Page 948 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
LightningZ71
2,654
3,339
Yeah but we need 512MB of that. At least I won't be satisfied till that happens
In general, the miss rate on a last level cache halves as the size of the cache quadruples. For example, if your hit rate on a 512Kb cache was 90%, your miss rate would be 10%. If you doubled that cache twice, to 2 MB, you would improve the miss rate to 5% and the hit rate to 95%. It would make a noticeable difference only in programs that have a hot working set that now fits in the expanded cache, but spilled before. Those are very general numbers for x86 code as the effect is still HIGHLY dependent on the hot working set size of each program.
Be aware that, for every doubling of cache size, you are going to introduce additional access latency as well as additional latency in any memory operations that result from a miss when seen from the program itself, OR, you will make the design of the cache more complex, taking up more area, resulting in additional product cost. Eventually, you just aren't making any useful impact in working set latencies and will have to resort to LOTS of predictive extra data loads from main memory to attempt to preload the cache with data that you think that the program will need next. This burns up a lot of energy making memory calls that are often unneeded.
I think that AMD is currently happy with their L3 cache ratio and may look to maintain that ratio into larger CCXs with respect to VCache packages.
Reactions: Tlh97
19,204
This should be exposed as a BIOS option and let the users make that call. I personally have no issue burning a few extra watts for maximum performance.
LightningZ71
2,654
3,339
I vaguely remember from long ago that there were processors that had bios settings where you could turn cache prefetch on and off. It's been a minute, I've slept since then, and there may have been an alcohol or two in my system along the way, so that's about all I have at the moment.
19,204
Cache prefetching is available in some Intel BIOS (turning it off causes a serious performance hit). I haven't seen it in the Epyc BIOS though.
MS_AT
919
1,840
It should be available on AM5. Usually the option can be found from AMD specifc menu but your mileage may vary, depending on the manufacturer.
Markfw
May 16, 2002
27,375
16,217
from techtechpotato stream or somebody shared a link to japanese site around the same time, that reprinted most of the slides if I remember correctly. In the stream you have both the article (skip backward) and the presentation slides.
Bottom line, which is better, 18a or N2 ?
19,204
With all of this said, if AMD gave us the option to have 3D V-Cache on both CCDs so that we could avoid having one set of lower cache and one set of higher cache cores, I think a lot of folks would be interested.
fastandfurious6
859
1,017
I went ahead and tried out on-CPU AI performance, mostly just for the fun of it. Armed with 64GB of RAM, I was able to test deepseek-r1:32b at an average token rate of 3.346 tokens/s.
not bad at all
Thunder 57
4,243
7,038
But... anyone who thinks they want that is ignorant and a fool.
I never said that. I know a lot of people want to see it. I just don't think it'll end up resulting in what they expect.
Look at the 9950X3D. It's no better in productivity than a 9950X in just about everything. Why would a dual Vcache version be any different? It would just be a waste of Vcache when AMD can't keep them in stock.
Hail The Brain Slug
3,889
3,329
That you feel singled out here is extremely telling.
StefanR5R
6,819
10,900
What would be better
The answer is trivial: The operating system and the userland gets to deal with sixteen homogeneous cores.¹
Or, what @Win2012R2 said while I was distracted.
Even on regular dual CCD CPU's one chiplet is binned better and runs at a higher frequency.
Not in EPYCs AFAICT.
________
¹) although split into two last-level cache domains, a problem for which at least EPYC 7000 and 9000 BIOSes offer an optional NUMA setting; don't know about EPYC 4000 BIOSes
Reactions: Win2012R2
