 100% stable."
Just for kicks I backed max clock down to 4.5GHz and the issues with Photo AI are resolved.
Checked with Intel and based on S/N and batch number they said my CPU is "defective" and will send a new one.
Now the question do I use it or just bail and move to AMD? I want to bail as I'm tired of this. I just hate starting over with Windows from the ground up. But it's gotta happen sooner or later right? I think the writing is on the wall and I have to move on from Intel.
Markfw
May 16, 2002
27,410
16,258
That's above Turin 9755. You are quite single minded aren't you?
No, its directly about the ampere. The Turin ends with a 5 , the 2 at the top. Whats the single minded crap ?
Are you commenting in the 6980P ? The Turin's are above that and the 2 Genoas are below. Still not impressed.
But much better than the 2P 6252
jdubs03
1,503
1,094
Are they offering a refund? It’s a tough call imo, because a replacement, which should not be defective, can slot right in.
But, Zen 5 is obviously superior, so I can see how it’d be tempting to pocket a refund and upgrade.
5,517
4,908
Just move away from Intel if the issue persists
alcoholbob
6,390
470
I can't imagine a new CPU would fix your problems as RPL CPUs are destined to degrade no matter what BIOS you use what these kind of suicide voltages. I don't think extended life is possible without heavy undervolting and lowering the AC/DC load lines because these chips come out of the factory boosting to 1.5V or higher which is insane.
If you watch buildzoid's videos you can see most of these 14900Ks can run stable at stock clocks at 1.3V max vcore, if not much lower (mine is running at 1.244V max vcore with AC/DC LL Mode 3 & -160mv offset). Intel's out-of-the-box VID tables are just total trash and are sending these chips into crazy thermal and voltage territory.
Reactions: Tlh97 and KompuKare
Hulk
4,128
They are offering a replacement CPU. I'm jumping ship. 14900K is too hard to cool and too prone to degradation for my tastes. I could just run at 4.5GHz and call it a day... but I'm an enthusiast! I can't go out like that.
DrMrLordX
23,230
13,313
Why the negativity for Rouge river forest it is coming Raichu and Bionic squash has confirmed it on Twitter
There are others claiming it's on the chopping block. Intel is strapped for cash. They're making decisions now (or have already made decisions) that will affect their product lineup for many years in advance, and if that means cutting corners, then there's going to be a direct competition for funding between P-core and E-core Xeons.
and can we stop blaming everything on Gelsinger
He's the CEO, and he's making the decisions. So no, we can't. Even if he's stuck in a bad situation with cash shortages that are a very real cause for concern. What he chooses to keep and what he cuts will have a major impact on how Intel progresses in the future.
How can you say that it is not doing well otherwise Intels DC revenue would not be 9% up they are due to SRF/GNR there is no other way for it to go up
They're in an overall growth market. Their competition is surging ahead while Intel lags badly, and their margins in the last quarter were quite bad.
Reactions: moinmoin
cannedlake240
247
138
They do have a few bright points on the roadmap, the 288C CLF and Diamond Rapids should narrow the gap with AMD even further. After that it depends if they've made progress in cpu core design and AI chips. If the foundry achieves break even, that's half their problems solved in near term
511
5,517
4,908
Others can claim but it is the last thing that should be on chopping block, maybe they are axing lower SKUs like the 144C SRF and moving forward with a common platform with DMR.
Unless some reliable leaker gives a leak i am not holding my breath for RRF Chopping
Even for bad decision his predecessor made for Lisa su she had her work cut out she didn't have to deal with foundry besides they are short on cash though she only had to get design together
Yes but there are improvement let's be real Xeon is their Saving Grace in AI not Gaudi and also Falcon shores will tell whether they can make a competent GPU or not
cannedlake240
247
138
We went over Clearwater Forest already, but hey maybe Diamond Rapids has something good to offer.
Yeah unlike Granite, Diamond isn't stuck with a last gen core and process node. Apparently it has no SMT support which is a major downside. Core counts unknown
cannedlake240
247
138
Isn't that reddit user making the claim one of the more reliable and well known in the rumor mill though? Pat expressed this sentiment twice already, once saying that Forest line sales in the foreseeable future will continue to be lower than P core Xeon
DavidC1
2,187
3,340
What the heck are you talking about?
Epyc 9755 gets slightly lower than 1300. The "previous generation 96 core" which is 9654 gets ~900.
If SRF-AP gets 1300 only 9965 will be faster in SpecInt_Rate. Biases are clouding your viewpoint.
511
5,517
4,908
DMR has SMT lol also considering it will be Two Tocks and 1 Tick it better be 40-50% Ipc 🤣
RWC+ -> Lion Cove -> Cougar Cove -> Panther Cove
cannedlake240
247
138
10-15% at best should be the expectation for modern architectures. Memory and cache latency on GNR isn't great in HEX mode so if they can sort that out IPC uplift will be greater than Client. If latency can't be lowered at least get the capacity up through 3d stacking...
511
5,517
4,908
Ehh for one architecture sure but they are Jumping two architecture and one optimization.LNC has 14% ipc over RWC and cougar is 5% more and Panther is another 10-15% it is inline with modern architecture 🙂
