Originally posted by: CaiNaM
...and people complain about 2 slot solutions, lol.
no kidding. that thing is huge, might as well go with water cooling.
Originally posted by: Schadenfroh
Originally posted by: PrayForDeath
What kind of a CPU cooler are you using??!? Looks like an Aircraft engine :Q
i want it
Think thats bad?
This is what a friend of mine did to his 9800 Pro.
Physco Heat Sinks
Originally posted by: SirDude
*speachless*
Originally posted by: McArra
Case link for Shady. It is the official site. I don't know what stores sell it in USA.
For some people here I'm getting tired of saying this: THIS 120MM LOW RPM FAN IS VERY SILENT. LOW RPM= LOW NOISE---> BIGGER FAN= MORE CFM. LOW+BIG= SILENT BUT GOOD PERFORMER.
The Zalman ZM80D-HP can cool the cards without a fan. Is it quieter than no fan? 😉
Its still not "silent", as you said.
That's true. My $30 each 120mm fans @ 5v aren't SILENT. They still make some noise, albeit very very little. Thermaltake doesn't make quiet stuff. They just don't. They make cheesey overdone crap, that's all they've ever done.
Thermaltake HS is noisy... ok now a piece of metal is noisy... think whatever you want.
Originally posted by: THX
I wouldn't mount that fan directly ON the card, it will just create more turbulence, and more noise. Like someone else suggested get a Zalman bracket and hang it off that, putting some breathing room for the air to escape once it has hit the card.
How fast can you OC your 9800? My 9800np is @ 451/340 with a Zalman heatpipe getting some help from a ultra low rpm 92mm fan.
If you wanna be the king of silent & functionality get the Zalman heatpipe case, until then you're the king of overkill 😉
Originally posted by: shady06
thermaltake = kings of overkill
Hey, you should say: McArra, the king of silent overkill LOL!!
Originally posted by: Mellman
i'd suggest moving your case away from the wall a bit, give that hot exhaust somewhere to go...instead of against the wall where it makes it harder for the rest of the warm air to get out of your case.
Whats the dB on that 120mm?
