ShintaiDK
- Apr 22, 2012
- 20,378
- 146
- 106
I assume they have A/C the same as you assume they have an inefficient computer to begin with. Yes it is a whole other matter, it's a much more relevant and meaningful matter, is my point. If you are going to worry about electricity usage, you should focus on the things that actually matter.
I can run my terribly inefficient AMD computer for about 10 years straight and use less electricity than I use with my A/C in one summer. Even less significant, the difference between my horrible AMD system and an "efficient" Intel system is so small that I'd have to run it for 100 years or more to make the difference greater than ONE SINGLE SUMMER SEASON of A/C usage. I can't stress enough, the difference you are talking about is not relevant in the world we live in.
I'm not sure where you get your figures, a normal sized house has a 2000-3500W A/C unit. Even a single room window AC unit typically uses 1200W.
Much less people got AC than there is with PCs. And I dont hope everyone got such an inefficient setup as yours.
So your rationale is because you got a poorly insulated house and leak cold air. That we then should keep wasting resources and money?
I dont think you thought it through.
Also those 10Ws extra heat would have to be removed by the AC as well. So in your case the saving is greater than 10W.
Many small streams make one big river.
