Page 335 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
I would suggest watching the High Yield video. Skymont looks like an absolute beast. It looks like you can still fit 3x Skymonts in the area of a single Lion Cove.
Shame that so much of the die is eaten up by this new NPU. I would have preferred to rather spend that die area on another 4 Skymonts and making the iGPU a bit bigger but the AI NPU wars cannot be stopped at this point.
When Intel starts spamming these new Skymonts (or future mont cores) in huge numbers, it should lead to some ridiculous MT performance and PPW.
Seriously? This thread is getting way ahead of itself. I thought I saw leaks that Zen 5 will have similar clocks, and dont forget ARL is giving up hyperthreading, so the E cores better be really good. ARL will still have to have a really good IPC increase for the P cores to beat Zen 5.
LNL's implementation of LNC will not have HT but HT versions of LNC absolutely do exist. It isn't yet known if ARL has HT or not.
Does anyone else thinks that 15% IPC gain of Lion Cove is quite poor given all the changes in the core? They beefed up every part of the core, separated int and float, scalar int mul throughput is up 3x, new cache structure,.. Sounds almost like Intel is sandbagging and the gains in some benchmarks should be much larger.
Lunar Lake vs. Meteor - Lion Cove performance uplift over Redwood Cove drops to around 10% near the end of the power curve. Against Raptor Cove it would a bit lower still, not at the same power though. The main benefits are at lower clocks, where we get 18%+ performance, Raptor Cove would probably look silly here.
Looks to me like we're finally going to get a chip optimized for low power. I wonder how much of this is influenced by the TSMC node.
Keep in mind that +14% IPC is LNC in LNL vs Redwood Cove. LNC in Arrow Lake would likely have higher IPC due to larger L2 and shared L3 caches.
Just found out the 14% IPC was for Lion Cove in LNL with 2.5mb of L3$. Apparently the Lion Cove in ARL-S is a bit different 3mb of L3$ + larger L2$ and also has the HT portion of the core present.
So it’s still possible for Lion Cove to gain a bit more performance per core.
Keep in mind that they compare it to RWC and not Raptor Cove (RWC has ~2-3% lower IPC vs Raptor Cove). I find the IPC jump to be very weak for P core and very strong for E core.
That is from twit
I don't know how much more clear I could have made it that I was talking about LNC in LNL and RC in MTL.
Your post also explicitly compares that LNC in LNL to Raptor Cove...
Given the bigger differences in P core implementations across different products than in the past, these differences in IPCs are worth pointing out.
Intel comparing new E-cores to the LP-E cores (the ones on the SoC with no L3), rather than the main E-cores on Meteor lake
There is good reason for that. The E cores on LNL don't sit on the ring bus with the P cores and are on a different PMIC. They are essentially the new LP E cores and on the "low power island".
So we are supposed to believe that integer IPC difference between the E core and P core in LNL is just 12%. That is ridiculous given the size difference and resource allocation.
I guess that Lion Cove is able to run >1.15x clock speed over the Skymont.
So, Lion has >1.265x ST perf. than Sky...
Is this ridiculous ?
They have provided ample comparisons for both mobile and desktop implementations:
  • on mobile they're comparing with LP-E cores because the Skymont cluster is taking over their role as well
  • for the desktop, they provide an IPC comparison with Raptor Cove, in a simulation where they both have access to the same fabric and memory performance
Raptor Cove in mobile CPUs. What made you think I was switching to desktop parts on the fly and without mentioning it?
I said nothing about desktops specifically, but it is irrelevant since mobile and desktop Raptor Cove are the same core.
Anyway, I think I made my point so probably no point continuing this.
From this slide LNL-MX iGPU seems to be easily faster than MTL-H iGPU at the same power.
It might be significantly faster and have better performance-per-watt than the bandwidth-squeezed Radeon 890M in Strix Point.
Intel put 8MB L2 on the new iGPU, which is 4x the L2 in the 780M 2/3rds the L2 in the RTX4050. It's a lot of L2 for a GPU that size.
The atom core is good. But some Intel users might anyway decide to shut them down to gain better P core OC and compatibility in some situation.
And if you care atom core enough, you should have known E core IPC is already quite good, compare Gracemont to Goldencove is just 16% lower on INT, and 38% lower on FP due to less FPU resources.
Guess why Intel compare Skymont to LP Crestmont in Meteorlake which lacks L3 cache.
Gracemont is around skylake IPC. Skymont is around Raptor Cove IPC, which is a jump of around 20-50% (specint int 20%, fp 50%) AND gets a clock boost.
The reason Skymont was compared to LP E Cores was explained. It is comparing the old low power island in Meteor Lake to the new one in Lunar Lake.
Skymont in Arrow Lake was also compared to Raptor Cove and Raptor Lake at iso frequency. The attempt at dismissing Skymont performance is amusing.
Edit : Spec
Gracemont is around skylake IPC. Skymont is around Raptor above IPC, which is a jump of around 50% AND gets a clock boost.
Skymont INT performance is great, but as far as FP goes I think it's roughly half throughput vs Raptor Cove (AVX256 needs to be split in 2 ops to execute on its FP units?).
