Page 386 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
919
834
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
AcrosTinus
221
226
Lol, it s documented by CPU Z themselves, they explained the "reasons" for such a downgrade after they revised the 1.73 version wich was released in december 2016 and "updated" in may 2017 after they noticed the surprisingly good score of the 1800X.
They updated their bench due to the score misrepresenting the actual performance. Zen1 is slower than SKL a bench showing otherwise would not be the intentions of the authors, so they corrected it.
AcrosTinus
221
226
Possibly. But I just ran the same version with a 13900HX w.r.t 12900K & 13900K and the results were inline with expectations. Might translate well for ARL too. So, I don't think we should label it as totally worthless already.
The most important question we should be asking now is, whether it's altered using photoshop. Is there anyone who can analyze it?
I think so too. But first we need to find out whether it's real or digitally altered.
True :)
DrMrLordX
23,114
13,215
Yes, that is why I say that for comparisons of Intel CPUs it is alright
That is debatable. CPU-z benchmark clearly has something wrong with it. We went through this with Dr. Cutress' 3DPM benchmark when it was found that repeated cache flushing caused the benchmark to heavily favor Intel CPUs with HT on over anything else. It wasn't even a really good tool for comparing Intel CPUs vs other Intel CPUs since the results were so skewed. Arrow Lake-S would probably suffer badly under 3DPM v1.
In any case that screenie might be a fake, and it's an already-sketchy benchmark, so let's not make too much of it.
CouncilorIrissa
765
2,782
I'm sure the benchmark that fits entirely into the L1 of any modern CPU and practically does not stress the branch predictor is totally representative of all possible workloads.
After all, it's not like pretty much any new CPU microarchitecture presentation contains slides containing words such as "Improved branch prediction". Totally not Apple's most recent presentation. Nor ARM's. Nor AMD's even. Nor Intel's. Companies are just investing transistors into this for lolz.
AcrosTinus
221
226
Fair
AcrosTinus
221
226
All I'm advocating for is that the term "real world workload" is nothing more than an approximation itself that no benchmark can justify. An aggregate of different benches come closer to representing reality, hence CPU-Z has it's place.
I know CPU-Z is not heavy on the branch predictor but many apps are.
AcrosTinus
221
226
Ignoring everything else I said. How would you like to be on a 4C or 6C CPU today with HT as a ~$100 add on?
I do not indulge in hypotheticals that did not happen. Fact is that 8 core Zen1 was defeated by Coffee Lake as a response (6C/12T). If I remember correctly people were excusing AMD due to better NT performance in that period the same way people excuse Intel for better NT against 7800x3D.
Hail The Brain Slug
3,889
3,329
I am right, the bench showed nearly zero IPC gain (CPU-Z), the performance increase in CPU-Z was due to clocks. I think other benches on average showed 10% or 13% increase from Zen3 to Zen4 or is that wrong ?
Until CPU-z corrects the design of its benchmark to respect the CPPC scheduling of Ryzen, the results will be a wildcard because it always forces to core 0, which could be any random quality core boosting to any unknown frequency below or up to max singlethread boost.
Comparing any two samples of Ryzen will give you unpredictable results due to this.
Comparing Ryzen ST results to intel is also disingenuous because it will schedule properly on Intel to the fastest core.
AcrosTinus
221
226
*Sniff* Sniff* I smell WCCFTech...
Hmm, that's a very, very kind way of putting it.
Nice passive aggressive response.
CPU-Z showed no increase in IPC, In aggregate other benches showed 13% increase in IPC from Zen3 to Zen4. If anything I am saying is false, just respond and correct me.
Reactions: Henry swagger
DavidC1
2,021
3,157
Let's call spade a spade. CPU-Z is for information, and the benchmark is for laughs. It's the AFV of benchmarking. They decided to get onto a different bandwagon and couldn't be some boring "information provider" anymore.
"Passive aggressive" What is this, Psychology 101 class?
We are ALL telling you CPU-Z sucks. It's a laughingstock. The burden is on YOU to prove that it's a good benchmark.
AcrosTinus
221
226
Interesting, where can I read about this scheduling issue in CPU-Z ?
