CZroe
- Jun 24, 2001
- 24,195
- 857
- 126
Originally posted by: sutahz
tl:dr
They asked for it, repeatedly, so who cares if you read it or not?
tl:dr
Originally posted by: CZroe
rant rant rant
rant rant rant
everything you listed is a pet peeve... not an OS failure.
just because you cant use the OS, or it's not "customized to your liking" doesn't make it a failure.
Originally posted by: Scholzpdx
All I heard was Waaaaaaaaaaaah about Windows.
Those are nothing. Literally I don't see any of those as a problem. UAC can be disabled like I said, so that's a STUPID point. Do you want it to be like XP where your PC can just get infected from pretty much anything? All Windows users wanted better security, and we got it. It works and it works great. UAC barely pops up anyway. What's your problem?
Bitch somewhere else about it.
rant rant rant
rant rant rant
Absolutely this. I have had absolutely 0 problems relating to the issues CZroe listed. Whining about things that, somehow, manage to affect you does not indicate them as OS failures.
Honestly, complaining the Pictures should be called Images because they're not always Photos? Really? Of course I agree with you because I have a number of images that are not photos and as a computer savvy fellow I'm simply used to the convention of calling such a folder "images." However, most non-power users (which is the majority of users) simply put photos in that folder which is why it's called Pictures, to make it easier for the everyday user. Same goes for Music/Audio, etc.
Complaining that the "Start" button is now a "Windows Icon." Again, really? I think the failure is such that you have some difficulty relating to your users that there exists a button there. Really, this concept is not difficult. Hell, if they don't want to click it, how about asking them to push the Windows key on their keyboards? That completely negates their having to locate and click it.
I could go on, but I'm going to be .. and your arguments are inane.
an instructional document can no longer refer to "Start" button, "MY" Computer or "My" Pictures and expect the user to follow along on both OSes.
Originally posted by: DangerAardvark
Anthony!
Originally posted by: evident
god this guy is a retard. i just want to punch his stupid expression off his face.
Anyone defending Vista is not a power user. I use Vista daily and have since launch and can tell you EXACTLY what Microsoft did wrong. I bump into them at every turn. Stupid, stupid, stupid.
Mojave Project my ass. I WISH they would have tried that shit on me.
Let's start with folder views then. Making selections in detail view while holding CTRL is an exercise in frustration with the default theme and selection color. You can't easily differentiate between selected lines and deselected ones, especially on an LCD and doubly so when viewing at an angle. SUBTLETY IS BAD. CONTRAST IS GOOD.Originally posted by: lxskllr
Well? Go ahead and list them.
I've used Vista since launch also, and the biggest problem I have is changing folder views.
The detail area off to the right of each file is sometimes NOT clickable to make file selections, which makes NO sense. The blank area underneath often does not allow you to perform an alt-click operation if you click to far away from the last file. Which wouldn't be so bad if I could, say, alt-click and paste in the control box...
THERE IS NO FREAKIN' CONTROL BOX! You can't perform an operation on the currently open object's window without BACKING OUT OF IT and clicking the icon, and yet they had the nerve to remove the "move up one directory" button (Backspace still works). No, the drop-down does not let me do the same thing nor does the "Back" button. For example, in in previous versions of Windows, you could alt-click the My Computer icon to access the Device Manager or Computer Management. If you open it and alt-click an empty area, you only get some of the same options. To simulate alt-clicking the same icon, you would alt-click the control box in the upper left corner. In My Computer, you could access Computer Management. In a folder, you could delete the current folder and it's contents as soon as you are done working with it without moving up a directory level. You may say "but the control box is still there! It is just invisible." You'd be wrong. Yes, you can still double-click an empty area to close the window just like double-clicking the control box, but the same functionality I described is NOT available. It's like MS forgot why it was there and only half-attempted to approximate its function.
Getting rid of the "Start" button only makes installations instructions for software more difficult to follow for users and makes instructions more difficult to give for tech support (ask me how I know). Telling people to click the Windows flag that is usually on the lower left hand corner of the desktop is sometimes so futile that I have to log in with Remote Assistance/Desktop because the user INSISTS that there is no logo/flag/button there.
Dropping "My" from the Documents and Computer objects fixes one of my pet peeves, but it also makes installation instructions more difficult to write (can't treat customers of both OSes the same regardless of the software's compatibility), as does removing the default Run menu option. It is MUCH more difficult to explain to the user what the windows key looks like to get them to press WIN+R and you can't solve that with Remote Assistance when they steadfastly insist that they don't have one. If they really don't, I can no longer tell them to press CTRL+ESC then R.
