Page 111 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
BFG10K
22,709
3,005
This thread was started in mid 2021 and is being retired/locked. As the OP is no longer active, or updating and maintaining it.
Mod DAPUNISHER
8GB
10GB / 12GB
  1. It's the player's fault.
  2. It's the reviewer's fault.
  4. It's AMD's fault.
  5. It's the game's fault.
  6. It's the driver's fault.
  9. Wrong area was tested.
  10. Wrong games were tested.
  11. 4K is irrelevant.
  16. It's an anomaly.
  17. It's a console port.
psolord
2,142
1,265
10GB VRAM at 1080 very low ☠️
Sir, please don't omit information. You got this from here.
It clearly says:
Please read the conclusion on how the game engine manages VRAM.
And the conclusion is here
and says
Our VRAM testing shows that Star Wars Outlaws will use a ton of memory—when it's available. On cards with less VRAM it does a reasonably good job at memory management. Our results confirm this, the RTX 4060 Ti 8 GB runs at virtually the same FPS as the RTX 4060 Ti 16 GB, even at 1440p and 4K.
and here are the results
psolord
2,142
1,265
If I ever have to define what "reductio ad absurdum" means I'm linking to psolords posts in this thread!
If you want to see denial, see the above post and add this to it as well.
Looking at 4060ti 8/16, you will need even more correct settings to make it playable, meaning even less vram, which is already irrelevant.
The 4060ti is effectively on 6800XT level. I don't see its 16GBs helping. The 4060ti 8GB is 38% faster than the 7600XT 16GB. Who is the abserdum here?
Wukong reached 2.5 million users on steam and will go higher. Please show me Deliver Us Mars at 1440p Ultra+RT to show the 20 people that played it how bad 8GB cards are. JFC
psolord
2,142
1,265
Which varies by user and is subjective.
It is a matter of human biology my friend. Sure not everybody is the same, but we are not slugs to be ok with 30fps. Seriously we had 60fps decades ago in the arcades. We are not going to backtrack now. I certainly will not.
psolord
2,142
1,265
It's not that hard in theory. Upon launch, they could simply check VRAM and if it's insufficient for the high quality assets, do the downscaling/downgrading on the gamer's PC in real time as a one time process. Then they don't need to include several different quality texture assets with the game. Should reduce game size even.
And that would lead to some cursing from the dude when he tries to run such a game on his old hardware with 8GB GPUs: "Time remaining: 48 days 10 hours 33 minutes and 9 seconds...".
8GBs are a huge amount of data and it's really sad that people do not get that. They can fit glorious looking textures. All that is needed, is for the dev to not try to render sub pixel sized 4k textures on a 1080p display, for which these cards are aimed at.
With UE5 even low textures look good. From here
Why? It's called asset streaming and has been a thing for decades, only now it's done better.
19,203
Question:
Why haven't they mentioned which NVMe drives they are using? And why two of them? Are they configured in RAID 0? This could be an attempt to mitigate the effect of a slow SSD to get a better picture of a GPU's performance potential without any I/O effects coming into play but then this will also prevent the fps from dipping because data can be provided fast enough to the GPU during texture streaming. Point is, this doesn't reflect a typical use case for the majority of users. This is basically a best case scenario and it would fail to show any effect of VRAM running out. A card with enough VRAM would be able to keep frame rates higher with more I/O pauses while something with lesser VRAM could run out of data and then have to wait for data, causing an fps dip.
So is the dude advocating that someone spend $400 for a 4060 Ti 8GB GPU and then splurge $1000+ on the rest of the PC?
WelshBloke
33,288
11,421
Honestly I can't exactly work out what the hell you are trying to prove.
The basic premise of the thread is that modern games are requiring larger and larger amounts of vram and that whereas 8gb might have been fine a few years ago it's now a bottleneck on performance.
You however seem to have taken offence at this for some reason and are entirely happy to die on the hill of finding a combination of GPUs that are bottlenecked elsewhere as if that proves that vram doesn't matter.
I mean you do you but clearly (as someone that's just played Diablo4 for a bit that's sucking up 15gb) it's a weird stance to take.
MrTeal
3,919
2,708
It is possible to incorrectly interpret the title of the tread to mean that 8GB is insufficient for any new game under any circumstances, and then spend the next 3 years railing against that despite no one actually claiming that's the case.
WelshBloke
33,288
11,421
I mean I'm impressed that he's put this much effort into arguing that other bottlnecks occur when no one else has ever argued that they don't.
I'm not sure that I've ever been so invested in anything as much as he seems to be invested in this!
19,203
He's a true visionary!
Expect that from a person who enjoys Jensen Sparkling Water and makes sure to touch the Book of Jensen every night on his bedside table before dozing off!
Reactions: Tlh97 and marees
marees
1,994
2,627
Please recite before booting up RT heavy games:
“Our Lord Jensen blessed us with silicon
that enabled people to build games
that look so pretty,
even if it has issues
that are partially due to
Nvidia’s influence on the developers.
We must look past them for we are lost without him.
Amen”
Iron Woode
31,331
12,840
Why anyone would want textures popping in and out or worse, muddy textures, all for the sake of "correct settings" on subpar VRAM cards in new games makes absolutely no sense to me.
