100+ heat indexes for you too eh?
I got my 6950 doing better, I had undervolted 20%, I raised that to 12% and its doing better, Ill double check the number, but the heat is only up a few C, still under 80, and running at close to stock clock
~285 MHash 75C, 10% undervolted, stock 800mhz clock
-v -w64 -f90(its my HTPC)
I ran mine at 1v, 725 memory, 840 core, fan at 70% and temps steady at 62C. The flags -v -w128 - f15 giving a 330Mhash/sec. That was for mining only, I found that the system would freeze if I do anything else at the same time, but if I raise the voltage to 1.050v I don't have any problems.
With my current setup @ the current rate, is it even worth me continuing to pursue this?
I wonder what will happen to bitcoin, when AMD goes away from VLIW (next generation)...
AMD card = little profit
NVIDIA card = huge loss
A 5830 gets about 300 MH/s and draws a way less power.
https://en.bitcoin.it/wiki/Mining_hardware_comparison
97 degrees today, no way am I mining today.
I had to remind myself I was reading a post on a forum about electronic video cards.
Do most of you not have air conditioning? I am interested in the fiat currency aspect of this technology and the way it almost evolves into a direct exchange of GPU once a level of money has been hit. Sort of like a caste system.
i have a basement , which i might say is becoming a bit warm with this down there
Jen
I do !
Heck! I have 3 A/C units
One central A/C it can only fight 10c degree difference
Now my portable A/C can easily fight 30 c 80 % duty Cycle
With that much of cooling efforts being put then I come around and
Run computer which blowing HOT air like 52 c sheeeh I feel guilty ;(
Get you some a/c, profit!
