Page 347 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
921
835
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
Wolverine2349
525
179
86
Some updates from my source:
  • the core in ARL is slightly beefier. Beside higher clock speed, L2 cache is 3MB (vs 2.5MB on LNL). The e-core is on the Ringbus, so gets access to L3. Of course, it is still 4-tile design vs 2 tiles of LNL, memory controller is inside the SoC tile.
  • Next year, Intel might not launch the 8+32 version of ARL-S. It was in the roadmap before, now no more...
  • The reason might be Intel has to increase the TOPS of NPU to 40 due to Microsoft's mandate requirements. My source can't confirm which process new SoC tile is being fabbed.
It is early leaks, I will update if anything new come up.
So wait its a 4 tile design Arrow Lake and not 2? Does this mean not all Lion Cove and Skymont cores are in the same Tile unlike Lunar Lake andd Meteor Lake where they are excpet separate tile in MTL for low power e-core?
Or are all CPU core for Arrow Lake in same tile for best core to core latency?
Ghostsonplanets
774
1,228
Yes. Arrow Lake inherits the same tile structure as Meteor Lake. GPU tile, SoC tile, Compute tile, IO tile and Foveros 3D base tile. But some of the tiles are updated/tweaked a bit when compared to MTL.
Lion Cove and Skymont are all on the same Compute Tile in Arrow Lake. It's the same structure as Meteor Lake Compute Tile.
There should be no LPE Cores for ARL-S. It's one of the tweaks made to the SoC tile from MTL to ARL-S.
Wolverine2349
525
179
86
What are the 4 tiles for then?
Is the ring bus with the P and e-cores on a single tile?
And what are the other 3 tiles?
And how does it compare to Raptor Lake and Alder Lake which have a ring bus with P and e-cores and also more?
So is that why latency will be worse with Arrow Lake than Raptor and prior because tiles only have ring bus where as all is on ring in RPL but separated by tiles for IMC and other parts for Arrow Lake?
Kind of like how AMD has a single ring bus in a CCX within a CCD, but they have separate CDs and IO die for infinity fabric and such which is why AMD latency is worse going to than components than Intel Raptor Lake which has all in ring bus?
Ghostsonplanets
774
1,228
Because ARL PoR was to reuse MTL tiled structure to cheapen development costs. But MTL went too hard into tiled design and ARL sadly inherit the same structure.
Future generation will use less tiles.
Yes. It's the same structure as Meteor Lake Compute Tile. Give a look at it.
The same as I said it: Arc Alchemist 64 XVE GPU Tile, SoC tile and IO tile.
Latency will be higher because compute tile will need to communicate through the IOSF. The example you gave about AMD inter CCX communication latency is a decent one.
Hulk
3,862
I just noticed that the slide showing Skymont outperforming Raptor Cove by 2% in "general software" there is a little note reading "when on the LLC ring."
So Skymonts in LL are not Raptor Coves. But they will be in ARL.
Wolverine2349
525
179
86
Have looked at it and its core to core latency while not bad is not great either even within same tile and not near as consistent as the core to core latency between P cores and threads in ALder Lake and Raptor Lake and Comet Lake. There is some latency increase going to e-cores though
Where as AMD has excellent and very consistent low latency between cores with a single 8 core CCX. Though the latency is beyond horrible when it exits the CCX but superior within it for AMD.
Tigerick
921
835
Can't they just use the new N4P GPU tile of Arrow Lake H to give the necessary TOPs for ARL-S Refresh next year?
The ARL H IGP tile brings back XMX while also clocking higher. Pretty sure it would be able to match the 40 TOPs requirement easily (Although the problem I think is that Desktop get a 64 XVE iGP while ARL H one is 128 XVE. So that's an area and cost increase either way).
I thought MS's mandate TOPS requirement is reside inside NPU due to battery life concerns. Thus, GPU and CPU's TOPS does not count.
Ghostsonplanets
774
1,228
Yes. But that's irrelevant for ARL-S, no? Intel can meet the TOPs requirement just fine with the GPU itself as there's no battery life concern in DT. So I don't understand why 8+32 being cancelled might have been something due to pressure of NPU width increase.
Unless it's a byfactor of ARL-H and S sharing the same SoC tile. That would explain a increase in NPU area affecting DT Core configuration plans.
lightisgood
250
121
86
Thanks. I was just thinking this point.
IMO, the capacity of Intel 3 is mainly filled by Xeon 6.
Granite Rapids-AP has really big tile...
So, ARL's Soc tile should be fabbed by the similar LNL process.
Joe NYC
3,954
5,485
Arrow Lake should be around 20% faster than Raptor Cove for single core stuff. That is more than enough to beat Zen 5 in many benchmarks.
I have a hunch hat it will go the other direction. Taking just one variable, memory latency and some round numbers:
MTL P-Core to LNL P-Core = +14%
(given from the presentation)
This transition improves latency since memory controller is on the same die in LNL (and also SLC). Let's say, memory latency improvement buys 4%, then excluding the memory latency improvement, core for core is 10%.
RPL P-Core to ARL P-Core = ?
If we start with core for core improvement of 10%
Going from monolithic RPL to tile based ARL, we lose 4%
Then,
RPL P-Core to ARL P-Core = 10% - 4% = 6% IPC gain
H433x0n
1,224
1,606
Then,
You’re deducting memory latency twice. You’re also ignoring that desktop will have less latency than MTL’s Redwood Cove and LNL from the ability to run higher ring clocks and a desktop oriented SoC tile that doesn’t have to worry about idle power draw and gets rid of things like LP ecores. Finally, there is an additional amount of L2$ for the ARL-S variant of Lion Cove.
It’s a moot point anyway when you consider the competitive environment. It could end up at 0% improvement overall and still be competitive. RPL already had 10-15% 1T advantage in the popular benchmarks to measure client 1T performance. They got completely let off the hook.
Joe NYC
3,954
5,485
That's correct:
Good -> Good = 0
Bad -> Bad = 0
Bad -> Good = +1 (MTL -> LNL)
Good -> Bad = -1 (RPL -> ARL)
Difference between (Bad -> Good) - (Good -> Bad) = 1 - (-1) = 2
Clearly, there are other variable, but my point was to analyze only 1 of many variables.
Also, only looking only at Intel side, at 2 transitions of Intel processors. Not looking at AMD.
Hulk
3,862
Actually, one of the lunar lake lead architects mentioned that the GPU also has access to Memory Side Cache (but doesn't have much priority like E core cluster).
Is the memory side cache the 8MB "mystery cache?"
