Page 937 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
sl0519
58
151
66
fastandfurious6
861
1,018
Strix Halo in 1.2kg tablet
33db is dead-quiet and 45db is refrigerator hum
Halo @ 70w = 7945HX3D @ 115w
temps on full load are pegged at 70c, total ~65w + ~65w
CP2077 QHD Ultra is super demanding, fps shown are without FSR + FG, with those it's 100+fps on perf mode
we have a winner
511
5,228
4,682
StefanR5R
6,819
10,900
From the Zen 6 speculation thread:
According to this Tweet, the CCD in Strix Halo is indeed 66 mm2.
And according to measurements, Granite Ridge CCD is 70 mm2.
Now, is Strix Halo's CCD different from Turin's CCD too?
So, perhaps, AMD really made a bespoke CCD for Strix Halo.
Looking at the die, and the short side shrunk implies GMI is gone
Not 'perhaps'. It is one.
TSV columns are gone too!
Are you going by artistically rendered "die shots" (into which I for one wouldn't read too much into), or by additional information?
sl0519
58
151
66
Can you see the split wattages for the CPU and GPU? Reviews looked good because they were comparing Halo products to older Intel and Ryzen parts, but I think ARL-H might stand a chance. Considering it's using the full-fat Zen 5 cores, I found it a bit underwhelming. Single-core efficiency isn’t any better than Strix Point, and multi-core performance is only on par with ARL-H (edit: reviews number are wrong I got misleaded). On the other hand, the iGPU is a real home run - it’s consistently matching or even beating laptop 4060/70 GPUs while consuming similar wattages for the entire chip compared to a dGPU. That’s just f___ing insane. It’s a shame it’s only using RDNA 3.5 - imagine if it had RDNA 4 or UDNA with massively improved ray tracing and FSR 4. At that point, it would make mid-range NVIDIA GPUs completely obsolete.
5,228
4,682
Can you see the split wattages for the CPU and GPU? Reviews looked good because they were comparing Halo products to older Intel and Ryzen parts, but I think ARL-H might stand a chance. Considering it's using the full-fat Zen 5 cores, I found it a bit underwhelming. Single-core efficiency isn’t any better than Strix Point, and multi-core performance is only on par with ARL-H. On the other hand, the iGPU is a real home run - it’s consistently matching or even beating laptop 4060/70 GPUs while consuming similar wattages for the entire chip compared to a dGPU. That’s just f___ing insane. It’s a shame it’s only using RDNA 3.5 - imagine if it had RDNA 4 or UDNA with massively improved ray tracing and FSR 4. At that point, it would make mid-range NVIDIA GPUs completely obsolete.
The only CPU Worth standing a Chance is ARL-HX
sl0519
58
151
66
Single-core performance and efficiency I meant, considering the fact that it is using the full-fat Zen 5 cores. (*edit: Dave2D got the multi-core number of U9 285H wrong so I got misleaded)
Reactions: 511
Chicken76
281
69
101
what are the chances the burn is falsified? is it easy to do?
Interviewer: "So tell us, how did your 9800X3D explode?"
Burnt AMD customer: "Well, I was watching my favorite daytime drama and playing with this hunk of metal that came with the computer you can see under the desk there, when the room filled with smoke"
Interviewer: "And this caused you to miss your show?"
Burnt AMD customer: "Right when it was getting to the good part too! Turns out my CPU exploded."
Interviewer: "Oh... So what are you going to do now?"
Burnt AMD customer: "I guess I'll display this on the shelf with my childhood action figures, 'cause it's pretty with the pipes and the fins you see? And replace every system I have with not-degraded-yet Raptor Lakes"
Interviewer: "Understandable. You don't feel like taking any chances anymore with these computer chips"
