Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 279 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
701
628
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E012 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E3CPU + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop & Mobile H&HXMobile U OnlyMobile H
Process NodeIntel 4TSMC N3BTSMC N3BIntel 18A
DateQ4 2023Desktop-Q4-2024
H&HX-Q1-2025
Q4 2024Q1 2026 ?
Full Die6P + 8P8P + 16E4P + 4E4P + 8E
LLC24 MB36 MB ?12 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
SiliconFly
1,615
973
I'm not hyped on NPU's, should I be? If I'm feeling lazy and I need a numerical solution to a math problem with no closed for solution or some other work that is boring for me to do manually I just hit up ChatGPT. It doesn't happen that often actually.
Am I stuck in the past and missing AI opportunities in my daily life/work?
Yep. NPUs are just being over hyped.
Ghostsonplanets
700
1,121
Panther Lake is new design with 2 tiles only. 18A is for CPU+SoC, tGPU is available for 2 version: Intel 3 for 4 XE and N3E for 12 XE
Ah, that explains it. I had forgotten PTL is a 2 Tile design once again. So the iGPU tile for the PTL-U SKU is designed on Intel 3? Quite interesting as it's the first time an Arc GFX is fabbed on Intel nodes.
Bionic Squash already leaked that ARLs iGPU (also with XMX) alone has more than double the TOPs of whole Meteor Lake Combined (70+). LNLs iGPU probably isn't worse and then it has a 40+ TOPS NPU.
I had missed that info from Bionic. Thanks!
FYI - C&C has a new article on MTL's iGPU:
That's a good read. Much thanks once again!
Makes sense. But I don't think Intel 4 & 3 are design rule compatible!
Intel 3 should be an Intel 4 optimization (Which Intel used to refer as "+" back in the days) but with complete libraries and PDK. Should be design rule compatible with Intel 4.
Tigerick
701
628
4 XE most likely used in PTL-U series but Intel won't call it Arc Graphics, just Intel Graphics...
Reactions: Ghostsonplanets
Ghostsonplanets
700
1,121
Thats what they said about MTL too (and it didn't turn out well). Without seeing LNL in action, we can only hope it's better.
TBH MTL design is just stupid. Too much tiles being used and the LPE cores are basically useless. No wonder Exist said way back then that MTL project was basically a learning experience that Israel watched the failings to do a better product with LNL.
Are you sure Intel 3 is for 4 Xe? Looks like it's actually for the tCPU after all. Not sure though.
PTL/Cougar Cove CPU should be using 18A.
Reactions: SpudLobby
SiliconFly
1,615
973
Yep. Panther Lake tCPU is 18A. Question is how does Intel 3 fit in the picture with Arrow Lake & Panther Lake according to the first slide?
Should be Arrow Lake-U with Intel 3's tCPU, replacing MTL-U
It has to be either one of the above. Both scenarios can't be true at the same time. Either LNC or Alchemist+ is on Intel 3 in some form.
DavidC1
1,118
1,810
For "Process Leadership" there sure are a lot of "External" showing up.
The idea itself of using whatever process necessary is a good thing.
Let's look at what they themselves have outlined as a problem within their company:
-The process development team got arrogant and treated equipment vendors badly.
-The foundry service never worked out because the management saw it merely as an icing on the cake and potential customers were treated as 2nd class citizens, rather than equal.
-Many years of decisive process advantage meant their design team was wasteful with resources and time. The only team within Intel more arrogant than the process team was design. The old adage "crap CPUs made up by excellent process" was true.
-Semianalysis went into detail about such waste: https://www.semianalysis.com/p/rebuilding-intel-foundry-vs-idm-decades
Hot Lots -
On the other hand, a leading-edge wafer can also be processed in a few weeks if no care is given to cost, but this leads to tremendous inefficiency with tools constantly
They could do as many hot lots as they want, they can do as many samples as they want.
David Zinsner, Intel CFO
Now, they are going to charge their internal design team for the hot lots.
Steppings -
They can do as many steppings as they want.
It took Intel 12 steppings to bring Sapphire Rapids to market, whereas AMD usually takes only 2 to 3 steppings for competing chips such as Bergamo and Genoa.
We even heard rumors from former employees that there was a time when some Intel design teams would rather send a design to the fabs, get a hot lot sample back, and test it for bugs rather than complete more through simulations and verification.
Intel plans to fix this issue by reducing the number of samples and steppings by charging the design and product business units a fair price for these operations rather than allowing as many steppings as wanted.
Test, Sort, Bin -
Intel believes charging business units more directly for test, sort, and bin will make the business units more conscious about what test strategies they use within designs and lead to savings of ~$500M a year.
Design and Ramp -
Intel design teams also tend to ignore the reticle conundrum and lithography tool throughput issues for internal manufacturing, which is something TSMC charges customers for. For a deeper explanation, see here.
