skyking
Just go through the prescriptive design and you either choose less than 8 lb per square foot or more than 8 lb per square foot.Maybe so. I can't find any mention of siding material in the prescriptive design guidelines unless it's used as bracing.
I had done my calculations assuming that I was going to be under 8 lb but basic framing is 7 lb with 2x6s and any of that concrete-based siding kicks it up over nine.
The solution is pretty simple, I just need to get an engineered set of drawings that everybody else that has any experience works with, and those engineers can waive their engineering wand and Viola!
Prescriptive design is necessarily conservative. You give Cletus a tool to design his house, and you give Mr inspector this same tool so that he can inspect it and be happy that it won't fall down on grandma in a high wind.
Inspectors rely on engineering to a great extent.
An architect could take my same building footprint and put giant glass across huge swaths of it. Not saying I want huge swaths of glass but they do it. They figure out the bracing elsewhere.
They also don't have to be as conservative as prescriptive design.
