GTX 980Ti finally launched - MSRP $649 - Reviews
Page 29 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Subyman
Moderator <br> VC&G Forum
Mar 18, 2005
7,876
32
86
To be clear, a topic posted in the Nvidia section does not mean there is license to bash AMD. I know this thread was created and has posts prior to the split, but going forward we need to keep this about Nvidia.
-Moderator Subyman
moonbogg
10,734
3,454
HOLY COW moonbogg, you are really turning into a serious custom water cooling junkie! HAHA.
What will really blow your mind will be what temps your 980TIs will run at maxed out when under full water. You will be pleasantly surprised.
I also agree with iiiankiii about reaching instability way before hitting thermal caps.
Just take your time and watch for instability.
So what you're saying is, I should put ICE CUBES in the reservoir and crank the voltage? :p
bepo
36
Feb 6, 2007
16,432
Just pulled the trigger on the MSI Gaming G6 overclocked 980 ti. As soon as I got the order through at Newegg, the stock updated to "Out of Stock," but they did charge my card, so hopefully I got in the window of availability. I would be a touch pissed if they charged me and then made me wait 4 weeks for stock to come in.
moonbogg
10,734
3,454
Nice. Congrats. Let us know how it does.
Feb 6, 2007
16,432
Looks great Atomic Playboy. What rig will you run it in?
A Sandy Bridge rig that's still serving me quite well. I5-2500K at 4.4 GHz on an Asus P8P67 Deluxe board, 16 GB RAM, SSD boot/game drive, 2 TB HDD for files and games I don't load as frequently. I also have a Soundblaster Z, but I only got that after I managed to break every sound out port on both the motherboard AND the tower, because I am an idiot (and 3.55mm jacks are surprisingly flimsy). My GTX 680 was getting long in the tooth, so it's off to a needy relative; can't be bothered to hang onto it for PhysX in the miniscule number of titles I have that support it. I figure the main system will easily pull me through until Skylake's second tier drops next year, and the 980ti should have a shelf life of several years, especially if developers keeping optimizing for consoles.
RaulF
844
Rumor on wccftech that Nvidia might be doing a price cut on 980 Ti :twisted:.
Come on baby, let the price was begin!
Majcric
1,409
65
Anything is possible but the 980ti seems to be already placed in a nice position among Nvidias own cards, and AMDs
RaistlinZ
7,470
9
I'm not sure why they'd cut the price. The 980Ti is still the better card at $650.00.
RaulF
844
I agree.
Weird article, maybe Nvidia trying to go for the kill with AMD.
Just wish the card I want was in Amazon and not newegg.
Mako88
129
They're not. It's just in areas where the prices were much higher than $649 US, like certain Euro countries, etc, where the true cost is closer to $750-800 when converted.
Gryz
1,551
204
Is it possible to increase the voltage on any gtx980ti ? Even the stock models ?
I have a fully watercooled system. Currently with a gtx680 with an EK-waterblock. I recently tried to overclock the gtx680. But it seemed I wasn't able to increase the voltage. I used MSI Afterburner to set the voltage (and clockspeed). I could overclock ~100MHz at stock voltage without problems. Anything higher would crash the videocard. I increased the voltage (with Afterburner), but even then, the videocard would crash at exactly the same core-speeds. It seemed like the voltage wasn't increased at all. I use HWMonitor to look at voltage (and temps, etc). HWMonitor would show the increased voltage. But I suspected that number wasn't the real number on the card. Sources on the web seemed to indicate that you can't overvolt a stock gtx680 at all. Unless you modify the bios, or do hardware mods maybe.
I didn't continue, because I was planning to buy a gtx980ti soon. Still hasn't happened.
I was interested in a EVGA HydroCopper gtx980ti. Which has a waterblock. Still unavailable. So maybe I'll buy a SuperClocked EVGA. Or a stock one.
I suspect that you can overclock and overvolt the SuperClocked models even further (also from other vendors). I will put my own waterblock on a gtx980ti, so the cooling should be fine. Which will allow me to increase voltage and clocks even further. If the card can be overvolted of course.
So my question is: can every gtx980ti be overvolted and overclocked as much as you want ? Or are there limitations for specific models ? Would a changed BIOS be needed ?
moonbogg
10,734
3,454
You can get a reference 980ti and then buy an EK water block and it will come out less than the EVGA model. I just installed some and it worked out well. The EVGA model uses the same EK water block but they tweak the appearance for an EVGA specific look.
Playing BF4 last night for about 30 minutes and the 980ti's topped out at 42c using the EK blocks.
Gryz
1,551
204
What do you mean, less ?
Less performance, less overclocking ?
Or lower temperatures ?
I know. The TitanX and gtx980ti use the same waterblock.
So did you buy 2 reference cards ? EVGA ? And you can overclock and overvolt them without special tricks ? What overclock are you running ? (Just curious. TIA).
RaulF
844
Less cost, if you have the water system already on your rig.
Hope that helps.
Gryz
1,551
204
Ah. Yes, that is true.
Stock gtx980ti is 750 euros here. Slightly factory-overclocked gtx980ti is 760-770 euros. Waterblock is 100 euros. Total cost 850-870 euros. The HybridCopper is supposed to be 890 euros (once it becomes available).
I'm still wondering if the stock gtx980s will overclock just as easy as the factory-overclocked gtx980ti's, once I put on a waterblock.
I understand that the factory-overclocked cards sometimes have different VRMs or other components, to improve overvolting or overvolting. But I was mostly interested in artificial limitations (like putting in max voltage, max tdp, etc in the BIOS).
bepo
36
Third time I've received the auto notify from EVGA for the hybrid and it's never in stock (even 5 mins after the email). Does it just sell out insanely quick or is there something I'm missing? I want to buy the card but it's never in stock :(
RaulF
844
Prob only a handful of cards show up for the hybrid and sell out fast.
Keep an eye on evga.com, they said they might have some tonight.
SolMiester
5,330
17
-Moderator Subyman
Where are we allowed to bash, err complain about AMD then?
RaulF
844
Wow really Sol!
How about don't, if that's your purpose for being on this forum maybe you should find another place to hang out.