Hail The Brain Slug
3,889
3,329
I am telling you as someone who is in possession of multiple generations of Ryzen and Intel systems I have verified this for myself. In fact, I re-verified it just a week or two ago on the latest OS/driver/CPU-z versions to make sure it wasn't fixed.
Attempts to correct the affinity for Ryzen are not fruitful, the benchmark does a sequence of MT then ST, and even if you set affinity during the MT portion it will force it back to core 0 when ST begins.
I have attempted to use Process Lasso to automate the affinity but it doesn't give a good result due to taking some time after the ST bench has begun (and run for some time on a slower core) before it corrects affinity, providing still artificially low scores.
AcrosTinus
221
226
It is passive aggressive. If you want to dismiss a product as a laughingstock, present the evidence, you have to prove the positive otherwise we can just have differing opinions, I don't subscribe to a default negative opinion.
Thunder 57
4,206
6,995
Chips & Cheese provided the evidence. You just seem to ignore it or say its "50% crap". Not smart for a new member if they want to gain anyones respect.
AcrosTinus
221
226
So then maybe SPEC?
OK well now you are just being disingenuous because Zen 2 was around just after. Sure CFL (AKA SKL) beat Zen in some areas. But like I said it made 8 core CPU's cost way less than $1000+. What are you trying to prove?
Yes, SPEC is great.
I am trying to prove nothing, I just made the claim that SKL is faster than Zen1 and you want me to somehow praise AMD for competing and making CPUs cheaper after a decade of shame ? , well good for them.
Another hypothetical if their bulldozer succeeded wouldn't we have cheaper CPUs earlier ? The opposite is true as well, due to AMD failure to compete 4C CPUs were sold for a long time.
AcrosTinus
221
226
Chips & Cheese provided the evidence. You just seem to ignore it or say its "50% crap". Not smart for a new member.
I did not say that it is crap, I only call 50% BS on the reasoning that CPU-Z should be totally dismissed due to the instructions mix and how branch light it is. That is all. I think all benches have their place, just put the appropriate weights on it while calculating performance increase.
Hulk
3,862
Lion Cove in ARL will show +14% to a max of +19% average IPC increase over Raptor Cove, with the likely number being about +16%.
Forget about the leaks. Intel already detailed 95% of the changes for Lion Cove when they previewed Lunar Lake. We know about all of the big, important architectural changes. As we have been discussing there will be some minor memory subsystem changes that may results in a few percent increase.
We also know all about the IPC increase of Skymont. The things I'm wondering about now are if ARL will have HT (doubtful in my opinion) and what the all-core frequencies for Lion Cove and Skymont in ARL will turn out to be.
This is actually a nuanced question. For example, the nT frequencies for the 14900K are 5.7GHz and 4.4GHz. The 4.4GHz is kind of realistic but 4.3GHz is a safer day-to-day use bet. 5.7GHz with HT on is ridiculous. You'll need a custom loop, crazy volts, and it'll be over 300W. That's nuts. The "real" specs for the 14900K are more like 5.5/4.3.
So with this in mind if Arrow Lake is specified at 5.4/4.5 all-core and that works with air cooling and reasonable volts and power, say 210W that would be okay. On the other hand if that is 290W and a custom loop then I call BS on the rating. We shall see.
Reactions: CouncilorIrissa
H433x0n
1,224
1,606
Holy cow. This thread turned into a mess really fast and devolved into the usual conspiracy drivel.
The performance of ARL-S is more or less known. There are Intel NDA overclocking guides that have already been given to partners and tons of ES samples in the wild. There’s no data to suggest a +20% 1T performance increase. Hype it at your own peril.
poke01
4,606
5,916
We should ban CPU-Z results, what a waste of time.
Like what does that benchmark even tell you?
FlameTail
4,384
2,762
Forgive me if this question sounds stupid...
So in a desktop motherboard, there is the "Processor" and the "Chipset", as shown in the above diagram.
Is this true for laptop motherboards too? My understanding is that in laptops, the Chipset and Processor are integrated into one SoC. Is that so?
Bouowmx
1,150
553
Except for the HX series, the chipset is moved on-package (regular MCM)
