Olikan
The trailers look 1000x better than what is in the alpha.
Trailers/tech demos, love to cherry pick high detailed scenes
Comparing 2 6970s to one 7970 ghz isn't too wise. Sure, I would take the 7970 ghz anyday. However, that doesn't mean it is a real upgrade. If you have 2 6900s then you should consider 2 7900s. That is always the case.
Actually, that is my point also. (so we're seeing it the same way)Comparing 2 6970s to one 7970 ghz isn't too wise. Sure, I would take the 7970 ghz anyday. However, that doesn't mean it is a real upgrade. If you have 2 6900s then you should consider 2 7900s. That is always the case.
My sentiments exactly except I have 4 GPUs, I'm in for a long wait it seems.Actually, that is my point also. (so we're seeing it the same way)
Until a single card can kick the crap outta my two cards, Im not upgrading.
When new titles are released, waiting for x-fire drivers sucks.
I mean literally remove one card from the equasion.Of course you can turn of CF/SLI even on dual gpu cards.
Ouch, this and the BF3 CPU test really show that AMD's lineup is aging fast(still playable enough though)
Just because a game runs like crap doesn't mean it looks good. Like Grand Theft Auto's horrific performance on PCs.
For Crysis 3: If you turn down the settings to get 95% of the image quality, do you double your framerate? If so, that just means the max settings are resource hogs.
sorry but I do not believe that. my E8500 even at 3.8 was pegged in that game even a notch below max settings. and my oced gtx560 se is almost as fast as your 6870 and in no way shape or form is Crysis 2 fully playable on max DX11 settings and high res texture pack at 1920x1080. even my oced gtx570 would drop into the 30s in many spots on those settings.
You only run the HIGH settings, that explains everything 😀I can video it and show you if you'd like.
I've installed both update packs, have the lastest updates to the game, run it on HIGH graphics settings at 1920x1080 and its completely playable for me.
I'm not saying I'm getting 60fps, but I'm sure not getting any stuttering.
Most games are like that these days.
Thank god I didn't buy a 7970/680. Likely this game will be like the original crysis, pointlessly taxing on hardware.
I will keep my fingers cross this game is the step forward (graphically) that the original Crysis was... but i have my doubts.
I also hope Crysis 3 gets back to the semi-open world of Crysis 1 instead of the defined corridors of Crysis 2.
http://www.youtube.com/watch?v=hmy0jhexvdw&feature=plcp
Full match playthrough.
720p - Low Settings with HD textures.
AMD Phenon II 965 w 1GB 560.
