Page 270 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
naukkis
1,030
854
The ability to use different data types is theoretically possible with NPUs. But, the main issue is memory, bandwidth, and power used. If you only need 4 bits (which AI often only needs 4 bits or 8 bits), then using something set up for 512 bits is quite a waste. Using 512 bits when your application needs 4 bits will require 128x more memory, will have to move 128x more data around, and will have to process 128x more of that data, using much more power. All while only being able to use much smaller AI models due to those limits. So, it isn't really efficient to use something set up for 512 bits with 4 bits
The reverse is true too. If you have an NPU optimized and designed for say, 4-bit math, and need 16-bit data, then you need to transfer that data around in 4 chunks which takes more time. Then you have memory to store only 1/4th the data. It can work, but just won't be as performant as you want.
Whole NPU meaning is to make optimized hardware for very short datatypes with simplified instructions. FPU does very complex instructions with long datatypes being exactly opposite optimizing point to NPU. And FPU isn't actually co-processor anymore, it's a part of a ISA and it cannot removed without losing compatibility. And as it's a part of a ISA pretty much every program used it by default if float or double type variables are used as it's faster use them with FPU than with integer units.
Reactions: Tlh97 and moinmoin
Hitman928
6,754
12,500
Not sure if this is news, but Microsoft just announced "Surface AI PCs". They utilize Intel MTL and come in 2 models, the Surface Pro 10 for Business and Surface Laptop 6 for Business.
eek2121
3,480
5,165
While I do agree, technology does evolve over time and this is what I am getting at. I was thinking in terms of literal decades when I said that.
The NPU will likely take on more responsibility as time goes on. I will be shocked if x86 20 years from now as it does today. New wafer costs keep going up and having duplicate functionality on multiple parts of the package wastes die space.
I am terrible at predicting , but if I had to I would say the lines between the NPU, CPU cores, and GPU cores are going to blur.
IIRC someone mentioned AMD has a patent for catching exceptions for missing instructions and redirecting the workload off chip. The reason it got brought up is because of Intel’s missing AVX-512. I could absolutely see something similar happening here.
Someone mentioned latency, but once the compilers are changed, there would be no performance penalty and performance may actually increase.
Me personally? I want socketed NPUs so competitors can play too, but of course we won’t get that. We are getting PCIE accelerators soon, however.
We are still in the very early days of AI. If you compare AI to the invention of the internet, we equivalent to where they were in the 70s.
Reactions: Tlh97 and Thibsie
adroc_thurston
8,552
11,283
Speculation was about replacing FPU with NPU
did you just invent GPUs.
like dawg we already invented silly parallel SIMD crunchers. in 2005. In Xenos, from Xbox 360.
It does dumb matrix math.
are you daft
THE FUTURE IS FUSION™
They'll be more clear-cut than ever.
DavidC1
2,182
3,328
Technology wise the Atom team's work indeed has been more interesting to follow for quite some time now, like for a decade by now?
After falling out of the spotlight with Silvermont/Airmont, they've been working quietly behind the scenes.
They've been doing a consistent cadence of using new ideas in one generation and optimization/expansion the next.
Bonnell - 2 way in order
New Ideas: Silvermont - 2 way out of order, lowered pipeline stages
New Ideas: Goldmont - 3 way out of order(added OoOE FP) + 16KB predecode
Exp/Opt: Goldmont Plus - 3 way + wider backend, quadrupled(64KB) predecode
New Ideas: Tremont - Clustered, 2x3 way, 128KB predecode, greatly improved branch prediction
Exp/Opt: Gracemont - Improved clustered 2x3 way, so the throughput is effective 6-wide. Predecode cache replaced with OD-ILD that predecodes on the fly for better performance under more demanding workloads and higher area/power efficiency
New Ideas?: Skymont - Clustered 3x3 way + ??
Darkmont - 18A shrink
Exp/Opt: Arctic Wolf - Clustered 3x3 way with backend optimizations?
Gracemont is already superior to Golden Cove in the fetch department, where it can fetch 2x32B(2x16B from the OD-ILD) to feed the two clustered decoders, while Goldemont Cove can only work with 1x32B for its 6-wide decoders.
Not only SMT is going to go away, eventually I suspect uop caches will too, as the primary purpose of the uop cache is to increase clocks while attempting to minimize branch misprediction penalties that comes with increased pipeline stages.
Henry swagger
513
313
raichu said skymont will be 8 wide so 4×4 way. And is targeting rocket lake to golden cove ipc
