Page 943 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
StefanR5R
6,851
11,029
About Threadripper and EPYC, mounting the CPU and mounting coolers:
  • Difficult? Wrong. Just different, compared to the tiny sockets.
  • Easy, in fact. IME very very painless to do. I was pleased about the process.
    And you know what? This is not coincidental.
    "Necessity is the mother of invention."
    They made the mechanism so that folks can assemble racks and racks full of servers quickly yet correctly. Time is money.
  • And lastly, this is not AMD specific. A few other vendors have very large LGA sockets too. (Personally, I have only dealt with AMD's yet myself, though.)
PS: Sometimes it does help to read the fine manual. :-)
Philste
308
486
First Test of Krackan Point: (German Notebookcheck).
https://www.notebookcheck.com/Asus-...itaets-Boost-oder-nur-Marketing.960264.0.html
Btw, Krackan Point Devices basically went available he same day Strix Halo dropped, at least in Germany. Now we see why there were no Reviews.
CPU Performance in MT tied to Phoenix/Hawk Point at Best, in Geekbench it falls back to Lunar Lake lvl. ST only 12% uplift over Hawk.
Graphics is just complete Destruction, 2K flat Timespy, worse than 760M in Ryzen 5 Phoenix Devices, getting stomped by 2 Times with every other x86 APU released since Computex 2024.
Battery life worse than Meteor Lake NBC took to compare. Now we know why they dropped it silently without any reviews.
branch_suggestion
897
1,955
It has the shiny NPU which means it is the cheapest part with the MS slush fund tech.
And yes, it means it sucks at everything else, go figure.
Reactions: Tlh97
Philste
308
486
Not really, this one is 999€ for a basic cheapish Vivobook with most basic screen without SRGB and tiny 40Wh battery. You can get Snapdragon X Plus Devices for much less (not that I want one of them either).
I hate this NPU stuff so much, thx to MS we now get this abomination in <1k Devices which gets beaten by 2 year old 600 Buck Devices of the same manufacturer.
adroc_thurston
8,571
11,303
that's just a bad device.
Philste
308
486
Overall Yeah, its a cheap device that shoild be avoided, but in terms of APU stats? Maybe for battery Life, but the rest? It can run at least 40W sustained, judging by the sustained 70W device power draw in stress Test probably even more.
Overall it lands where I expected it, but that's the problem, I already expected bad things.
Philste
308
486
that's far far far past the KRK falloff range.
It's a 20W part.
I know that, but AMD decided to make it the successor of all Ryzen 5 and 7 parts and leave Strix at Ryzen 9 only. It will be compared to 8845HS because at the end of the day AMD themselves named and positioned it that way (15-54W cTDP).
DrMrLordX
23,223
13,303
Actually +12% ST over Hawk Point isn't too bad. Kracken is meant to be cheap, not necessarily good. Hawk Point is currently AMD's answer to Intel's 10nm mobile spam, all Kracken has to do is be cheaper then Intel's Intel 3/4 mobile products and be functional (and readily-available).
Let's be honest, nobody is gaming with this thing except out of curiosity or desperation.
That's a little surprising, though that'll come down to specific configurations and battery size. Tale as old as time in the mobile sector. If you look at the power draw graphs, it looks like Kracken is using more power than the 8540U and that's a little concerning.
Reactions: Tlh97 and r.p
Abwx
12,025
4,988
  • Screenshot 2025-03-02 at 20-28-31 Asus Vivobook 16 im Laptop-Test KI-Features im Fokus – Produ...png
  • Screenshot 2025-03-02 at 20-37-02 Lenovo ThinkPad X9 15 Aura Edition Laptop Review - The MacBo...png
MS_AT
939
1,859
Check MemBW, somebody figured out that soldering 5600MT/s would be a good idea... To make it even funnier, it's single channel (well dual channel in DDR5 terms, but Strix Point gets 4).
Abwx
12,025
4,988
He say that this KRK laptop, wich has a 42Wh battery, has way lower endurance than the 99Wh equipped 155H comparison...
