Page 159 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
919
834
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
Thibsie
1,156
1,363
Bye bye offline privacy. :D
Well this functionality is, in fact, sought after.
Either you do it with the CPU, the NPU/GPU are files are uploaded so a server can do it faster but... privacy bye-bye.
I can totally see why it is useful to have the photo software get you every photo of, let's say, daughter number 1 without having to do the job yourself.
Seems a valid use case to me.
gdansk
4,688
7,924
It is a useful feature and one that most customers would want to run on their machine instead of in the cloud whether they realize it or not. Who wants Google/Apple sending pictures of their kids to their servers if there is a good local alternative?
But it isn't clear to me if customers would prefer that processing to be fast or power efficient. I'd lean toward the latter and in that case total peak TOPs doesn't seem too relevant.
Reactions: Tlh97 and Thibsie
eek2121
3,458
5,105
Yeah the TOPS is the bad news.
I was expecting MTL to have 45+ TOPS NPU.
I am surprised it's not the case.
Not a single CPU released (or releasing this year) has an NPU that does 20 TOPs, let alone 40+
If Windows 12 is as bad/worse as 11, my privacy will be intact because I will finally move to linux.
SiliconFly
1,924
1,284
I think i may have figured out why Intel marketing came out with the snake oil stuff out of the blue! MTL launch is just a few days away and AMD has the tendency to crash Intel's party by saying stuff like Intel's cores are monolithic and old and their chiplets are the best. Or stuff like, Intel's nodes are bad and their nodes are superior, etc. Same goes with the cores like Zen architecture is better than Intel core, etc, etc.
And as far as MTL is concerned, everything in it is new, except for the CPU tile which has RWC which is just a rehash of RPC which in turn is a rehash of GLC. Afaik, this is Intel's achilles heel. And probably the singular issue with MTL. And they know AMD will somehow bring it up to rain on the MTL parade. So, it appears they chose a preemptive strike. A carefully orchestrated attack on AMD to ensure they doesn't get too cozy taking potshots this time.
Saylick
4,099
9,578
HXL on Twitter posted some benches from bilibili on MTL. Not sure how legit, not sure what laptops were compared, what kind of battery size, etc.
Battery Life (Minutes):
dullard
26,185
4,841
More MTL stuff from HXL (from Bilibili), this time about the iGPU and CB:
Looks like Ultra 7 155H wins some, 13500H wins some, and 7840HS wins some. But the Meteor Lake is at 28 W vs 35 W or more for the others?
Also, why Windows 10?
Hitman928
6,748
12,474
Their 13500h results seem to be in line with notebookcheck's results but their 7840hs results are really low (outside of geekbench5 multi for some reason). If their Intel results are true, it's pretty disappointing. Battery life is improved but performance is significantly worse tier to tier (unless the 125 is supposed to be lower than the 13500H?). Without knowing what the exact PL setting and such were, it's hard to really say though.
dullard
26,185
4,841
The 7840HS is configurable from 35 W to 54 W. I agree: without knowing the power level of the tests, it is hard to really say if the results are good or bad.
Hitman928
6,748
12,474
The 7840HS is configurable from 35 W to 54 W. Without knowing the power level of the tests, it is hard to really say if the results are good or bad.
The results shown are significantly lower than the lowest of notebookcheck's results. I mean, it's possible that their configuration is hard locked at a lower power than any of notebookcheck's tested configurations, but that seems unlikely, especially given the large difference and the inexplicable geekbench5 result which matches notebookcheck's top result. If it was a hard power limit, there's no way that could happen. Only thing I can think of is if maybe they tested the Ryzen on battery power for most of the tests except GB5 multi. That's the only thing that I can think of that would make the results make sense (but obviously still invalid). No real idea what's going on, but their Ryzen results make me question if their MTL numbers are legit either.
TESKATLIPOKA
2,696
3,260
Without actual power these results are meaningless.
At least IGP looks decent. 3077 in Graphic score is not bad at all and higher than PHX. The question is how It performs in actual games.
cebri1
373
405
Battery could have a lower capacity or bad optimizations, you can see It all the time in laptops despite having comparable specs.
That's my point. If a CPU with less cores and lower frequencies has worse battery life is that the comparison is not well made.
Abwx
11,936
4,910
From NBC tests it look like the 7840HS is set at about 35W, the 7840U score about 12000@30W.
Also notice the evolution from R15 to R23, no need to improve your CPU IPC, "improve" the bench instead, that work much better, same from GB5 to GB6...
Edit : The difference between 125 and 155 in battery life is not significant, in the first test it s 3%, so within error margins.
dullard
26,185
4,841
Why 3 GHz for the 155H? I thought the base was supposed to be far higher than that.
dullard
26,185
4,841
Some numbers are off. 125H should have better battery life than the 155H.
Look up "Race to idle". If both turbo to the same power level, but the 155H gets done sooner, then it will sit idle for longer. The 125H will have to stay in high power turbo mode for longer, using more energy. Thus, the 155H should have a longer battery life.
Reactions: Tlh97 and cebri1
Hitman928
6,748
12,474
Most battery life tests aren’t run this way. They will do some combination of constant web loading tests, video loop tests, pdf/ebook tests, long idle, and constant load tests. Race to idle doesn’t affect any of these.
Very few do a total energy used type test where race to idle can have a large effect but usually they put them under efficiency sections.
