I got a "Will it Blend" blender!
FP
4,568
Originally posted by: mobobuff
Originally posted by: binister
Hold up... That is requires 1500 watts? Is that continuous? That is 13.6 amps!
Guess you can't use it anywhere but the bathroom and kitchen! :)
What does GFCI have to do with the amperage it draws?
I wasn't referring to the GFCI outlets. Most household circuits are 15 amps while the bathroom and kitchen are usually 20 amps. If you throw in a few lights, computer or TV you could easily draw more than 15 amps with that thing running.
Op, how much did you pay for that thing?
mobobuff
11,099
Oh, most houses I've lived in have had dedicated 20A circuits for appliances, while the outlets where still on a 15A circuit. I've only seen bathrooms with 20A circuits if they have those heating lamps. But I haven't lived in a house built after 1980. *shrug*
FP
4,568
We had 15A circuits as well but had to put in 20A when I recently remodeled our kitchen and master bathroom due to city code.
SirStev0
10,449
What are the blades made of?
Adamantium.
That explains everything.
They tried to blend Wolverine, but it broke. Same thing happened with Jack Bauer, oddly enough.
Well Wolverine could heal himself and had a higher Adamantium mass, and Jack probably had Chloe break into the blender's mainframe and upload a virus to the motor.
I am not going to lie... I immediately went to their website and suggested them to try Jack Bauer...
I think we need an ATOT effect...
Jack Bauer
International terrorists, the Chinese, and even the President of the United States have been trying to kill him for years, yet he has continually been able to out wit them with only a messenger bag, palm pilot, and Chloe Sullivan. Jack Bauer is indestructible... but "will it blend"?
ultimatebob
25,134
2,450
I'm curious... if you blended a steak, do you end up with something like ground beef? If not, would you end up with "steak smoke"? Is "steak smoke" even breathable?
Enquiring minds want to know!
Rubycon
Madame President
Aug 10, 2005
17,768
485
Surely those blenders used in the willitblend movies get their bowls replaced. The lexan bowl is very durable but blending hard objects is going to scratch it all to hell.
I think it would be neat to blend a vial with water on one side and a lump of potassium on the other. :Q
Duddy
4,677
15
Try this:
1 Pint of Haggan Daz (sp?) Strawberry Sorbert
2 Whole Bananas
1 Cup of Orange Juice
That there makes the best Strawberry-Banana Smoothie on Earths.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Originally posted by: Jeff7
Sorry, 3 HP = 2,237.09961 watts.
:p
It's funny how all these ratings get skewed. In pro audio we have amplifiers that can put out 4000 watts per channel into 4 ohms and run on a 120V 15A circuit. How is that? Well music is never a continuous tone. If the program demands the power it will come from the outlet (and often trip the breaker) hence one has to be careful if their distro is limited to 15A for this example.
With a blender it's possible to have a motor that can produce a peak of 3HP and run on a common 15A 120VAC circuit as well. The most common motor used is the universal motor that has a very high speed (a dremel moto tool is based on a universal motor) and speed that will sag under load (this depends on the motor controller). While the blender on frappe may freewheel at only 3.0A it will draw 5-10 times that when a load is dumped (ice cubes while making a smoothie). Normal fusing/circuit breakers will allow these types of momentary overcurrents to pass freely and the actual hp rating can indeed reach over 3hp in such given circumstances.
Where the blender motor vs. pro amp example varies is under a continuous load the windings in the blender motor will overheat. The amp (if the circuit allows) will produce a high output sine wave at its terminals until either the speaker voice coil melts down or the amp's output transistor heatsink grows too warm and thermal protection interacts cutting off the output.
The blender most likely has a current monitor to protect the motor windings, commutator, and brushes too. If there's not too much isolation between the motor controller and the supply circuit and the supply circuit is protected with an arc fault circuit interrupter it may trip from excessive brush to commutator sparking. If the blender is very sophisticated it may use a polyphase motor with cycloconverter drives. Those are another discussion all by themselves. ;)
Kaido
Feb 14, 2004
51,930
7,406
About $400 on Amazon: (available in black or white)
http://www.amazon.com/Blendtec...&qid=1186287686&sr=8-1
Not a small investment, but on-par with the other high-end blenders like Vita-Mix. It replaces a number of other appliances as well (food processor, ice crusher, wheat mill, etc.). I like it a lot. Pretty much all I use now are the blender, a 10" skillet, and my grill :D
Kaido
Feb 14, 2004
51,930
7,406
Originally posted by: Duddy
Try this:
2 Whole Bananas
Ooh I'll try that next week :D
Kaido
Feb 14, 2004
51,930
7,406
Originally posted by: Cristatus
How does the Vitamix boil things? Does it have a built in heater?
edit: I've never used a blend for more than 1 minute at a time.
(C)
I think it just heats up from motor heat. The Blendtec can do the same thing, but I don't know if it gets quite as hot. I made strawberry sauce with it yesterday and it was fairly warm but not boiling.
Kaido
Feb 14, 2004
51,930
7,406
The replacement jars are about $50, just FYI :)
andylawcc
18,183
Adamantium.
Jack Bauer
LMAOSSO!
