Page 986 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Josh128
1,542
2,295
Only way this will really be newsworthy is if this SKU manages to unify both CCDs and L3s to form one 16 core coherent CCX. Apparently that is out of the question, so the use case for this consists of basically nothing outside of bragging rights.
That being the case, Im more curious about the new 8 core version. Would it be more likely that its a "9700X3D" that is clocked lower out of the box, say, 5.0 GHz, or a "9850X3D" that clocks higher? Out of the box 5.2GHz seems is already not that reliant on highly binned CCDs, so it would be interesting if they pull off something cool like a 5.5GHz out of the box boost. An "XT" style refresh if you will.
Reactions: Thibsie and Joe NYC
ToTTenTranz
951
1,575
I think there'd be more market for a Threadripper where one CCD got VCache than there will be for a Granite Ridge getting 2 CCDs with VCache each.
And perhaps software video transcoding?
Josh128
1,542
2,295
That 4% advantage example is a super dubious claim for the benefits of X3D in transcoding. Thats margin of error stuff. I'd bet adding a second vcache die would not add another 4%, if anything at all. Certainly nothing worth the extra $100-$200 (15%-30%) that they will surely be asking.
Josh128
1,542
2,295
Watch one be around 9800X3D speeds and the other be around 9950X3D speeds so you end up with a ~7% difference between CCDs anyway.
It's AMD. You know they want to.
Almost certainly wont be both a 5.7 boost. They do that and this really will be the enthusiast halo approach, and the price will be eye watering.
Hail The Brain Slug
3,890
3,331
The use case for this consists of basically nothing outside of bragging rights.
I've been doing zen 5 x3d vs zen 5 performance comparisons with Unreal - engine compiling, shader compiling, cooking assets, building HLODs, etc and the V$ seems to provide anywhere from 3-10% uplift. A dual V$ chip would provide some measurable improvement overall for this.
Hail The Brain Slug
3,890
3,331
I will hate them with a vengeance if they do that now. I seriously will. I spent over $800 for my lame 9950X3D :mad:
For their sake, I hope they don't do that.
I just ordered a second 9950X3D for a new unreal workstation. Amazon already charged me but I managed to still cancel it when I saw the news this morning. I'll rob the 9950X3D out of my gaming rig until this CPU materializes (or doesn't)
eek2121
3,482
5,176
Yep, it provides a bit of an uplift in certain developer workloads, gaming, and more. The dual CCD part likely won’t add much more performance, however the TDP is higher, so all-core clocks will also probably see a slight boost. It wouldn’t surprise me if it received it’s own numbering scheme (9955X3D or something similar)
MSRP will probably be around $999.
Hail The Brain Slug
3,890
3,331
All of the workloads I mentioned are embarrassingly parallel and should benefit to various extents from the second CCD having cache.
Of course, an extra 3-10% on top of a 9950X3D hardly justifies $1000, or $900, or even $800.
Heck, the 3-10% gain a 9950X3D has over a 9950X in my workloads doesn't justify the currently 30% price premium ($670 vs. $515)
However, I have found cases working with Unreal where the scheduling puts it on the frequency CCD when the workload actually would benefit measurably from the cache CCD, and in some cases I haven't found any way for me to fix that since it's not managed through thread affinity and process lasso would do nothing. Actually while writing this I remembered the UEFI should have a preference toggle for cache vs. frequency CCD, I should try that and see if it helps.
Edit: It did, but it didn't. Now it just round robins the threads between both the cache and frequency CCD. I suppose that probably gives the best uplift since now there's one worker per physical core.
Hail The Brain Slug
3,890
3,331
Do you have gamebar installed? Can you put the Unreal engine EXE on gamebar, making it think it's a game?
I just realized this is the fastest way to do the work, 16 workers with one per physical core is faster than 16 workers on 8 cache cores. I should do some further testing to see how much having two cache CCD's would speed it up vs. having the scheduling improved this way.
Josh128
1,542
2,295
They will probably do both, consumer and Epyc 4005 models.
Hmm, now that you mention it, nothing about this leak says Ryzen...being AMD likes to disappoint the enthusiasts and all, I bet the dual X3D chip is merely that, an AM5 compatible EPYC SKU. Probably not going to be for consumers at all.
gdansk
4,776
8,071
Hmm, now that you mention it...being AMD likes to disappoint the enthusiasts and all, I bet the dual X3D chip is merely that, an AM5 compatible EPYC SKU. Probably not going to be for consumers at all.
Doesn't matter. It's AM5. It would be nice to launch it as an Epyc to avoid gamers thinking they should buy them.
