FIREFOX ON SPEED: Firefox Speed Tweak
fs123
21
There is already a extension that does this and actually has a gui that lets you go in and tweak it out. Its simply called "tweak network 1.0" and you can find it here and here is a
screen shot
ebrevdo
It's easy to do this inside firefox:
In the URL bar go to:
about:config
set
network.http.pipelining - to true
network.http.proxy.pipelining - to true
network.http.pipelining.maxrequests - to some high number (100 is good)
Firefox will permanently save your changes to user.js in your profile directory
govtcheez75
2,932
hmm...just did the "patch". It seems to hang on the loading of pages for about half a second now, where before it started right away. Then when it's almost done loading, it'll show the entire page faster, which "seems" faster. I can't really tell for sure if it is indeed actually faster or not though. Maybe someone should do some before, and after benchmarks.
*edit*...I take that back. I just tried it without patching on another computer, and it has the same "hang" or lag for a split second....then the patched one loads MUCH faster. :D
Trikat
3,384
FireFox doesn't work well on my fairly new computer at all. I have no idea why. :/
I heard so much good stuff about firefox, but can't use it. Me sad.
daveybrat
5,816
1,029
Well, i finally tried it as well..........
OMG, Firefox is now on Crack!!
Pages load instantly. I guess i'll be using more of Firefox over IE from now on ;)
NoToRiOuS1
1,594
im a firefox lover but i still enjoy maxthon a little bit more....kinda wish there was a patch like this for maxthon...if both maxthon and opera had such patches.........well then its goodbye M$ and IE:D
NoToRiOuS1
1,594
so if maxthon is an IE based browser...am i to assume that it is vulnerable to all the problems that IE affected by?
on a side note...help me out ppl...whenever i click on a link, i want firefox to open up a new tabbed window...not a whole new firefox window...i looked in the options menu and changed some of the settings but im still having problems. can someone tell me where i can change the settings so that the links open up as tabs and not as a seperate window? i know this is off topic but any help would be appreciated.
So
25,923
17
Yes, maxathon is still vulnerable to all the usual IE exploits and bugs. As for the tab problem, look up 'tabbrowser extensions'
bigboxes
42,228
12,415
Well, this post convinced me to finally try another browser out (other than IE). Not sure what the final verdict will be but I am initially pleased and am in the tweaking mode. Just applied the patch and things are loading much faster. Thanks OP! w00t!
RagingBITCH
17,618
You can do it in IE too.
NoToRiOuS1
1,594
thanks...will look into the browser extensions one more time...though thats where i looked before...unless i just didn't see the right options.
