Hi all. I would like to modify one of the recommended builds for a different purpose -- primarily photo editing. It is a gift for my wife. How would you modify that?
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
-- Primarily photo editing for my wife as well as microsoft office stuff for work for both of us.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
--Willing to spend around 1300 including the software that we can't get cheap. Note, I can get Microsoft office Pro for like $25 bucks through work. I do not think I can get an operating system (though maybe I can pull out that old XP disk I have .... not sure if I have the code for it though).
3. What country YOU will be buying YOUR parts from.
--USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
--None
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
--Yes, I have two monitors, a mouse and keyboard that I like. The build would have to accomodate two monitors.
7. IF YOU plan on overclocking or run the system at default speeds.
- default
8. What resolution will you be using?
--Not sure what this question means.
9. WHEN do you plan to build it?
-- Around New Years..
Let me know what you suggest. Also, if you could suggest PC photo editing software that would be great. Should I just get Photoshop?
Thanks!
