Modelworks
- Feb 22, 2007
- 16,240
- 7
- 76
he might be able to get around that by making electric part of the rent. Around here its common to Buy a huge house and rent out rooms to college students. $300-4000 for a room (with all utilites).
Renting out a room in a house is under a different part of the rules. Whenever you wall off a part of a house with its own entrance and the rest of the house not directly accessible by the new tenant then it becomes a whole different matter. The NEC is only concerned with safety and the rules require that the wiring inside the living space have a disconnect from the outside service wiring that is accessible by the tenant or a building manager . A subpanel in the living space doesn't meet the qualification because it isn't a disconnect for the service wiring, that would be in the panel in the main house. Installing a meter allows you to also install the service disconnect inside the tenant accessible space.
The requirement of 230.72(C) is specific to multiple-occu-
pancy buildings because the different units are generally in-
dependent of each other and access to the service
disconnecting means may be precluded because of locked
doors or other physical impediments that are inherent to this
type of building. Unless electric service and maintenance are
provided by and under continuous supervision of the build-
ing management, the occupants of a multiple-occupancy
building must have ready access to their service disconnect-
ing means and this feature has to be incorporated into the
building service equipment layout. Section 240.24(B) con-
tains a similar requirement for access to service, feeder and
branch circuit overcurrent protective devices.
