Hardware to start mining
It's exploiting default configurations of the Claymore miner. You need to shut down the remote management feature of the software, or update to a newer version that defaults to read-only.
Probably a good idea to keep the wallet on a separate box than the miner as well, in case there's any other vulnerabilities found in the mining software where there is remote code execution or whatever.
I posted this on another forum. It seems there is a fix for the claymore hack. DL the software from claymore
Is NiceHash Legacy vulnerable? I'm currently running a Claymore Eth+Decred miner, and the banner just says "remote management enabled on port XXXX", no "Read-Only" like some of them used to say.
Concerned because my NiceHash estimated payout has dropped from $30 to $26.xx.
How much of this is mitigated by a NAT Router/Firewall? With UPnP enabled? Although, I have my other FIOS router in front, so I'm probably safe.
If you have the port blocked at the router, they're not going to get to it anyway. But I recommend either updating your software or disabling remote management for that machine, just in case. I disabled remote management since people were complaining that it was an exploit waiting to happen over a year ago.
-mport remote monitoring/management port. Default value is -3333 (read-only mode), specify "-mport 0" to disable remote monitoring/management feature.
Specify negative value to enable monitoring (get statistics) but disable management (restart, uploading files), for example, "-mport -3333" enables port 3333 for remote monitoring, but remote management will be blocked.
You can also use your web browser to see current miner state, for example, type "localhost:3333" in web browser.
Warning: use negative option value or disable remote management entirely if you think that you can be attacked via this port!
By default, miner will accept connections on specified port on all network adapters, but you can select desired network interface directly, for example, "-mport 127.0.0.1:3333" opens port on localhost only.
Someone just mentioned that download the newest software. And it's read only
I need some help here. I'm giving ETN a go to mine.
I downloaded the wallet cli. As of now, it's out of sync 93 days. I had it running for about 30 min to an HR or so.
And how can I sync it to my wallet?
I've already downoaded the paper wallet. And joined a mining pool.
Not sure about ETN but with Ethereum I've been syncing my wallet for almost a month now. I should have used a web wallet lol... made money but can't access it yet. I at least want to do a small cash in to make sure I'm doing everything right.
The syncing process is one of the things I think will be a huge long term issue with blockchain technology as a whole. At least until someone comes up with a crypto where you don't need the entire blockchain right away to do transactions. They also need to do a client-server implimentation. A wallet should be a simple client, while the server is what syncs the blockchain. So you should be able to connect to any server with your wallet. I think this would be the best approach imo. That's just a software thing though, I'm sure we'll see implementations eventually that work that way.
ETN is a pain in the butt. I've been getting help but so far nothing good so far. I just don't get why mining is so difficult. At least for me
So I am trying mining with nicehash and am wondering why my GPU doesn't sound like a leaf blower? I thought mining would be maxxing out my GPU...
Not always, depends on the algorithm, especially on an NV card. Sometimes, my GPU usage in Win10 FCU Task Manager, only shows 10-20% on some algos, on my GTX 1070 ti.
I noticed mine does not rev up to 100% either. I think it's normal. You can overclock but for now I decided not to touch that. Not even sure how to do it on Linux. I heard there's a tool called nvclock but it's not in the apt respository. This is the states for my 1070 TI:
Code:
==============NVSMI LOG==============
Timestamp                           : Tue Jan 30 23:15:09 2018
Driver Version                      : 384.90
Attached GPUs                       : 1
GPU 00000000:03:00.0
    Product Name                    : GeForce GTX 1070 Ti
    Product Brand                   : GeForce
    Display Mode                    : Disabled
    Display Active                  : Disabled
    Persistence Mode                : Disabled
    Accounting Mode                 : Disabled
    Accounting Mode Buffer Size     : 1920
    Driver Model
        Current                     : N/A
        Pending                     : N/A
    Serial Number                   : N/A
    GPU UUID                        : GPU-33c0c595-d42f-5419-b801-ef5ca27d4a86
    Minor Number                    : 0
    VBIOS Version                   : 86.04.85.00.9D
    MultiGPU Board                  : No
    Board ID                        : 0x300
    GPU Part Number                 : N/A
    Inforom Version
        Image Version               : G001.0000.01.04
        OEM Object                  : 1.1
        ECC Object                  : N/A
        Power Management Object     : N/A
    GPU Operation Mode
        Current                     : N/A
        Pending                     : N/A
    GPU Virtualization Mode
        Virtualization mode         : None
    PCI
        Bus                         : 0x03
        Device                      : 0x00
        Domain                      : 0x0000
        Device Id                   : 0x1B8210DE
        Bus Id                      : 00000000:03:00.0
        Sub System Id               : 0xC3001462
        GPU Link Info
            PCIe Generation
                Max                 : 2
                Current             : 2
            Link Width
                Max                 : 16x
                Current             : 16x
        Bridge Chip
            Type                    : N/A
            Firmware                : N/A
        Replays since reset         : 0
        Tx Throughput               : 2000 KB/s
        Rx Throughput               : 6000 KB/s
    Fan Speed                       : 44 %
    Performance State               : P2
    Clocks Throttle Reasons
        Idle                        : Not Active
