Originally posted by: Jeff7
Originally posted by: fs123
There is already a extension that does this and actually has a gui that lets you go in and tweak it out. Its simply called "tweak network 1.0" and you can find it
here and here is a
screen shot
That one doesn't install for me. It gives an error saying that it only works on Firefox versions 0.9 to 1.0. Odd, since I have 0.93, and based on my math, that does come between 0.9 and 1.0.
Jeff -
Strange because I loaded the patch and I only had the 0.8 version and everything worked okay.
After I read your post, I updated it to ver. 1.0. I thought I'd have to re-install the patch, but when I clicked the .exe file, I got a prompt to click the "undo patch" and it will be uninstalled, so it's still installed.
Just a suggestion, but why don't you update it to ver. 1.0, not just for the patch but for the improvements as well? Can't hurt, and you should notice a difference in quicker page loads after you've added the patch.
M.