Beside it s soldered 16GB SC but there s a slot to add 16GB for the second channel.
DrMrLordX
23,223
13,303
Okay there you go. Also it looks like the OEM set Kracken far above its normal TDP range.
Kraken is a low cost option, so it'll probably get more than a few single-channel configs.
Abwx
12,025
4,988
This one is dual channel, you just have to add a 16GB sodimm to get to 32GB, as for power it s configurable down to 27W.
  • Screenshot 2025-03-03 at 03-11-40 Asus Vivobook 16 im Laptop-Test KI-Features im Fokus – Produ...png
Philste
308
486
Because the 99Wh one is the only device in NBCs Comparison:1000009719.jpg
There you go, also 125U with 512ALU iGPU might be an even better comparison for Krackan, but it also loses to Hawk Point with battery size normalized. And the 155H one might have a 140% bigger battery, but look at the results, 140% to 219% longer runtime. Krackan is the worst at least for this test.
How does the TDP matter in Krackans conclusion? Ok, you shouldn't take efficiency measurements from this device, but for general performance it's fine, because the absolute performance doesn't get worse with a 40W limit eben if it's MT sweetspot is way below that. Ok, single channel is an Issue, but more on that later.
Also we live in a time where even Ultrathins like Zenbook S16 run at 28W sustained. Only OEM that i really know that still runs below 20W regularly is Lenovo in the cheaper Thinkpads.
Krackans "normal TDP Range" is the same as Strix' and every predecessors before, namely 15-54W with the option to basically going open end. Is that a bad decision? Yes, but at the end AMD still took it.
That's the main Problem: It isn't low cost. I just looked at Zenbook 14 Configs before posting this because it has Hawk Point, Krackan and Intel all in the same Chassis.
Krackan is a 1:1 replacement for Phoenix/Hawk Point from a price perspective. That Cheapo Vivobook 16 NBC tested costs 1k bucks and you get Single Channel RAM, crazy cheap display with bad colours and brightness and a Keyboard without backlight.
I'm afraid to say it, but a Zenbook 14 with Ultra 7 255H and 3K/120Hz Windows 11 Pro is only 200€ more than the same device with AI 350 and FHD/60Hz Windows 11 Home. It's literally 1399€ vs 1599€ while Hawk Point also costed 1399€ when released a year ago.
Reactions: Mopetar
DrMrLordX
23,223
13,303
I was more referring to the Cyberpunk: 2077 comparison, where Kraken is burning more power than the 8540u. By a lot. It's not supposed to be configured to run at those power levels. It can be, but it's really supposed to be a ~20W TDP SoC.
Hawk Point is pretty ubiquitous and cheap by now. If Kraken can stay at that price level then it should find itself in plenty of laptops in the $500-$1000 range.
It shouldn't be a $1k laptop. Something is definitely off there.
Philste
308
486
What I meant is that Krackans MSRP is the same as Hawk Points MSRP when it was new, has nothing to do with what Hawk costs now. It's a 1:1 price tier replacement, nothing more, nothing less.
Like I wrote, in Zenbook 14 configs you can see that it is same price as Hawk Point and barely cheaper than ARL-H. Personally I would even say ARL-H is the better option in price/perf.
Hitman928
6,754
12,500
Your math is off. When battery capacity normalized, the MTL laptop battery life is 33% shorter in the Last (load) test, 2% longer in the Wi-Fi test, and 35% longer in the offline H.264 test. It's also just almost impossible to judge a chip from a single laptop test. There are many knobs and variables the OEMs adjust or ignore that can drastically change performance and battery life. I'll reserve judgment on the chip until we get a few more laptops tested at various price points.
Reactions: Tlh97 and Markfw
Philste
308
486
Yeah I normally don't look at these load tests. It's not a real battery test, more of a test which manufacturer puts what TDP in standard mode. Pretty useless in my eyes, let alone the fact that 99% of x86 Laptops land below 2h, which is nothing. I looked at Video and Browsing tests because it's actually a specific workload and at least kinda comparable.