        Applications Clocks Setting : Not Active
        SW Power Cap                : Not Active
        HW Slowdown                 : Not Active
        Sync Boost                  : Not Active
        SW Thermal Slowdown         : Not Active
    FB Memory Usage
        Total                       : 8112 MiB
        Used                        : 2507 MiB
        Free                        : 5605 MiB
    BAR1 Memory Usage
        Total                       : 256 MiB
        Used                        : 2 MiB
        Free                        : 254 MiB
    Compute Mode                    : Default
    Utilization
        Gpu                         : 100 %
        Memory                      : 100 %
        Encoder                     : 0 %
        Decoder                     : 0 %
    Encoder Stats
        Active Sessions             : 0
        Average FPS                 : 0
        Average Latency             : 0
    Ecc Mode
        Current                     : N/A
        Pending                     : N/A
    ECC Errors
        Volatile
            Single Bit
                Device Memory       : N/A
                Register File       : N/A
                L1 Cache            : N/A
                L2 Cache            : N/A
                Texture Memory      : N/A
                Texture Shared      : N/A
                CBU                 : N/A
                Total               : N/A
            Double Bit
                Device Memory       : N/A
                Register File       : N/A
                L1 Cache            : N/A
                L2 Cache            : N/A
                CBU                 : N/A
                Total               : N/A
        Aggregate
            Single Bit
                Device Memory       : N/A
                Register File       : N/A
                L1 Cache            : N/A
                L2 Cache            : N/A
                CBU                 : N/A
                Total               : N/A
            Double Bit
                Device Memory       : N/A
                Register File       : N/A
                L1 Cache            : N/A
                L2 Cache            : N/A
                CBU                 : N/A
                Total               : N/A
    Retired Pages
        Single Bit ECC              : N/A
        Double Bit ECC              : N/A
        Pending                     : N/A
    Temperature
        GPU Current Temp            : 65 C
        GPU Shutdown Temp           : 99 C
        GPU Slowdown Temp           : 96 C
        GPU Max Operating Temp      : N/A
        Memory Current Temp         : N/A
        Memory Max Operating Temp   : N/A
    Power Readings
        Power Management            : Supported
        Power Draw                  : 142.87 W
        Power Limit                 : 180.00 W
        Default Power Limit         : 180.00 W
        Enforced Power Limit        : 180.00 W
        Min Power Limit             : 90.00 W
        Max Power Limit             : 240.00 W
    Clocks
        Graphics                    : 1860 MHz
        SM                          : 1860 MHz
        Memory                      : 3802 MHz
        Video                       : 1670 MHz
    Applications Clocks
        Graphics                    : N/A
        Memory                      : N/A
    Default Applications Clocks
        Graphics                    : N/A
        Memory                      : N/A
    Max Clocks
        Graphics                    : 1911 MHz
        SM                          : 1911 MHz
        Memory                      : 4004 MHz
        Video                       : 1708 MHz
    Max Customer Boost Clocks
        Graphics                    : N/A
    Clock Policy
        Auto Boost                  : N/A
        Auto Boost Default          : N/A
    Processes
        Process ID                  : 2280
            Type                    : C
            Used GPU Memory         : 2497 MiB
It's kind of nice that these stats are easy to get though, since I'll be able to set alarm points when I setup my proper rig.
Thanks
Glad I didn't prematurely order a water cooler 😀
One more question, can I hold on to what I mine until BC goes up in value?
Like VirtualLarry said it just depends on the algorithm you are using. Here's a screen cap I just took of my RX480 mining eth using claymore's miner. As you can see my MSI RX480 is maxed out on core clock and memory clock but the fan is at a modest 57% and it is consistently at that level.
Thanks
Missed this question when I posted earlier. You can hold onto anything you mine indefinitely. There is no law saying you have to cash out at a certain time for USD or GBP or any other currency.
Of course. But if that coin u mine goes to crap, then ur holding onto essentially nothing.
That goes without saying but Paperfist wanted to know if he could hold onto his mined shares or if he had to sell them. I was just answering his basic question but you are indeed correct. If the coins he is mining now go to crap then he is out the money they were once worth. He can always transfer his mined shares to another coin that is more stable if he desires. I believe that is called currency trading.
I'm new myself to mining but what I plan to do is cash out about half of what I make then keep the rest so I can play the market a bit. Though I may cash out more like 80% as my main goal will be to try to get ROI on the equipment. Once I hit that point then everything else after is just bonus.
Bbhaag has the better answer .
What cards r u using to mine coins? Any coins u plan on mining?
Right now I'm using 1 1070 TI mining Ethereum, I have another 1070 that's ready to go but I'm building a dedicated rig, with custom case, so once that's ready I'll have both cards running in that rig, as right now my gaming machine is tied up.
I'd like to go with more cards but they're too expensive now because of the shortage. I will wait it out an see what happens. I want to eventually put 6 cards in the machine, maybe even 8.
I keep having visions of going YUGE and buying property and going solar, but reality is the initial capital for that is kind of crazy, and obtaining the hardware in a quantity that makes it worthwhile is too hard.
Stop gaming and use that card to mine.
