Baltimore’s Francis Scott Key Bridge collapsed after being hit by a cargo boat.
Nov 17, 2019
13,294
7,875
Bridge collapse live updates: 1st portions of bridge to be lifted Saturday
abcnews.go.com.ico
ABC|54 minutes ago
Highly trained demolition crews will begin cutting the top portion of the north side of the collapsed Francis Scott Key Bridge into smaller sections for safe removal by crane. One crane barge and one working barge are staged at the incident to support Saturday's operations.
Torches? Cutting charges? Some kind of super shears?
This ain't no job for recip saws.
BoomerD
66,238
14,660
abcnews.go.com.ico
ABC|54 minutes ago
Just remember...they have to take it apart very carefully so it can be put back together again to save money and time...
BoomerD
66,238
14,660
Likely will use cutting torches for most of it. Maybe angle grinders for odd spots, etc. That steel has to be thick AF though.
Torches...sure. Grinders aren't likely to be used...too time consuming. I thought I saw a picture of some piece of equipment similar to an excavator equipped with a large shear head. NOT certain it was headed for this job.
Reactions: Pohemi
Nov 17, 2019
13,294
7,875
The crane is on a barge on the water and rated at 100,000 tons, so I'd imagine other tools are similarly oversized.
Shmee
8,210
3,126
Sounds like this was a failboat.
eelw
10,333
5,487
Back to Elmo and REUSE!!!! The parts of the bridge that’s still up, wonder how much structural damage there is?
hal2kilo
26,012
12,259
They will probably use those big cutting torches with lots of inert gas to blow out the molten metal. Very impressive if you are near one at a shipyard.
Reactions: iRONic and Pohemi
Pohemi
10,875
16,958
Even if they rebuild the exact same bridge, I would be surprised if they did not remove everything old (that didn't fall).
iRONic
8,320
3,628
When I worked offshore as a helicopter mechanic I watched a crew install a drilling rig on top of a production rig. Same type of barge with the crane just like what they're using there. They welded that shit straight to the top deck! They welded everything else right to the first level!
They came back eight months later and cut it right off. Three weeks later you would've never known there was a drilling derrick on top of that production rig.
Reactions: Pohemi
Zorba
15,613
11,255
This is clearly a major safety issue if any non essential electrical component can overwhelm ship controls.
It has to be something different.
Speaking of this ship was made by Hyundai Heavy Industries, how come no one anywhere is talking shit about Hyundai and what very well could have been a manufacturing/design failure, while we get national news every time a 25 year old Boeing aircraft has a flat tire.
Should also be talking about the shit regulations that allow these massive ships to only have one source of electrical power, steering, and thrust. A 30 second black out would never be allowed on any aircraft, modern aircraft can transfer buses without even making the lights flicker (and do at least 4 times every flight).
Reactions: Pohemi
