Jmmsbnd007
- May 29, 2002
- 3,286
- 0
- 0
Originally posted by: MrsSkoorb
Well, Skoorb is off to see what he can get!![]()
Should be OK on the ramps all night. Really it's not that different from leaving it parked on an incline. Just make sure that it can't roll off the ramps.Originally posted by: Skoorb
Oh - are there any problems keeping a car up on ramps overnight? I guess it puts extra weight on the backend, but otherwise no worries...? Maybe I'll have to leave it overnight and finish up in the morning.
I just went down and the thing had rolled into somebody's car. OMFG!!!!!!!!!!!!!!!Originally posted by: Zenmervolt
ZV
Laugh all you want, I've dropped my car off of it's jackstands more times than once. Damn lucky that no-one was under it either time when it fell.Originally posted by: Skoorb
ZV
Well I had problems getting it on the ramp, so I bought some extensions for low profile cars. I screwed up getting it up on the ramp and on one side one of the extensions shot out and caught under the back tire, so now when I go backwards the low profile front of the car will rub the extension-less ramp. I guess I'll have to jack up the back with the tire-changing jack and get the extension out. Lesson learned.Laugh all you want, I've dropped my car off of it's jackstands more times than once. Damn lucky that no-one was under it either time when it fell.
ZV
EDIT: Also seen the ramps collapse.
Didn't know about them. Looks like one would do the job great, except there is definitely not enough clearance to get one back there behind the sensor...use an impact wrench at low speeds to break it loose then use the ratchet to take it out.
ZV
It's fineHand brake on, in gear, and the ramp has lips on it anyway
Just went down after 30 min with the wrench and a hammer and the buggar is still on so I applied more PB. I'll try in an hour or so, then if not I'll try tomorrow morning. Then I'll keep trying every 12 hours and I'll try it for 2 days. If it doesn't come off I'll torch it or bring it in somewhere.
A lump of coal?Originally posted by: Ornery
How did you determine it needed to be replaced? How much was it? For what kind of car?
I'd suggest using heat too. There are MANY times on auto repairs where that comes in handy, especially on the old cars I buy. There are a LOT of times I've needed a torch in the past, and all I had was a damn propane one. :disgust: I know what I'm going to ask for Christmas now!
I recommend that in conjuction with the PB blaster. Do that a dozen times: spray on, give a few second of impact knock, wait, then repeat.
A knock with hammer might help, but impact wrench is best.
