ATI card to use FlowFX like cooling system
jtcartboy357
7
I don't see what all this fuss is about. It seems quite simple to me enmic or whatever the heck the company is called is going to "offer" a powered by ATI card with a flow FX system on it. Even though it is not a necessary component as of yet on any ati card even the R350. Also if one would like to they can purchase the cooler the same as one can pruchase a Zalman Heat Pipe and put it on their GPU. WHereas the new GeforceFX has to have the dustbuster 2003 on it or else it will overheat.
prontospyder
I'm looking at their current Radeon 9500/9700 Pro cards on Enmic.com and they have standard coolers. Not sure why they're going with those FlowFX coolers since they have been getting a bad rap recently from enthusiasts.
RaynorWolfcastle
8,968
16
Something to consider:
- Though this card hasn't been tested for noise levels, they state that it will be operating between 600rpms and 1500 rpms. Hell Panaflo L1As spin faster than that, with a properly balanced fan these should be extremely quiet. Keep in mind that the maor problem people are having with the FlowFX cooler is that its too damn loud.
- It still eats one of your PCI slots just like the FlowFX so it still has that drawback
Say what you want about the FlowFX and this thing, I'd buy them if they were quieter than standard cooling solutions, I'm sure others would too.
SexyK
1,343
4
This is not that big of a suprise, Abit was using this system MONTHS ago on their Ti4200 OTES card, people just assume all systems like this are "bad" because nVidia paired it with a 7000 rpm fan. Its actually a pretty good design IMO, and i'd buy a card with one if it kept heat out of my case.
ElFenix
102,402
8,574
its all just a ripoff of abit anyway.
ati card still implies that the card was manufactured by ati, when it was not. powered-by ati would be most accurate
since nvidia does not manufacture cards (and we know this) its also known that when someone says nvidia card they're refering to a board manufactured by someone other than nvidia.
VirtualLarry
56,587
10,225
There's nothing wrong with that. It's still an ATI card. Just because it's made by Enmic doesn't mean anything. It's still an ATI card. Nvidia doesn't make cards, just GPUs. Does that mean that an ASUS Ti4200 isn't an nvidia card? Of course not, it's still an nvidia card. Just like the Enmic is an ATI card.
I'm sorry, but you've got some pretty strange logic going on there. Does that mean that every motherboard ever made with an Intel 440BX chipset, is an "Intel motherboard"? Not quite.
And for the record, Nvidia *does* make cards. The key factor here is, they don't sell them into the retail market, as that would compete directly with their 1st-tier chipset customers. They only sell them (cheaply) to high-volume OEM integrators (Dell, etc). They may not even physically mfg the cards, they may outsource them.
As a form of proof, I have a totally-generic looking GF2 MX AGP card, that has "NVidia" on the PCB itself, and an FCC ID that seems to indicate that it was made by NVidia themselves.
MadRat
11,999
307
They ought to flip that squirrel cage motor around so that it sucks air from across the card. It would cool card components as it sucks in air.
LeeTJ
4,899
Enmic != all ATi cards.
No one said that. Just said that it's an ATI card with a FLow FX cooling solution. Yes, it's an ATI card. It sure as heck isn't an Nvidia or matrox card. It's an ATI card. Some people read way too much into some things.
actually, it's an Enmic card w/ an ATI GPU.
w/ Nvidia, you can call any card w/ an Nvidia GPU an Nvidia Card because Nvidia doesn't make it's market it's own cards. ATI does, so to call a video card w/ an ATI Gpu in it built by an OEM, an ATI card IS misleading.
LeeTJ
4,899
Originally posted by: TonyB
yeah all those people putting down the NV30 flowFX cooling system pretty much should be feeling dumb now.
why?? how many ati cards use this? how many nvidia cards use such a cooler?
can you reasonably buy an ati card w/o a flowfx type cooler? can you reasonably buy an Nvidia FX card w/o one??
ElFenix
102,402
8,574
dell actually gets their nvidia cards from some company no one has ever heard of. even if they're outsourced nvidia isn't making them.
chizow
9,537
If you really want to get technical, ATi doesn't build the majority of their cards either, Sapphire does. At the 9700pro's launch, > 90% of ATi's "built by" cards were actually manufactured by Sapphire. I'm sure this % has only increased since ATi has been moving away from fabbing their own pcbs for some time.
yes.
yes.
Acanthus
19,915
ostif.org
so you all think when gpus hit 500+ mhz they are still gonna be able to use 1/2" thick heatsinks and tiny fans?
give it up, videocards are gonna need heatsinks like cpus soon, they should just use bigger,quieter fans. Rather than high-rpm screamers.
