AMD peeps... post your mult x fsb settings
well i forgot to mention, that the temps where still a lot higher on the abit board than on the epox board.. with the same chip, memory, case power supply etc the cpu temps for the abit was on a 1.5v where as the epox was using a 1.75v from the bios, which is also slightly lower (unvolted sort of thing...)
how on earth did you manage to get to that speed? i cant get to 2.3ghz on my epox board without having problems and that was rev 1.1... was that a bad thing or a good thing?
how do i know whats a good cpu and whats a bad one?
Originally posted by: JConforti
11.0 x 213 (2343 mhz) running Prime 95 stable.
34C at idle, 41C under full load.
nice little machine there man and welcome to Anandtech. With anandtech you can make a page that has your specs on it like this from here
oops
I booted at 5 x 100 yesterday for some extreme power!
Normally run:
12.5 x 180 (is also stable at 12.5 x 184) 1.74V and 1.85V respectively
Gigabyte 7vaxp
t-bred 2100+ 0303
single 512 corsair pc3200 at lowest settings
10.5 X 166 = 1743mhz
XP 1600+
Epox 8k5a2
single 512mb samsung 2700
i was wondering because i don't have a board that unlocks processors, and i dont forsee doing it myself.... my board doesnt have a 1/6 divider, so anything above 166 puts the pci/agp outta spec and things get squirrely. so, if i were to put in a different processor in the future... say a Barton 2800+, i wouldnt want to overclock by upping the fsb any higher than 166. so, would i then use a higher multiplier instead? Bartons come at 12.5, right? so i could use something higher, such as 14 or 15? are there any problems with doing this?
i know some boards don't allow those higher #s. they're actually obtained by using a 6 or 7 or whatever as the multi, and i believe this board is one of those, right?
deadseasquirrel
currently 10.5 x 222
NF7-S v.2
AMD barton2500+ Havent cut the bridges yet(waiting to replace my alpha)
xmspc3500 512
second rig
11 x 220
NF7-S v.2
xp1700+
OCZ pc3500 256 x 2
Epox 8rda w/XP2100+
11*200
I just did the vdd mod and everything is running fine at 200. I will try for more later. For now I am going to make sure everything is running as it should.
la la la
10 x 230
ram async (75%, = 171mhz fsb)
its ghey, i have pc3200 ram, but its super unstable, my board's gone whacky ever since my psu blew up
i cant even do 80% (184mhz) or 83% (191mhz)
ram would do 11 x 200 sync, but that's it, no more
i had a 550w that died, now im using an old gateway 200w psu, and i SWEAR its sooo much better!!!!
Originally posted by: AkumaX
la la la
10 x 230
that's why i always say quality over quanity
if you want a good one go with the allied true 450W from newegg or the fortron 350W from directron.com
they are AWESOME psu's that won't blow up on you when they hit 450w or 350w
la la la
10 x 230
I don't understand this post. You say RAM "will do" 11x200 sync (200MHz, right?), but then you say you "can't do" 191MHz?
I think you're getting something wrong maybe trying to set FSB too high (230?)...
If you can do 230x10(async), I don't see WHY you couldn't do 200x11.5 (sync)? Doesn't make sense.
Originally posted by: Whitedog
"HyperX2700 @ 2-2-2-6-1T "
I wan't your memory... 😀
bah!
you can find nice pc3200 that'll do 2-2-2-6 or even 5 @ 200 mhz !!! that's much better 🙂
the twinmos/winbond ch-5 is around 90 bucks at memoryx.com
it can do around 244 mhz @ 2-3-2-7 or 2.5-3-3-7 ... 44 mhz o/c for a stick a ram is pretty impressive...
la la la
10 x 230
actually i can do 11.5 x 200, but doesnt "feel" stable (ram in sync)
10 x 230 feels a little snappier w/ dc enabled
and yes, when i do 230 for the cpu, the ram can't do 191 or 184, only 171 (in async), but can do 200 (in sync)
i dont think its the ram either... i think it had something to do w/ when the psu died... i've done 220 in sync (with different ram) but not after it blew up... 😛
oh yeah, 31c idle and 38c load
8rda, (before = geil 3500c2, now = generic 3200)
slk900 + 120mm toyo strapped on
When I set up new hardware I always run Sandra memory, memtest86, prime95, 3DMark01 and UT2003 benchmark to verify stability and figure out which settings perform the best.
i ordered some new stuff for my mobo in order to get to that 240 mhz mark...
a new nb fan - vanteq iceberq pro w/ blue LED
and a zalman zm-nb32j for my sb...
hope these will help squeeze a few more mhz out of my board...
oh.. an di have to wait for my new RMA'ed stick of ch-5 twinmos 🙂
And you tried to get me to buy some of that ram too... tisk tisk.. 😛
hehehe i got a bad stick.. it happens!!! 🙂
i think it'll run great once i get it 🙂
my bh-5 can do 225 mhz no sweat 🙂
Dumb question here, but how do you guys get such a high FSB? I can't go past 166 no matter what I do.
Athlon 1600XP
MSI KT4VL
Samsung PC2700
-Nate
12 x 209
temp readings.. i'll update soon... new bios fixed temp issue.. should read somewhere in the mid 40's now 🙂 @ 2505 mhz... not too shabby