This essentially tells us that Intel's problems were widespread and it wasn't simply a matter of "replace the CEO" or "split the company". These were long-standing issues arising from a company that ironically touts "Only the Paranoid win" but not living up to that standard themselves, and were comfortable with their massive financial stockpile and believing they were invincible.
Look at Golden Cove, and even the suspected performance for Lion Cove. They are disappointing. Because they lost the process leadership, they are fully exposed. Rather than thinking Intel was a decent CPU designer with phenomenal process technology, their process leadership was masking growing internal problems just as if a mother would shield her adult son from all troubles, even if going through that trouble would mean her son would benefit from it.
They are basically telling Intel Foundry that you can't be just making chips for Intel anymore, and it has to do all things for all customers, and they are telling Intel design teams that we won't give you training wheels and have to stand on merit, on equal ground.
We should have cycles of TSMC-fabbed Intel chips prompting Intel Foundry to do better, and Intel-fabbed AMD and Nvidia designs prompting Intel's design to do better.
SiliconFly
1,615
973
Hot Lots -
Steppings -
Test, Sort, Bin -
Design and Ramp -
Excellent post!
jpiniero
15,314
5,837
The desktop Meteor Lake is here for Embedded. LGA 1851 too. Cuz Embedded, the price is likely really high.
Needless to say, all they talk about is AI, AI and more AI.
Ghostsonplanets
700
1,121
Is Lunar Lake meant to be a one-off thing? Because there's no roadmap for a LNL successor currently, right? PTL is ARL successor on 15 - 45W range. Will LNL be Intel 7 - 28W offering until they release a new P core?
There's an Intel Core Ultra 3 there. Maybe that's where the Intel Core Ultra 5 115U went.
SiliconFly
1,615
973
...PTL is ARL successor on 15 - 45W range...
That assumption may not be right. Initial leaks suggested that PTL might be more of a LNL replacement (28W or less), although later leaks suggest it may also replace ARL-H as well (up to 45W; but not sure). Higher power desktop parts might still be ARL-S Refresh.
DavidC1
1,118
1,810
There was a brief discussion in December 2021 from @IntelUser2000 and then @Ajay that Arrow Lake was on Intel 3. But no real details were given. https://forums.anandtech.com/thread...ure-lakes-rapids-thread.2509080/post-40656166
That's me, so you missed the note some time back.
Now Intel has proper high volume products on Intel 3 with Sierra Forest and Granite Rapids. The fillers and the plusses are not 3 and 18A but 4 and 20A with minimal usage, while 3 and 18A will have greater than expected benefits and have much higher volume, or you could say conversely that Intel 4 and 20A will be below expectations.
Intel 4 = Intel 3-
Intel 20A = Intel 18A- (Yes those are minuses)
The latest presentations do confirm suspicions that they are still stuck in the high end, high clocked mindset from the 2000's Pentium 4 Netburst era, and aren't the best fit for density, nor for low power. Hence, the usage of Intel 3 for low end iGPU and TSMC for the higher end one.
Ghostsonplanets
700
1,121
The 15-45W range is already covered by ARL. PTL is the next main series on mobile. Where's LNL 2 on the 7 - 28W range? Because PTL-U 15W doesn’t replace LNL. We can see that already with the fact the Xe iGPU tile is half the size of LNL iGPU.
I'm guessing LNL 2 will only happen once Intel has new P and E cores to improve performance at low power. Doesn't make sense to refresh LNL with the same Lion/Cougar Coves they're already using.
SpudLobby
991
684
If Intel lets LNL just float like it’s Lakefield or whatever, bad sign. Would also be annoying just generically. Here’s to hoping they follow up with a successor or that PTL’s architecture is good enough to make it roughly irrelevant.
uzzi38
2,705
6,427
If everybody loves and wants LNL, what do you think happens to ARL-U?
Why even bother having a successor to the cheaper (but not cheaper than RPL-U) mobile die that nobody really wants?
I dunno, to me it makes perfect sense for LNL style designs to cover the entire -U laptop range, excluding cheaper designs.
FlameTail
4,151
2,512
Intel's strategy is to flood the market with options, even if it makes no sense.
Reactions: spursindonesia
trivik12
340
315
Few details from Intel today.
GKu-aTtaIAAWZQI
5 million MTL shipped till date and they are expecting 40 million for 2024 across MTL and what ever they ship for LNL or ARL.
LNL will have 45 Tops for NPU and 100+ across CPU/GPU/NPU. Nothing beyond that for now.
dullard
25,543
4,038
Intel is extremely limited in each node's production quantity. So, Intel has a choice: (A) extreme shortages of processors or (B) processors from multiple different nodes at the same time. They chose route (B) which can work if they are priced correctly.
Ghostsonplanets
700
1,121