Despite the long overdue change (the "My" prefix should have been dropped with WinXP), document folder names STILL aren't corrected. Pictures should be Images because not all images are photos. Music should be audio because not all audio is music. At least they didn't call Videos "Movies" (iTunes is guilty of that) but, then again, neither did XP.
Now, when Win95 starts, there is an animation that is supposed to continue animating unless the system is hard-locked. Same for 98, 98SE, 2K, ME, and XP. Vista can sit on a blank screen for well over 30 seconds, as it did on my first Vista system (nothing was wrong, it was just a slow Athlon X2 3800+). Did they forget what the animation was for? On the initial boot, I gave it SEVERAL minutes before determining that it was hard locked (unresponsive to anything else) and forcing it off repeatedly until I gave up for the night and found it booted in the morning. Of course, I gave it a fresh install again after that and it took an eternity on the first boot again, only i finally knew to just give it 30 *MINUTES* before checking back. Black screen when booting normally = UI FAIL.
You know what else is a UI FAIL? Conditioning the user to agree and approve every pop up dialog to accomplish any minor thing they want to do in the name of increased security. UAC is good and I wouldn't disable it myself, but the average user is conditioned enough as it is already and this only makes them even more likely to go "Yes, yes, yes, OK, yes, continue, OK DAMMIT" until they've loaded the system with spyware and trojans. STUPID. Someone should be fired over such an oversight.
Now, the hardware accelerated UI (Aero) needs the equivalent of CTRL+ALT+DEL for falling back to 2D compatibility mode. Inarguable. *NEEDS* It also needs to be well known and ubiquitous. I've encountered the need hundreds and hundreds of times on multiple systems due to sleep issues, driver issues, other stability issues, etc. Often times the PC is not locked up and I can log in remotely to save my work and shut it down properly. Sometimes, I can't log in remotely and yet the system is still not locked up. If I could navigate blindly, I could shut it down. It responds to the power button and will sleep/Hibernate/Shut Down/etc, but you will be forced to shut down and lose all your work regardless. If Aero ends up causing data loss that would not have occurred without it, it is a weak link. If Vista were truly designed for stability, it would have popularized recovery methods for this Vista-specific scenario, especially if they want to promote its stability against XP's. Instead, I find crash after crash that I can unequivocally say would not have happened on XP. FAIL.
Don't get me started on Vista's Games thing that doesn't enforce any standards (installation directories, save data, etc) and also doesn't create corresponding program groups/Start Menu entries, has the WRONG ratings for EXTREMELY common games and more complicating/aggravating factors and problems than I can list here.
Microsoft failed at every turn. Even just USING Vista is a chore.
Originally posted by: Locut0s
I think he means Vistas User Account Controls. I never found them to be much of an issue and I AM a power user. I'll gladly type in my passwords numerous times for the extra security. If it's any major hardware install I'll log in as the admin anyway.
Nope. The problem is that it is less security for the average user because it conditions them to approve everything. Myself, I'm OK with it, but it's academic UI design that you don't condition the user to approve everything in the name of security. They won't differentiate between renaming a file or viewing system specs and executing a downloaded file or approving a browser plugin. It's the same dialog they had to click through and approve/dismiss to do what they wanted to do on their system before and they will see no difference when it truly matters.
The problem [with UAC] is that it is less security for the average user because it conditions them to approve everything. Myself, I'm OK with it, but it's academic UI design that you don't condition the user to approve everything in the name of security. They won't differentiate between renaming a file or viewing system specs and executing a downloaded file or approving a browser plugin. It's the same dialog they had to click through and approve/dismiss to do what they wanted to do on their system before and they will see no difference when it truly matters.
Originally posted by: Bateluer
Its funny how nobody remembers that XP took its own share of complaints and insults when it was released for being horribly bloated and slow. Rose colored glasses anyone?
Originally posted by: schneiderguy
I still don't understand all of the hate Vista gets. Windows7 is the exact same thing with a new taskbar and all of a sudden its teh best OS evar!1!!! Sure, it's better, but its not that much better![]()
I have no issues determining which file is selected and which isn't. Neither does my mother on her laptop.Originally posted by: CZroe
People claiming to have had "no problem" are not simply stretching the truth... they are LYING. Perhaps they have conditioned themselves to no longer consider forcing the power off a "problem."
Originally posted by: Mike Gayner
Yeah I definitely think that tech companies should always just do what they were doing 14 years ago.
Anthony!
I can't believe it took someone so long to notice!! As soon as I opened the vid I thought he looked familiar![]()
