Originally posted by: 308nato
Roger is 100% correct. The only useful tool here is the fire wrench.
Check engine light code read off as this sensor being whacky. It was $68 from Nissan (the part is not possible to get at somewhere like Autozone), 2000 Maxima.How did you determine it needed to be replaced? How much was it? For what kind of car?
Originally posted by: Skoorb
Ooo, where is a good place to get a cheapo propane torch? Homedepot and Lowes online don't seem to have em...
I thought that Homedepot or Lowes WAS a hardware store! :QOriginally posted by: PsychoAndy
Blasphemy. If they dont, check Kmart, Walmart or a hardware store.
-PAB
Just occured to me too. Hopefully one won't cost too much 😀The probably have them in the stores but due to restrictions on shipping gas cylinders through the mail don't carry them on-line.
-PABJust occured to me too. Hopefully one won't cost too much 😀The probably have them in the stores but due to restrictions on shipping gas cylinders through the mail don't carry them on-line.
OK. It may be tricky as heck to keep from heating up the o2 sensor but I'll do the best I can and that price is right.Originally posted by: Roger
Skoorb;
$12.99 at KFart for a propane torch, remember that you must heat the exhaust pipe and exhaust for at least 5 minutes for it to work.
Skoorb;
EDIT: OK I can heat up both o2 sensor AND pipe!
Well there must be a point to replacing it isn't there? I know that this sensor down by the cat convertor is bad. My gas mileage has gone down very recently (although it was "bad" for at least 1000 miles before that) and the other night the car was making a foul, foul smell, so I thought I'd replace this, since it is bad. I'll confirm at lunch that only this sensor is bad and another one hasn't gone bad in the meantime causing the nasty gas use.Originally posted by: LAUST
I'd hit it with PB blaster, let that soak on there for a good while then heat it with a torch, I'm pretty well verse with pulling them off myself, my truck has 4 of them.
BTW why are you pulling your Cold side sensor?
I did buy some anti-seize last night from autozone so that this isn't an issue next time...Originally posted by: 308nato
There should be a threaded fitting welded to the pipe that the sensor is threaded into. Get that nice and hot. And try to "snap" the sensor loose quickly with a nice, quick application of force. Simply tugging on it may not do it if it has self welded nicely. Do yourself a big favor and pick up some "Never-Sieze" and apply it on your new sensor (small amount on threads only) to keep this from happening next time. NAPA carries the real stuff in a red/blue can.
The Cold sensor (Muffler side of the CAT) is only used for ODB2 to report CAT failure, the Hot sensor (Engine side) is what reports your Rich/Lean ratio to your PCM.Originally posted by: Skoorb
Originally posted by: Brutuskend
Take a torch to it, (the surrounding area at any rate) until it's a nice cherry red and it should come right out.
OK I'm not sure on the heat thing - some are saying heat the O2 sensor - others are saying heat only the area around it. Although I don't deny the fact that the torch will help, if the heat expands the metal wouldn't that make everything just tighter in there instead...?
Go Skoorbie Go Skoobie GO!
Please let him get it off...I cannot stand a frustrated Skoorb for another night!OH MAN, that's SCREAMING for a off color joke!!
But I'll try and control myself.......
Just heat the area around the sensor, the senson itself will get hot as well, but what your trying to do is expand the metal around it while keeping the sensor from expanding as little as possable.