ATi will be taking up 2 slots soon too, just like NVIDIAs future cards will also require, the heat has to go somewhere.
Spicedaddy
2,305
77
So does the DustBuster enable the 9700 to be overclocked to 500MHz, like it did for the Geforce FX? :p
chizow
9,537
Originally posted by: Acanthus
are there 3ghz wilamettes? :p
D'uh, everyone knows if you buy a really loud fan you can overclock your 1.5Ghz Athlon XP Palomino and turn it into a P4 Northwood 3GHz.
Chiz
Acanthus
19,915
ostif.org
exactly what i was getting at, The 9700 pro chip (unless they added about 40 layers) could never reach 500mhz without some kind of supercooling, comparing a .15 chip to a .13 chip is exactly like comparing a northwood to a wilamette. Only in this case the Wilamette is faster >< .
Markfw
May 16, 2002
27,256
16,113
IF they were quiet, I would buy one too, as I don't care about the slot (empty so no IRQ conflict), and I don't want the heat in my case. I know in the future, cards will just get bigger and hotter. And I would love to see the heat go outside the case..... But most importantly, NO NOISE !! NO DUSTBUSTER !!!! and then I will buy one.
McCarthy
Problem with the dustbuster is noise. Loss of the PCI slot is annoying, but not a big deal for but a few and no problem for most. NOISE is why it's mocked.
Since we don't know how loud this is it's not even that funny for me, personally. Cuz that's the comparison, not the design.
FishTankX
2,738
Hello, people! This thing spins up to a *max* of 1500RPM while the Dustbuster Ultra 5600 spins up to an earth rattling 4000+RPM. And since noise=RPM^2 I think this sollution will be well within the acceptable range of everyone. Infact, if you have a well venthilated case, this thing will spin at 600RPM. And i'll tell you all, that's quieter than an undervolted panaflo. Blowers are not loud by design. Most spin at low RPMs, like this one. I believe this is a *good* idea. It's a slow spinning high flowrate cooling system. Where's the problem?! Read the article!
Nemesis77
7,329
Originally posted by: thorin
No big surprise. But I bet all those ATI fans who put nVidia down for the fan on their 0.13um cards are feeling dumb now that ATI is going to end up doing the same thing.
Thorin
Try engaging your brain before engaging your mouth. The cards powered by Ati-chips have variety of different cooling-methods. One manufacturer uses heatpipes and passive cooling. This particular manufacturer chose to use FlowFX-wannabe. However, 98% of all cards with Ati-chip is going to use normal-cooling. In short:
- Card-manufacturers are free to use whatever cooling-method they prefer
- "Normal" cooling is more than enough for any Ati-chip, and most manufacturers stick to it
- Some manufacturers prefer more exotic methods
- This manufacturer chose to use more exotic cooling-method
- But the fact remains that normal heatsink and fan is more than enough
- And the fact remains that excluding two exceptions, all manufacturers use normal cooling.
Nemesis77
7,329
Originally posted by: chizow
The irony and double-standards in this thread (and on this board in general) are amusing:
nVidia releases preview GF FX Ultra boards with reference PCB and cooling to reviewers. Despite knowing and acknowledging nVidia doesn't choose the cooling or design for the end-market nVidia graphics cards, fanATics go apesh!t and AT forums are spammed to no end with photochopped links and school yard humor.
Here are the facts:
ALL GF FX Ultras are sold with the dustbuster. That is a FACT. The Dustbuster was the product NV sent to the reviewers. The ones without the dustbuster are regural FX's (the "even slower FX" ;)).
People laughed at NV because:
-If you want a FX Ultra, you have to get the dustbuster as well
-There is a FX with no dustbuster "available" (still haven't seen them anywhere), but it's considerably slower
Fast forward to today:
An actual AIB maker, albeit an obscure one, releases specifications for a nearly identical cooling solution that will actually be implemented on their shipped retail products, and said fanATics resort to semantics and grammar in attempts to discredit the poster.
The difference is that if you want a 9700Pro (or 9800Pro), you can get it with "normal" cooling. If you want a FX Ultra, you have to get it with that ridiculous cooling-solution.
Nemesis77
7,329
I wonder how many people it's occured to that you can't get built by ati cards in europe and other parts of the world. Not everyone reading this board is in North America, you know.
You mean Ati-branded vid-cards (as opposed to Hercules, Sapphire etc.)? I can buy an Ati vid-card just fine in Finland.
