Finally got to delid my 3770K and the results are fantastic. I used Liquid Ultra on all 4 surfaces. CPU is @ 4.6GHz 1.31v
Before
After
The delta temp dropped 22.5c!
I do. The 2600k would do 5GHz without missing beat. For what I do, I need 3-4 desktop computers so the 2600k was already rotated out of my "fun hobby computer" and over into a "it works for a living" computer, but I can certainly rotate it back if need be.
As for your question - SB or IB - once power usage is removed from the equation, if the individual is not using the iGPU then I'd recommend a SB no question. It is a no-fuss no-muss situation where hitting good overclocks on economical air cooling is completely doable.
BTW. Does NT-H1 suffer from pump-out effect at IHS to Heatsink contact? A few months ago I hit 87C degrees with my mild OC which already seemed very high and right now I hit 98C in IBT. My cooler is zalman CNPS 10X and TIM is noctua NT-H1, those temperature seem much too high 🙁 I'm begging to suspect there's something wrong with my CPU's IHS. Either that or the cooler is not flat where it sticks to the IHS. It has two fans in push-pull configuration. AFAIR it was only 10C worse then the top coolers like nactua NH-D14.
Figured I'd ask here:
I just got my GF a Ivy Bridge i5 3570K (can't beat Microcenter deals) and plan on OCin'g it. I'm not aiming for any stars.
I picked up an CM EVO 212+ and will aim for about 4.4ghz-4.6ghz range.
Should I delid the processor or are temps in that range acceptable? Since she is getting the chip my main concern is noise/heat vs performance. She isn't as anal as I am about performance haha.
Great thread IDC, really enjoyed reading it.
Not sure how close an EVO 212+ compares to an NH-D14, but I was able to OC to 4.5GHz with my NH-D14 before delidding/lapping and the temperature was 82°C (1.18V).
So I have to imagine you can hit 4.4-4.6 with the 212+ while staying under TJmax.
The thing that is a real concern as you mention is the noise. The following is data for my 2600k, but it applies just as well to my 3770k:
Depending on your mobo's fan control profile, the noise will get noticably loud once your CPU's temperature crosses a threshold (70°C for mine).
That alone is where the benefit of delidding and reducing your peak temperatures by 20°C yields dividends.
Yes it does. But so will just about every other TIM out there other than IC Diamond. Liquid metal will, too, but being a liquid at all times means it just reverses the pump-out on cooling so it is irrelevant. But NT-H1 has been reported by a number of people as perhaps having the most pronounced pump-out issue.
What do you recommend, should I reapply Noctua TIM after just 6 months? Obviously there is something wrong with my CPU and/or Cooler because those temps are way too high for a modest overclock on SB. Right now temperature hits over 70C even at stock settings (3.7GHz). That temperature would be fine for a stock cooler not a tower cooler that trails Noctua NH-D14 by 10C.
Yep, reapply. And clean out your HSF fins while you are at it.
If you don't want to deal with the rinse-repeat cycle down the road then you could go with some IC diamond and do the "once and done" dance. That won't prevent the dust build-up though.
I just ordered a tube of IC DIAMOND 7 CARAT + is it the same TIM you're talking about? I can't find any other IC diamond TIM in my country. Doing something in my computer is such a pain, it's very cramped, 3 cards being the main culprit, I want to mess with it as little as possible. Thanks for the help. I'll post temps with IC diamond and see if that helped.
BTW. How much of that TIM should I apply on the IHS? Your pictures show bare die which is certainly different then IHS.
Yep, thats the TIM. The carat amount is just the volume you buy, 7 carat is a smaller tube than 24 carat, the diamond per volume is the same.
Apply the same as you would any other TIM. You can get too little though, so be careful about trying to spread it too thinnly.
These days these TIMs are all about finding the goldilocks amount - not too much and not too little - so a nice dollop is in order.
I would also suggest to not use ic diamond straight to the die. Would it not scratch it?
IDC can u do a Delta T of ambient.
Take another probe and take the ambient temperature at the air passing though the radiator in the time you take a load temp.
And give us a Delta T.
I would like to use your data, but would need it to be constant.
I dont care. I'm about to do this to another 3770k but with the noctua nh-D14. I'll post some pics. I'm going to use your numbers. ALso there was a post on here about someone doing this on a noctua nh-d14 so I thought great it will seat perfectly on the die. I did a mark transfer to see how it would seat and guess what. No marks. If i put a little paste on there it will mark, so there is not a good contact. So The stock plastic washer are probably 3mm too high. I'm going to use washers and drop the distance 3mm since i is spring loaded and give it a try.
Edit here it is. I saw this was referenced on anandtech here to this website about this cooler and the delidded process.
http://www.overclock.net/t/1249419/pcevaluation-intel-i7-3770k-temperature-measured-without-ihs
Yeah. i was going to put some electrical tape at the base to protect the MB, and use the washer method like you did on here. But if you look at the guy who did the test with the Noctua he's using the stock base plastic hubs. There is no way unless he modifyed it and there is no mention he did this.
Pic is from pcevga forum
Absolutely fine. Noctua knows what they are doing and it shows whether you are looking at their NH-D14 coolers or their NT-H1 TIM. I even used NT-H1 on my GTX460 when I delidded it and remounted an Accelero XTREME Plus.
(I sound like a damned spokesperson for Noctua D: but I swears I'm just calling it like I sees it)
