For obvious reasons do not do this in the garage!
For frig's sake, whoever told you that and actually works as a professional mechanic should have their knees beaten in.Second time they told me I should use 92 octane gasoline for two full tanks in order to remove the carbon buildup in my engine, then I could go back to 87 octanes.
Originally posted by: OrganizedChaos
you got scammed, if engine has a knock sensor test it.
more than likely: built of carbon deposits raised the compression ratio of your engine just enough for it to ping, all you need is a can of seafoam or some of that amsoil power foaming stuff. some say a glass of water will do the trick but i personally think this is half-assed.
1. remove vacuum line
2. suck up liquid of your choice
3. don't stall engine.
4. don't hydrlock engine.
5. shut down for 5 min
6. start engine
7. enkoy smoke show
8. enjoy your now perky engine
optional : beat the fvck out of the guys that replced your A/C compressor in winter.
Originally posted by: wayliff
I brought my 2001 Chrysler Town & Country to the dealer because the engine had a pretty loud ping.
First time they replaced the AC compressor and told me the problem would go away.
Well...the problem was still there.
The manual says that the recommended gasoline for this engine should be 87 octanes.
While researching on the internet I found that using 92 octane gasoline could actually harm my engine.
Premium Gasoline
Certain high performance engines benefit from use of high octane fuel. For other engines, using a fuel with a higher octane rating than the vehicle requires sends unburned fuel into the emissions system and catalytic converter. This puts unecessary stress on the emissions system. For some vehicles, a rotten egg smell coming from the tailpipe signals use of too-high octane gas.
Also found that all gasolines should have the same detergents and cleaning agents to clean your engine, so one should not have to switch to clean the engine.
Regular Unleaded Gasoline
The recommended gasoline for most cars is regular 87 octane. One common misconception is that higher octane gasoline contains more cleaning additives than lower octane gas. All octane grades of all brands of gasoline contain engine cleaning detergent additives to protect against engine deposit build-up. In fact, using a gasoline with too high of an octane rating may cause damage to the emissions system.
Would anyone have a clue on the following?
1. Why would the dealer tell me to do this?
2. Why are considered high quality 87 octane gasoline distributors?
Thanks for your help.
In the meantime the van has the first tank of 92 octane gasoline and it is going quite faster than the regular one. No ping heard though.
Premium Gasoline
if the pinging went away with the higher octane gas then the gas is the problem.
make sure your getting a quality gas that doesnt contain ethanol
mobil and amoco are usually pretty good but look for the sign on the pump.
higher octane means it has additives to make it less flammable so it ignites at a higher temp.
ping occurs from premature ignition, this can be caused by several things.
its when the gas in the chamber explodes before the piston has reached top dead center, so it can also cause quite a bit of damage including broken pistons in extreme cases.
timing could be slightly off, may need a tune up.
your car has several sensors that tell it when to fire, if one of these is getting bad reading then it could also cause it.
take it to a professional mechanic. dont go to the stealership
runner hotter then you should be can cause it.
Originally posted by: Toastedlightly
Another vote for seafoam... but use sparingly. I ran a bottle through my tank and my engine stopped pinging (3.1L v6). Just make sure you don't use too much, as it may clean away deposits that are stopping leaking.
Originally posted by: Skoorb
BG44k is good, but costs about 3X the price of techron concentrate. It is harder to find, but when I bought mine I just called up some dealerships and eventually found one that sold it at a Jaguar dealership. I think my local nissan was also in the habit of using it, but had none in stock.
I have to really recommend not going back to that dealership. Telling you to replace the AC compressor, then saying "it needed it anyhow" when that doesn't fix the problem is despicable. Also that idea about the octane really was stupid!
Originally posted by: smithdj
Running 92 or even 93 (where available) will not fix the problem. The only "quick" okay not too expensive possible fix is to have the intake manifold clean which will clean the carbon deposits off of the valves and the tops of the pistons. The dealer should not be a cheap a$$ and do it for you. They hook a bottle full of cleaner stuff (cant remember the brand) to the intake via a vacuum line and let it burn through the engine, it takes about 20 minutes. The bad side, where do you think all of that crap goes? Right down the sides of the pistonsSeriously, have them do this, if not for free, it should cost $40
Did you use it through the gas tank or actually used the vacuum line method?
6. start engine
7. enkoy smoke show
Originally posted by: Citrix
come to colorado where 87 octane doesnt exist. your choices are 85,90 and 92 octane.
