Page 268 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
919
834
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
coercitiv
7,447
17,752
Yeah XMX has to come back, because MS's TOPs requirements are only getting larger as time goes on. It's a lot more area efficient (AKA cheaper to produce and for the end consumer later) to use XMX than it is to slap on an even _bigger_ NPU, even if the NPU would be more power efficient.
Never really bothered to to get more in-depth with the subject, but my basic understanding is ML based tasks in personal computing will be split in two categories:
  • "Low" compute tasks where efficiency is important, such as video call background blur, noise reduction, recognition, translation, dictation, grammar & auto correct etc. The NPU should handle them, so it needs to be scaled to their scope and made as efficient as possible.
  • Heavy compute tasks using generative models (language, multimedia, science & engineering) where performance is important. These will leverage the GPU mostly, because this way the compute area can be used for both AI and graphics, which is a good compromise for a consumer chip.
moinmoin
5,248
8,463
If the former is true, then having AVX-512 support in the die and then fused off is a complete waste of expensive silicon and adds up to cost significantly (25% is a ton of money). Having two separate designs makes a lot of sense considering LNC is new.
It would be especially silly considering the whole reason of existence for E-cores is area efficiency. But with AVX-512 existing but disabled the P-cores are essentially artificially bloated without reason. And I have a hard time imagining combining P and E-cores with all the hard- and software changes that necessitates is cheaper than just optimizing P-cores.
Geddagod
1,617
1,665
I remember reading some articles that had mixed views about the AVX-512 die area during the Linus Torvalds AVX controversy. Many claimed that AVX-512 instructions take up significant die space (as much as 25% per core) due to it's complex logic. While a few others claimed that AVX-512 support doesn't take up significant space in the total die area.
Where did you hear AVX-512 adds 25% to the core area?
Also, even if it is true (I doubt it is lmao), that's just the core. It's not adding 25% to the whole die, the impact there is gonna be way, waaaay smaller
19,203
If we assume each P core in Intel CPUs contains two AVX-512 units and same core is used for server and consumer with the latter having one unit disabled, that's a lot of die area being wasted in the name of segmentation.
Geddagod
1,617
1,665
You should. Like I said, AVX-512 % die area projections differs from one die to die. Some are from trust worthy sources while others are plain speak, possibly just rumors or guesses (may or may not be accurate). You be your own judge, cos Intel doesn't publish exact figures.
You can literally just look at skylake client and then skylake server (which has AVX-512).
Assuming you can read correctly, I clearly mention their claims upto 25% per core. I never said 25% of the whole die area.
Shouldn't have said this then
You are talking about the die in one sentence, and then in parenthesis just mention 25% is a ton of money? It would be generous of me to assume you are talking about the core area tbh, though if it was some other people who typed that I would have just made that assumption lol
Then also, I'm sure it's definitely not waaaay smaller. Definitely not a single digit % number.
Using very optimistic calculations, at best it looks like on AVX-512 is ~15% of a skylake server core. A skylake core looks to be ~ 2/3 of a skylake "block". There's a lot of stuff on the CPU that's not just skylake "blocks" but let's just ignore that. It very conceivably can be a single digit % number, even if the number is 25% as you think it is.
Geddagod
1,617
1,665
Intel might have a marginal lead in client with their upcoming products.
Lol
But, AMD's upcoming cores appear to be better suited for data center than Intel's upcoming cores. Diamond rapids may not match Zen5 series in overall server performance and/or efficiency.
DMR not matching Zen 5 would be kinda pathetic since DMR would be launching pretty much near Zen 6
don't think the transistors are in it to enable it, right ? While googling on the subject, I found this from tomshardware.com
That doesn't mean the transistors won't/can't be there....
AMD drops performance in exchange for area/cost for the Zen4c cores. This leaves Intel in a situation where they need a faster Atom or a more efficient Cove core, but they have neither.
Why?
Ya. Agree. Nothing special. But still gonna be light years ahead of Zen5 I presume.
"I presume"
LionCove+ will be something like RaptorCove compared to GoldenCove or RedwoodCove. Nothing more.
Uhh I think Bionc said something about changes to the L0 and L1, but I could be misremembering
dullard
26,185
4,841
So many of the arguments here are simple misunderstandings like that. People here tend to change subject midsentence and not tell anyone about the change of subject. Or, my pet peeve, use a pronoun that doesn't refer to anything remotely close to the sentence the pronoun is in. The way I read his post was that paragraph was talking about dies, and thus a 25% cost would naturally be assumed to be referring to the entire die cost.
Geddagod
1,617
1,665
Yup. Regardless, idk why he was so mad, other than the "I doubt it is lmao", nothing in my reply was thaaaat annoying. And that was referring to the core, not the total die.
But whatever, I* don't use this site much anymore due to how many times it loads super slowly, or just doesn't load at all.
Ghostsonplanets
774
1,228
Lmao Xino said ARL will be the same perf as RPL or maybe a singe digits level improvement (prob referring to ST)
That would be really unfortunate for a brand new generation. Specially coming after the impressive Sunny and Golden Cove generations, which both had ~20% IPC increase over the past uArch gen.
But, quite frankly, I'm more interested into how Lunar Lake will shape up than ARL. The return of low power x86 in the vein of Core M is much needed to fight against Apple M and X Elite. Intel ST performance is already very competitive so that a single digit uplift would still maintain them in the fight. But figuring high performance at low power and with good efficiency is key and hence why LNL is such an interesting prospect to me.
Reactions: Tlh97 and Thibsie
Geddagod
1,617
1,665
Oh wait their accounts have all been suspended when was this lmao
No it hasn't. It was today.
Then there is a third but remote possibility that ARL might have a slight performance regression over RPL, cos RPL screams at a mind-numbing clock of 6.2 GHz.
Xino claims ARL might get up to 5.6ghz, but I doubt he is talking about the 14900ks, most people when comparing generations don't include the KS parts.
Might be closer to 10% than 20%, unfortunately. I agree though, after all the LNC hype...
Intel's low power optimization is just so cooked it's wild. Crossing my fingers for LNL (though I prob won't end up getting it anyway).
eek2121
3,458
5,105
Meh, both can be used for point #2. I am actually more curious if this becomes a move back to CMT. Put enough instructions and speed on the NPU and suddenly the CPU doesn’t need to have an FPU anymore. 🙃
19,203
Wouldn't that break compatibility with existing software? If they somehow divert those instructions from CPU decoder to NPU, there would be a latency hit involved.
naukkis
1,030
854
NPU is exact opposite of FPU. Floating point instructions are varying point so number expression range can be huge, like from 2^-64 to 2^64 and calculations can be done between opposite extremes. NPU instead is relying extremely short integers, like 4 and 8 bits - only 16 or 256 values. If we think normal integer(fixed point math) cpu as middle point NPU is other way and FPU the other, they are absolutely not alternatives.
H433x0n
1,224
1,606
An fmax of 5.6ghz would be fine.
At this point they should be receiving ES2 for a launch in October. If the practical IPC is ~15% I guess that makes sense once taking into account the 2-4% penalty from tile overhead.
Unfortunately in typical leaker fashion Xino wasn’t very specific. Was this test at JEDEC-4800? Was it with most recent stepping of SoC tile? Are the IPC figures from mobile or desktop ARL? Which version of RPL is he talking about? The 13900K or a 14900KS 1T performance?
Expectations are pretty low but if IPC bump is <15% then they deserve to get clobbered.
Reactions: Tlh97
