Originally posted by: ValsalvaYourHeartOut
Originally posted by: sxr7171
Well, audiophiles and more so manufacturers like to claim dramatic differences in every they use or sell. However the differences can seem dramatic in the context of what caused those changes. For a skeptic (as I was) to hear the Analysis Plus cables make as much difference as they did was "dramatic" in a relative sense. I heard the difference and really enjoyed it for the two days before I got my new speakers. (I can't test my old cables on my new speakers as my new speakers require biwiring).
Unfortunately, the differences that you heard were NOT controlled by a blinded comparison. I do not deny that you perceived an improvement when you swapped in new cables, but this perception may or may not reflect actual differences in sound reproduction. There are NUMEROUS explanations for why you might have thought your new cables sounded better...for instance, I bet you didn't pink-noise level match the two comparisons, etc. But this is irrelevant to my central premise:
If cables indeed result in dramatic differences in sound quality, then these differences should EASILY show up in even the most hastily constructed BLIND listening test. This means that even the average audiophile who is used to listening to nice setups should be able to pick out the expensive cable, even though he doesn't know which on it is. Unfortunately, the ONLY evidence supporting major sound improvements has been with NON-BLINDED listening tests in which the listener is subject to biases, placebo effect, and preconceive notions. Anyone who is used to evaluating evidence should easily conclude that there is strong (but non-definitive) reason to believe that cables do NOT make significant differences in sound reproduction. At the very least, the available evidence does NOT (absolutely DOES NOT) support the notion that cables heavily influence sound quality.
If you want to hear a real dramatic difference try running your signal through a tube pre-amp, that was a dramatic difference (amazing in some ways, but it also had it's problems - mainly in the bass).
This is irrelevant. What does this have to do with your speaker cables? And just as an aside, tube amps have MEASURABLE increases in distortion, which can easily correlate in the DIFFERENCE in perceived sound reproduction -- that is, we can measure the differences, and we can hear them. You can't say the same about speaker cables.
In audiophilia sometimes the most subtle things can make a big difference, for example some people will say they can't hear a difference when playing SACD, while others will swear that they can. I know there is a difference, and I'll be honest and say that it is small enough that the average listener will neither care nor notice. However for me it is a difference that really improves the musicality of what I am listening. After listening to SACD and LP, and I can easily say that CD is simply not as musical of a format.
See, now that's getting ridiculous. How can you possibly make a judgement of the FORMAT?? First and foremost, the master and engineering used to create the same recording in CD vs. SACD might be different. Engineers and studios know that people who listen to CD's have crappy speakers and they tend to use lots of compression so that they can use a higher recording level - subjectively sounds better on cheap setups. However, engineers might choose to use full dynamic range on an SACD because they know people with SACD players have better systems and expect that dynamic range. There's no way of knowing whether the same master used to record an SACD vs. a CD might result in INAUDIBLE differences between the two sources. Furthermore, SACD's use completely difference DAC schemes vs. CD - you could easily be listening to a CD player with an inferior DAC or an inferior analog output stage. Saying that CD is not as "musical" as SACD sounds like you're regurgitating marketing hype.
It has detail, in fact it even has a sense of exaggerated detail but it does not sound like music as LP and SACD do. Most people will not notice or care, and neither this hobby nor this thread is for them. I get the feeling that you are someone that does care, but that you are letting your skepticism get you to not explore the options out there.
I'm not a skeptic, I'm a realist. I have objectively evaluated the available data on the audibility of speaker cables and interconnects...and as an individual with experience in evaluating published literature, I can honestly say that there is no compelling data to support the claims of cable manufacturers. Like many people, I WANT to believe that cables make a difference...I would feel a lot better knowing that my signal isn't getting degraded by zipcord, and it would be nice to think that my interconnects are an integral part of my system. But there's one thing I don't do, and that's lie to myself. I'm not going to ignore the barrage of data that says "unable to find a difference" and emphasize non-blinded biased "listening tests" that describe sound improvements that don't exist. That's the reality of it. Yet, I still buy upgraded cables and wire -- again, because it looks cool. That's it, and nothing more.
Valsalva
I see what you saying about capacitance, inductance, and resistance. One thing to remember is that not all cables of the thousands out there have similar values for these parameters. The other is to consider geometry in that some cables are designed to reject more noise or have other characteristics due to geometry (there are so may factors that go well beyond those three basic parameters - such as skin effect).
Unless you have an abnormally noisy environment, the inducted noise into a properly shielded cheapo cable should be well below the noise floor of your electronics. ...and cables that are expensive and well-respected have LCR characteristics that are equivalent or no better than cheap cable - that's what i'm saying.
Another thing to keep in mind is that these 3 basic parameters can change in a cable depending on frequency and most tests are done at 1 khz.
I don't know who's feeding you this misinformation, but I don't know any half-brained engineer who would test a cable at a SINGLE frequency then draw conclusions from it. It's farcical to believe that.
If you have different frequencies experiencing different conditions in the wire then there can be timing errors. I realize that this differences are small considering frequency against the 3 basic parameters, but they can make a difference.
TIMING ERRORS? Do you realize that the phase aberration introduced by the crossover network is FAR GREATER than the absolute worst cable design you can imagine (and I'm talking coils and loops). The amount of timing error found in a worst-case scenario cable is SEVERAL ORDERS OF MAGNITUDE less than that expected by the crossover + drive + cabinet/reflections + listening room. Phase is absolutely irrelevant here.
Cables also provide impedence matching in some cases, in the case of a digital cable they need to be exactly 75 ohms including the connectors in order to not create minor reflective signals at the ends and create jitter (which is a big problem).
Oh boy. Yes, and 75.001 ohms can cause the entire timing circuit to disintegrate. Who is telling you this crap?
Valsalva
