Page 987 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
19,218
Could the additional 30W be to feed the extra V-cache die?
I'm hoping it's a newer, more refined V-cache die with slightly more bandwidth.
StefanR5R
6,851
11,029
The most important chart from there, in my opinion, and the corresponding 285K chart: [...]
For those who haven't read the article yet: As far as I have registered, it contains some good discussion of how Zen 5 and Lion Cove have similar yet different bottlenecks in game workloads, furthermore game workload traces put in contrast to SPEC traces, and also some IMO enlightening bits about games versus inter-CCX traffic. Finally somebody who, rather than merely speculating about the latter effects, did some actual performance counter based monitoring.
ToTTenTranz
959
1,576
That 4% advantage example is a super dubious claim for the benefits of X3D in transcoding. Thats margin of error stuff. I'd bet adding a second vcache die would not add another 4%, if anything at all. Certainly nothing worth the extra $100-$200 (15%-30%) that they will surely be asking.
What about putting 2x VCache dies underneath one of the CCDs? Can't they stack?
Give one CCD access to a whopping 160MB of cache.
MS_AT
941
1,866
Advocates of dual x3D chips might not like the conclusions. On the other hand, I wonder how the author has handled the internal game settings for SMT. As the game by default, in theory, should use 1 worker per core for 2CCD chips. It should be now possible to modify that in the options, but I never really tried to see what these are really doing. Still I wonder if anything could interfere with manually setting the affinity + whatever the special chipset driver is doing. Especially that the very last plot suggest, that by default almost all the load is rather contained on one CCD, within SMT threads.
fastandfurious6
984
1,092
what is easily observable during any bench + hwinfo is that the boost core changes every second
t1: core 13 5ghz
t2: core 6 5ghz
t3: core 7 + 10 5ghz
. etc. not efficient
the assumption is, scheduler throws too much work over random cores, waste
Josh128
Banned
Oct 14, 2022
1,542
2,295
t1: core 13 5ghz
t2: core 6 5ghz
Thats a function of the CPU to sustain high 1t boost frequencies. The CPU "hands off" the load between preferred cores to allow cores to rest & cool while others take up the load. Max frequency is sustained much longer by doing this. The algorithm is so efficient that there is basically no perf loss from doing it. This has been the case since at least Zen 2 on the AMD side.
Hail The Brain Slug
3,890
3,331
A few very interesting benchmarks here
Besides the obvious efficiency numbers, Halo has better absolute CPU performance in quite a few ML/AI workloads, Gromacs, Palabos, GPAW and other stuff.
I'd like to have seen the Granite Ridge parts tested in eco mode.
In the testing I've been doing against a strix halo mini PC I have, once I enable eco mode on the 9950X3D it performs similarly (they are workloads that don't benefit from strix halo's design) and draws similar power from the wall, even with the big desktop idle overhead.
I imagine outside of the workloads that benefit significantly from strix halo's unique configuration, it actually isn't significantly more efficient than granite ridge at lower power.
LightningZ71
2,698
3,396
From what we know, it's the same cores and the same node. There shouldn't be much of a difference in non bandwidth limited scenarios.
Hail The Brain Slug
3,890
3,331
All the proclamations of a big efficiency advantage really seem like, for a lot of cases, it may just boil down to comparing something pushed way out of the pocket of the V/F curve against the same thing right in the pocket.
MS_AT
941
1,866
Do you mean that, at idle, the Strix Halo draws a similar amount of power from the wall as a desktop part despite the SoC reporting lower power consumption? Or are you saying that if you enable Eco Mode on the 9950X3D, it will draw a similar amount of power under load as the Strix Halo does under load?
Reactions: Thibsie
Hail The Brain Slug
3,890
3,331
I have seen workloads where my 9950X3D with 88W PPT draws 190 watts at the wall and completes work slightly faster than strix halo in 120W mode, also drawing 190 watts at the wall.
The power per core in this specific case was only 3.1 watts for the 9950X3D, but 6.5 watts on Strix Halo. I assume it's at a disadvantage from the memory latency, unless something else is going on with it.
9950X3D was sustaining ~3.8GHz while the Strix Halo sustained ~4.3 GHz. It's memory intensive, but not bandwidth intensive, hence the thinking maybe the incredibly high memory latency from the LPDDR5X is at fault.
Edit: The workload was compiling unreal engine. It doesn't benefit very much, maybe 3.25% from V$ on the 9950X3D. Nothing significant. Other related workloads varied back and forth a bit, but in my line of work there was nowhere I found a compelling performance or efficiency advantage for Strix Halo.
Geddagod
1,683
1,720
Has anyone checked Zen 5 L3 latency vs Zen 4 btw? I remember AMD saying in some slide that it stayed the same or improved, however I remember some aida64 pic showing that it got worse.
Looking at the impact of switching to mesh vs ring is bound to be some what interesting for Zen 5.
There should also be a way to compare power between ring and mesh too- perhaps by subtracting CCD power vs core only power? IIRC AMD does have software power reporting for both of those metrics.
Geddagod
1,683
1,720
47 cycles (i.e. it's the same).
does the mesh run at the same frequency as the ring in previous gen? The ring boosting algo for desktop is IIRC ring frequency = frequency of highest boosting core, and in mobile it's some specific ratio of the highest boosting core?
Hail The Brain Slug
3,890
3,331
Good review. The Framework included cooler isn’t that good other than that looks good.
Kinda weird, my mini pc with the same cooler that most of the other ones have never throttles. It looked like frameworks heatsink was going to be better than that cooler that's making the rounds in the other designs.
19,218
This is a fatal flaw with LPDDR5X. Sure, when on battery, it should run as-is but when on AC power, it should switch to low latency power burning mode. Always conserving energy was just a bad engineering decision. It badly needs a turbo mode.
poke01
4,881
6,222
How good is the memory controller on Strix Halo? As far I know it’s not very good and AMD had trouble with this.
There is a reason why it’s stuck to 8000MHz as well. The latency issue is probably exacerbated due to this
