gt = 350x1000Originally posted by: chinkgai
im confused at what this does exactly after you flash it.
what is the new "stock" speeds after u flash a regular gt?
will it work on any gt? like pny, evga, bfg, leadtek, etc?
does ur core/mem have to have a minimum oc level before you attempt this?
Originally posted by: THUGSROOK
if youre an OCing nut ~ youre gonna wanna try this on your card 🙂
1> you get to use ExperTool software
yes, if using the floppy version you can save your original bios to restore it later if needbe.Originally posted by: Spike
So you say it is reversable if I screw something up? I saw something about flashing back to original bios...
Also, should I do this right off that bat (flash and oc) or give my card some time at stock speeds as a 'burn in'?
-spike
youll never know unless you try 😉Originally posted by: Matrix333
i already modded my Gigabyte 6800GT to 1.4v in 3D
so will i not see any better performance with this than i do already?
currently 400/1100
Way to bash before you read idiot. He is talking about the expert tool.Originally posted by: Ackmed
He says GT overclocking is limited to 420Mhz core. Uh, WRONG.
