Page 266 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
920
835
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
Henry swagger
513
313
The lesser known impact of Sierra Forest is that it comes merely 1H after they say Intel 3 is in production, when for Intel 4 it took a year.
I think there's also a significance in saying 18A is 1H ahead of 20A. 20A product comes in H2 2024 with Arrowlake. Logically, 18A product is Clearwater Forest in H1 2025. Cutting the gap alludes to improved design execution.
288 cores of Skymont that's on par with Golden Cove in average(Int and FP), on 18A in 2025 will truly mark "undisputed leadership").
Nah amd is still ahead in data center.. intel will have unquestioned leadership as pat said with diamond rapids
19,203
In the demo we watched, an AMD exec said that AVX512 and VNNI acceleration built into the Zen 4 CPU cores were behind the winning results you see in the charts. That's interesting, as we expected to be told about the more powerful NPU in the Phoenix vs Meteor Lake processors.
Oh dear God! Pat, just admit defeat and enable AVX-512 on MTL.
Markfw
May 16, 2002
27,360
16,193
I don't think the transistors are in it to enable it, right ? While googling on the subject, I found this from tomshardware.com
Next-gen Intel Arrow Lake-S CPU spotted with 24-threads and no AVX-512 functionality​
eek2121
3,458
5,105
Am I reading this correctly?
Let's look at 2GHz.
4 Gracemont cores requires about 3000J
4 Golden Cove cores requires about 3750J
4 Skylake Cores requires about 4200J
I knew that Gracemont was area efficient but I did not know that below about 3.2GHz it is more power efficient than Golden Cove.
This chart brings some economic realities of CPU manufacturing to light. First of all, if you want incredible MT efficiency just throw a huge amount Gracemont clusters at 1.4GHz at the task. For ST 6 or 8 Golden Coves will do the job. Problem is of course that would be a huge and expensive die!
Performance/Efficiency/Cost
Pick two. You can have performance and efficiency but at higher cost. Or low cost and high efficiency but you'll also have low performance. Or you can have low cost and high performance and low cost (Raptor Lake).
The reason I put Zen 4 above Raptor Lake is because it does much better than Raptor Lake at hitting high performance, high efficiency, and low cost.
Cost is due to die size, which is derived from the process and density. I state this because you can make a design which balances performance/density/efficiency, or you can optimize for one or two while sacrificing the others. Intel clearly goes all in on performance, whereas AMD appears to balance things out. (See my response to the below post)
Intel might have a marginal lead in client with their upcoming products. But, AMD's upcoming cores appear to be better suited for data center than Intel's upcoming cores. Diamond rapids may not match Zen5 series in overall server performance and/or efficiency. AMD's dense cores are particularly very impressive.
Intel’s issue is that their big cores aren’t as well designed as Zen because they spent years optimizing for absolute performance. The atom cores were originally designed for phones and tablets so they favor efficiency and die area. Because of this, Intel has been able to gradually move towards a good balance of perf/efficiency/area.
AMD drops performance in exchange for area/cost for the Zen4c cores. This leaves Intel in a situation where they need a faster Atom or a more efficient Cove core, but they have neither. However that is about to change.
IMO they really need a clean slate design
Reactions: lightmanek
AMDK11
484
424
'm 99% sure that in RedwoodCove and LionCove the AVX512 physically occupies the transistors in the core as it does in SunnyCove and GoldenCove. AVX512 is part of the core microarchitecture. There's really no reason to think it will be any different since Xeon and Core(i/Ultra) processors use the same P-cores.
The only difference is that since AlderLake the AVX512 is inactive.
Reactions: Tlh97 and Geddagod
19,203
I have this fantasy that Intel Thread Director is firmware based so once they figure out how to make it recognize AVX-512 code and prevent it from scheduling it on the E-cores, they will retroactively enable AVX-512 on all consumer Golden Cove cores. Just waiting for that one fine day...
dullard
26,185
4,842
The AMD solution used its CPU, GPU and NPU. Does LM studio even support the Intel NPU or GPU?
According to Tom's Hardware, no, it doesn't use Intel's NPU or GPU. So this is a comparison of just Intel's CPU vs. AMD's CPU + GPU + NPU.
"You could try LM Studio instead, though it doesn't appear to have Intel GPU or NPU support yet, so it would just use your CPU."
Intel's NPU is quite weak in Meteor Lake, so it wouldn't help much. But the GPU might help. The NPU is supposed to be 3x better in Lunar Lake and then 5x better than Meteor Lake in Panther Lake. By then the NPU should be better than the GPU.
Markfw
May 16, 2002
27,360
16,193
alder was disabled, and raptorlake. But MTL does not even have it, and from the link, not arrowlake either. and since Intel is monolithic, I don't think the cores are identical.
poke01
4,606
5,917
Intel even in panther lake is behind in AI performance. So PTL will have 50 TOPS for the NPU meanwhile Qualcomms NPU in the X elite already has 45 TOPS already in 2024.
So PTL launches in late 2025. Intel is behind in every metric. CPU, GPU and even NPU.
AMDK11
484
424
In AlderLake this was disabled via bios/microcode, but in Raptorlake it was disabled at an even more advanced level. GoldenCove and RaptorCove contain physically the same FPU. Moreover, in RedwoodCove the FPU is also identical because the basic microarchitecture in RedwoodCove AVX512 exists the same as in RaptorCove.
I'm sure AVX512 exists physically in LionCove because Intel won't develop two different P-Core microarchitectures.
This is not about deleting the block with AVX512 registers. AVX512 is included in almost all P-core logic.
Removing the P-Core logic means a completely new core design and a separate design for Xeon.
Markfw
May 16, 2002
27,360
16,193
Well, I am not sure of any of it. When Intel comes out with the chips, lets look at benchmarks, then talk. Yes, Raptorcove is physically disconnected for avx-512.
Khato
1,328
398
You're giving AMD's software enabling capabilities too much credit. The article specifically states:
As a reminder of the properties of the latest Ryzen chips that align themselves to local AI acceleration, AMD says that three kinds of cores can be used in concert: NPU, RDNA 3 GPU, and Zen 4 CPU. In the demo we watched, an AMD exec said that AVX512 and VNNI acceleration built into the Zen 4 CPU cores were behind the winning results you see in the charts.
So basically this is AMD saying that they have AVX-512 VNNI enabled on their consumer processors while Intel doesn't. It's apparently far easier to design a hardware NPU than it is to get software to make use of it.
AMDK11
484
424
In RaptorLake and RedwoodCove, AVX512 logic transistors physically exist and that is certain. In LionCove, I am confident that AVX512 logic will also appear. In the basic microarchitecture there will be 1x512bit, and for Xeon with additional logic, which will give a total of 2x512bit. I don't expect anything else. In LionCove, the only thing that can be for ArrowLake is that AVX512 is disabled at the hardware level, but it will still exist physically.
You will remember my words.
Markfw
May 16, 2002
27,360
16,193
I won't remember, but I will discuss things when each new CPU comes out.