So, are we all in agreement that he is wrong and needs to stop posting this nonsense?
marees
1,994
2,627
I have a question
Is UE5's virtual shadow map of nanite the kryptonite for low vram cards, when there is fast camera movement necessitating textures not yet loaded to be pulled from outside the cache ?
DAPUNISHER
32,180
32,796
I have made the motion several times to lock this thread. As the OP rage quit, and ghost is the only dissenting opinion. The members have majority responded they prefer the thread stay open each time. Ghost also puts a great deal of effort into defending their position so it isn't like some low effort trolling is going on.
Reactions: Mopetar
DAPUNISHER
32,180
32,796
I have a question
I watched their vid on the topic a couple of days ago. Interesting stuff.
Reactions: Tlh97 and Ranulf
marees
1,994
2,627
I would consider any card with 8gb vram as not suitable for 1080p high / 1080p ultra gaming.
Of course if you spent $400+ on acquiring such a card, you could somehow play at 1440p by playing around with several settings.
But you shouldn't have to do that. An 8gb vram card should only be used 1080p medium. That is $200-$250 range. Of course TSMC fab prices & fast gddr memory prices are increasing. So maybe $300 for 8gb vram card, if grudgingly, can be tolerated
Anything $350 or above should be atleast 12gb vram
Anything $500 or above should be atleast 16gb vram
Anything $700 or above should be atleast 20gb vram
Fortunately 20gb vram has been sufficient as of today for gaming purposes.
blckgrffn
9,687
4,348
www.teamjuchems.com
I am fine with it. It reminds me of the silly debates back in the mid 2000’s. Nostalgia and always a thread update for me to wonder at :)
blckgrffn
9,687
4,348
www.teamjuchems.com
Anyone not wonder why he is only one? I mean, where are his friends? Why aren't they supporting him? Is he the only one in his community who plays videogames?
I think the user count here is too low. Which is actually nice, because its not a sea of strangers. Just like a little backwater of strangers, some of whom have been kind enough to DM me and be less of stranger and are now an Internet acquaintance :)
And many that I have seen post for 5-20 years and so I get an idea of how they think, which is also cool.
For me, some of my friends IRL I can and do argue with about trivial things like this, so I am not sure that would help either :D
DAPUNISHER
32,180
32,796
I literally just read the same nonsense he spews on TPU forums. Either he has a different username there, or there are others still repeating those tired taking points from the old days when textures were not a hugely differentiating feature to consider. And GPU power really was quite frequently more important than vram quantity. As we have lived. died. repeated here so often; Textures are arguably the single most important IQ improvement while costing very little to no impact on performance in modern games. Frame pacing issue, muddy textures, textures not loading, pop-in; all among the most egregious IQ issues and all caused by low vram. When everything else is identical between cards, more vram FTMFW in late 2024.
Those forums are a reality distortion field anyways. It's is obvious Intel swag and ad revenue influences the staff and their postings. And they have accumulated the most fanatical pro Intel following I've seen. We are talking copium overdose levels. Some of the stuff I read there is straight up alternate reality and or denial of reality nonsense, just like the contentions being made in this thread.
Or as your observations apply to me in particular, you get an idea of my random synaptic firings that can hardly be considered thoughts at all. :p
19,203
Wow! Good thing their forum results rarely (if ever?) show up in my searches so never needed to read crap like that.
Reactions: marees
DAPUNISHER
32,180
32,796
Make no mistake, there are some seriously great posters, cool people, and they really know their stuff. I learn a lot reading the threads. Unfortunately they don't police shilling and trolling like here, so flame wars, insults, and massive thread derailments are prevalent. Here is the post I read -
https://www.techpowerup.com/forums/threads/2080-super-vs-3060ti-used-purchase.325922/post-5319211
Sound familiar?
Mopetar
8,510
7,766
I wouldn't pay more than $200 for an 8 GB card. At that point just get an APU and save yourself some money. The APU might not have as many cores, but if the VRAM is going to be a limiting factor in so many cases going forward, why spend the extra money?
I'd also knock $50-$100 off your suggested prices. I should be able to get 16 GB with a $400 card. A $300 card should have at least 12 GB.
Sound familiar?
A little, but there weren't five consecutive posts filled with charts arguing a completely different point so I don't think it's the same guy.
The 3060 Ti wasn't a bad card when it came out, but games have changed a lot since then. At launch there weren't many titles that would use more than 8 GB, some even in 4K. I even argued that it made a decent entry-level 4K card for its price if you didn't need to have the best frame rates for the games you were playing.
However, the new console generation increased the amount of memory that games could utilize and easily allowed for more than 8 GB to be dedicated to video memory without squeezing the rest of the game. As the old saying goes, software is a gas that expands to fill the available container.
yepp
403
38
Some of the texture work in Wukong is absolutely terrible for 2024, got to stay in that 8GB buffer lol. It's almost like some kind of texture streaming/LOD bug. Game is pretty decent but way overhyped on Steam, it's on around the same level as the much underappreciated Surge 2, Metacritic score of 8/10 is fair. Nioh 2 dances circles around this game even without a jump button.
20240830092059_1-jpg.106524
Both HUB and DF mentions how bad some of the textures looks:
Status
