Hot Rechargeable Batteries Deal!--24 Pack 2000mAh AA Cells $25
Cybordolphin
2,813
Sorry guys.... I did not mean the charger shuts off. It has a built in timer control for overcharging that only goes up to 12 hours though. It takes that long or longer to charge the 2000mAh batteries. It does discharge, switch to trickle when the battery reaches full charge, and indicates "dead" cells via the LED's.
By the way..... I sent a friendly email to the sales department and told them that I had received (2) dead cells from my prior order. I received in 3 days (2) new replacement cells. I was not expecting anything, but just emailed them to let them know I had received two dead cells. Nice customer service.
Bot69
985
Sounds like superb customer service. I will have to do the same for the dead cells that I received.
SupaDupaCheez
2,034
I just ordered:
12 Pack AA 2000mAh High Capacity NiMH Rechargeable Batteries---New!! 1 $16.14
V-2000 Superfast Smart Charger + 12 AA 2000 mAh Hi-Energy NiMH Batteries 1 $26.59
Total with 5% code and standard shipping was $49.37.
I believe this is slightly cheaper (a couple of bucks) than purchasing the 24 pack and the v2000 separately.
SDC
mindless1
8,834
1,801
Originally posted by: niuniu6
can i connect my batteries in parallel to increase the capacity?
It's better to just get larger capacity battery, though more expensive. You can do it, but don't charge them in parallel, always in singles-series.
A different reason to run them in parallel might be to get more current... these are not high-current batts.
niuniu6
14
Thanks, that's very clear.
Muse
41,290
10,441
Originally posted by: quincy2002
EDiT and niuniu6 - I use the Maha/Powerex MH-C204F. It's really good. Charges the batteries in about 3 hours. It has a deep discharge cycle that you can use periodically. I've had several batteries that wouldn't hold a charge very long after some use. I put them through the discharge cycle, recharged them and they're like new. Very nice charger. Maha also makes a newer model of this charger, model MH-C401FS. It supposed to be better than mine. Newegg has these chargers. You can also find them at SunnBattery.com and Thomasdistributing.com among others.
The MH-C401F is NOT a newer model of the MH-C204F. It's a different design, doesn't support discharging but does support pulse chargine. Maha claims the pulse charging does away with the necessity to condition (discharge) the cells, but I wonder.
[/quote]Yes, definitely worth it. I have the MH-C204F too, but I'm thinking of getting the newer model C401FS. I have some FRS radios that use 3 AA, what a PITA. The C401FS can charge each battery separately, the C204F cannot.[/quote] For that purpose, the C401FS would be better, at least in terms of being able to charge 3 batteries at once. It has 4 separate charging circuits. The C204F has two.
mindless1
8,834
1,801
anybody knows how much difference between 2000mah and 2250mah? can I take 20 more pictures?
That sounds like a good estimate, yes, but it depends on the 'cam. Some peeps ordering the 24 pack 2000mAh were getting 2250 cells anyway.
wakeboarder
177
250 mah
Basically mah stands for milliamp hours. So a 2250 mah battery can supply 2250 milliamps for 1 hour. Or 1125 milliamps for 2 hours, etc. You multiply the millamps needed by the time usage in hours to figure out how long it will work for your particular device. So a 2250 mah battery gives you 250 mah more then a 2000 mah battery, equivalent to a 12.5% increase in how long it will work for. So if you can use the 2000mah battery for 8 hours on your camera, the 2250 mah will work for 9 hours. If you can currently take 160 pictures then you would get an additional 20 pictures out of the battery.
A lot depends on the usage though, just having the camera on takes a little current, add the lcd display and that ups the current needed, taking a picture draws even more and if you use the flash even more. So if you are taking pics without the lcd or flash you will get a lot more pictures then if you use the lcd and flash. So if batteries are dying turn off the display to get extended life.
cssmaster
47
250 mah
Thanks a lot. My record tops 177 shots with Kodak 3.2MPix, hope these new cells bring me 200.
eyeguy
187
I got the AAA's for pager. remotes, etc.
now I'll never have to buy batteries (for years)
if only they had rechargeable cr123A
LordSnailz
4,821
Originally posted by: huaian
Just got a free bushnell binoculars from them..that's sweet!!
How did you get a free bushnell binoculars? I'm planning on placing and order, any freebies I can get would be even sweeter!
mindless1
8,834
1,801
Not sure if the deal's still good or not, but IIRC it was 'spend $50 to get 'em free'.
sontakke
895
11
Why fast charger is better than slow charger:-1) The voltage drop (i.e. the delta detection) is easier for
a fast charger as it is pumping more current into the battery.
A slow charge has more chances of missing the peak detection
2) When you buy a battery for $1 or even at $2.5 (at your local Walmart)
do you really care if instead of gettingg 500 charges, you are
"only" going to get 100 charges out of it?
3) I still have 2 year old Panasonic 1600 batteries which are still
going strong and they have been exclusively charged by the Rayovac
1 hour "cooker". I wish they would die, I would then go out and
buy newer 2200 mAh and giving me almost 40% more charge
3) Fast charger is more convenient
4) If I had not picked gazillion Dynacharge (Duracell) 1800 last year,
I would jump on new 15min Rayovac system. Walmart has the 15min
4AA package for about $13.
In short, I see no reason to use slow charger at all. Frankly, your
batteries will die of old age or worse become obselete well before
they are harmed by GOOD QUALITY fast charger.
mindless1
8,834
1,801
One of the chargers offered on their 'site, is currently on 1/2 price sale at Harbor Freight for $10
Edit: Sale is over.
Johnbear007
4,570
IS there anywhere else to get a good deal on recahrgeables? I really need some but this place is always out of stock
